Do you "EV Foot Flick"?
Discussion in 'Prius c Main Forum' started by kkim, Apr 8, 2012.
  1. kkim
    kkim Active Member
    386
    132
    kauai, hawaii
    And by "normal" you mean? As far as I can tell, this will only work in a hybrid car.
  2. t_in_the_front
    t_in_the_front Junior Member
    Bay Area
    In ICE cars best to DWL, drive with load. Keep the pedal steady on an overpass or small hill. Just let your speed drop then get it back the other side of the hill.
  3. yogipaolo
    yogipaolo Junior Member
    69
    washington, dc
    The manual does say that if you back off the throttle, the hybrid system will automatically switch to EV. I found this out by accident, then came across the description in the manual.
    My technique is to accelerate from a stop moderately, reach target speed, then quickly back off the throttle. Then I gradually press the throttle to maintain speed.
    The lights in my city are timed fairly well, so i try to stay average within 5 mph of the posted speed to make lights.
  4. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
    Yogi, you got it.
    That is how to do it.
    No slamming on the gas and then braking.
    Keep it smooth and always let off the gas and slowly press it again to keep speed.
  5. Tek55
    Tek55 Junior Member
    96
    Houston
    It's painful to EV Flick in the city and get 67 mpg only to drop to 54 on the freeway... :-(
  6. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
    54mpg is still way higher than it is rated:rockon:
  7. bdub
    bdub New Member
    60
    Maryland
    It really annoys me having people punch the accelerator then slam on the brakes. Only if they learned to drive smooth...
    The smoother you drive these cars, the better.
  8. Tek55
    Tek55 Junior Member
    96
    Houston
    I find that a little part of me finds joy in watching others waste gas by passing me ridiculously fast off a light, only to be at the exact same stop light that I roll up on ten seconds later.
    It's my favorite unspoken "HA! IN YOUR FACE!" moment that makes me smile every time they look at me and roar their aftermarket exhaust systems.
    Better yet, I find solace in the slow acceleration when I know that I'm a smooth operator and they're not.
  9. LizKauai
    LizKauai First PriusC3 owner on Kauai!
    70
    Kauai
    A few years back my boss noticed that his 4runner got better mileage when I drove it often.
    The easy acceleration, backing off and gliding and easy deceleration worked. He works in numbers so a 10 - 14 % increase in fuel efficiency was very meaningful! :D
  10. kkim
    kkim Active Member
    386
    132
    kauai, hawaii
    I'd chalk that up to a difference in driving styles, not due to the 4runner running in the EV mode. :p
  11. LizKauai
    70
    Kauai
    True. :rockon: Boss learned the style and did himself a favor. :rockon:
