Calculated MPG vs. Indicated MPG of the c - Please post your results
Discussion in 'Prius c Fuel Economy' started by F8L, Mar 11, 2012.
  1. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    If the computer readout was 66 mpg you can safely state
    that you obtained over 60 mpg. Based on the computer
    for the Prius C being off about 3 mpg (over read).
  2. Kirkuleez
    Kirkuleez New Member
    220
    24
    Oshkosh, Wisconsin
    Filled up again today and got 397.1 miles on 8.319 gallons for a calculated 47.73 mpg's. Car indicated 49.9 so about 4% off this time.
  3. pakitt
    pakitt Senior Member
    2,173
    1,312
    Colorado
    I am starting to wonder what the Yaris Hybrid, based on the same exact drivetrain, will yield on European roads. It appears that the c is a winner. And is more accurate in reporting the MPG.
    BTW: I think most manufacturers are not accurate on their MFD readings on purpose and for cost reasons, moreover 99% of drivers do not calculate the fuel consumption by hand and rely on what reported from the MFD, if they ever look at it. Most drivers go by the amount of money they put in per week/month or trip. Only freaks like us here check to the last decimal way is going on... :)
  4. Maxwell61
    Maxwell61 Active Member
    384
    238
    Italy
    Hi Pakitt,
    You in Germany seems to have more data available than the rest of EU upon the Yaris HSD: by chance, have you come across the weight data of the Yaris HSD, so to compare to Prius C?
    I do remember that yaris cx is 0,287 rather than Prius C 0,28 , so i'm expecting something less on highway FE and maybe something more for the rest due to some possible lighter weight. Not only the Yaris is more than 10 cm less than the Prius C in lenght , but also the structure should be lighter due to the slightly less restrictives rules of EuroNCAP crash test.
    Edit: Sorry if that sounds a bit OT...
  5. arlotone
    arlotone New Member
    25
    Portland, OR
    Based on a review of the posts here and on this similar thread, it looks like the computer runs about 2 mpg higher than the calculated mpg.
    Giora suggested above that increasing your tire pressure would improve the accuracy of the dashboard gauge. I think that theory supposes that the distance is calculated incorrectly due to a variation in tire size. I never thought about the distance calculation, but assumed it must be fairly reliable in all cars, since odometer readings are so important for valuing a car. Could variations in tire pressure really account for a 4% discrepancy in the odometer, which would in turn affect the mpg calculation by the same amount?
  6. maverickf
    maverickf New Member
    113
    Southern California
    Year of vehicle: 2012
    Date:
    4/6/12
    Miles driven: 471.8
    Gallons Pumped: 9.15
    Hand-Calculated MPG: 51.56
    Displayed MPG: 54.4
    Average Speed: (Didn't check) about 6% local, 94% highway
    Tire Size / Wheel size: 15in
    Tire Brand / Model: Original
    Tire PSI (Front / Back): Original
    Seasonal Conditions: Sunny, ~55-80 F
    Commute Length: 148 miles round trip
    Hypermiling Techniques: Tried DWL, P&G
  7. F8L
    19,011
    4,081
    Grass Valley, CA.
    The odometer is not inaccurate at least it is not in the GenII/III. It has been verified by many using mile markers. The speedometer is inaccurate, however, and reads approx. 2mph too fast in most cases. The car's computer knows the real speed though. Scangauge confirms this.
  8. PriusofDoom
    PriusofDoom New Member
    Seattle, WA
    2nd fillup tonight. 435.4 miles on 7.746 gallons. 56.2 actual, 58.6 indicated. Still 2.5-3 high, but a MUCH better tank for me. :)
    Cruise range said I had another 30 miles, so this pump may have clicked quickly. It'll balance out.
  9. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Thanks for your post.
    We have nearly 70,000 miles on our Prius and I am
    still waiting for the mpg guage to balance out.
    Consisitently off about 3-3.5 (overead) mpg from day one.
  10. pakitt
    2,173
    1,312
    Colorado
    All of the official information I got is posted here:
    http://priuschat.com/forums/toyota-hybrids/102578-yaris-hybrid-reviews-8.html#post1498353
    If I get more technical information or it is published on the Toyota.de website I will make it available in that thread.
    Yaris Hybrid and Prius v are already available on pre-order on launch date in June.
    The Prius Plug-in is also on pre-order, with lanuch&delivery in September.
  11. Prius Maximus
    Prius Maximus Senior Member
    937
    795
    Northeastern IL
    Fillup #1 not listed since it doesn't count - don't know how full the dealer filled it or how long it was driven when I bought it....
    Fillup #2 = 54.3 displayed, 51.78 calc'd, display high by 2.5
    Fillup #3 = 57.1 displayed, 51.34 calc'd, display high by 5.8
    Fillup #4 = 55.3 displayed, 52.55 calc'd, display high by 2.8
    I didn't quite get the usual top off in on #3, so that one is a little high due to my fault. But it looks like the display is running about 2.5 - 3 mpg higher than calculated.
  12. kkim
    kkim Active Member
    386
    132
    kauai, hawaii
    Year of vehicle:2012
    Date:14apr12
    Miles driven:381.4
    Gallons Pumped:7.175
    Hand-Calculated MPG:53.156
    Displayed MPG:55.9
    Average Speed:
    Tire Size / Wheel size:175/65, 6.5x15 alloy
    Tire Brand / Model: Turanza EL400 02
    Tire PSI (Front / Back): 38/35
    Seasonal Conditions: (please include A/C usage and temp setting if applicable) a/c on maybe 50%, set to 73*
    Commute Length: 13 miles one way
    Hypermiling Techniques: paying attention to HSI gauge
    Still learning to drive the car to maximize FE. 2nd fill up.
  13. ufourya
    ufourya We the People
    1,258
    336
    42
    F8L
    Standard tires,wheels, etc. on Prius c II.
    First measured fill-up was a throw-away since I paid little attention to driving technique and did not know any specifics of the dealer's fill. Measured mpg 44.4.
    Now, from top off to top off, second fill read 60.8 and calculated at 60.97. That is, 197.8 miles and 3.244 gallons. So my measured actually bested the display by a small fraction. Temperatures ranged from 70 to 80. Overcast with occasional light sprinkles. 80 % city.
    Will be posting at fuelly.com soon.
  14. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Thanks for going top off to top off. This does away with
    any differences in pump auto shutoff. Its nice to see
    the computer mpg gauge is accurate. I recall that
    Wayne Gerdes from cleanmpg.com did the same with
    a Prius C about 2 months ago and I believe from
    top off to top off the gauge was within 1% of true.
    It looks like you confirmed that as well.
  15. pakitt
    2,173
    1,312
    Colorado
    Well, I would like that on my Prius 2010 - when I am topping off, I get 7%, when I am not topping off (about 1L difference) I get 5%...way far from 1%...
  16. F8L
    19,011
    4,081
    Grass Valley, CA.
    Thanks, ufourya.
    If we can add a few more data points like that we may learn something. Once the weather stabilizes around here I plan to do the same with my GenIII.
  17. managerman
    managerman Prius v Nerd
    228
    110
    Columbus, OH
    Ok...second tank down...here are the stats...
    Date:4/19/12
    Miles driven: 531.5
    Gallons Pumped: 9.3
    Hand-Calculated MPG: 57.1
    Displayed MPG: 58.2
    Average Speed: 21mph
    Tire Size / Wheel size: 15"
    Tire PSI (Front / Back): 42/40
    Seasonal Conditions: No AC use...nice temps in Columbus, OH
    Commute Length: 5 miles each way to work....some other longer trips also..
    Hypermiling Techniques: Pulse and Glide
    Other: None
    -M
  18. pakitt
    2,173
    1,312
    Colorado
    Why did they not put such a nice summary (I refer to the pic!) on the Prius Gen 3??? :Cry:
  19. rjdriver
    rjdriver Active Member
    407
    168
    Rhode Island
    2012 Stock C3 with alloys and Turanza EL400
    Total odometer miles: 1223
    Miles this tank: 456.8
    Temperatures: 50-80 (weird week in New England)
    Displayed MPG: 52.1
    Calculated MPG: 50.94
    Did not top off on either fill. Next measurement reported will be top off to top off.
  20. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    That is the most scientific method to use for comparison
    of calculated and displayed mpg's.
