2012 Prius Three Owners - Disable Reverse Beep?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by bjhickman, Mar 5, 2012.
  1. bjhickman
    bjhickman New Member
    Long Beach CA
    Okay...I've searched the site for a couple hours now, and I cannot find directions for disabling the reverse beep on a Gen III 2012 Prius Three. Is my only option to have it reduced to one beep at the dealer? I've tried (so many times, we lost count) the directions for the Gen II and it simply doesn't work.
    I appreciate your help!!
    Thanks.
  2. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    You can do it with scangauge if you have it. If not, then dealer is the only option.
  3. LulzChicken
    LulzChicken Prius Enthusiast
    791
    135
    Alabama
    Hey there - cproaudio is right. The only way you can do it is to go to the dealer and ask them nicely to do it for you. At first, my dealer told me that they couldn't disable the beep because t was a safety precaution. I was like alright, I'm not goin to argue with them. Instead, I came back a few months later and asked another service rep (mentioning that the beep is listed as a customizable feature of the car, and that others have had the beep disabled by their dealers) and he did it without any questions asked. It usually helps if you're getting some type of maintenance done, instead of going in there solely for the reverse beep change. Good luck!
  4. pauln64
    pauln64 Junior Member
    77
    Macon, GA
    You can have the dealer change it. If you look in the manual, there are several options that can be changed such as when the doors lock when you put the car in park or in gear. I just took mine to the dealer and gave them a list of what options I wanted to change. No problems.
  5. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    2010 and later, you cannot disable it, but rather can change it to an intial beep only. But yes, scangauge or dealer.
    JMD likes this.
  6. pjksr02
    pjksr02 Active Member
    534
    227
    Connecticut
  7. vladkov
    vladkov Junior Member
    51
    Carlsbad CA
    I wonder what he does, that we can't do?
  8. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    How do you do it with a SC? What about the torque app?
  9. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    You can do it with the Torque app also, both the seat belt and the reverse beep.
  10. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Care to share with the torque app? :D
  11. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    Perhaps these should shed some light:
    http://priuschat.com/forums/gen-iii...difications/90414-scan-gauge-ii-question.html
    http://priuschat.com/forums/obdii-android-app/98693-geniii-prius-custom-pids-torque-app.html
    I believe http://torque-bhp.com/ is the right place. I don't know since I no longer have an Android phone. I have owned http://www.scangauge.com/products/scangaugeii/ for a few years though.
  12. RichardAK
    RichardAK Member
    121
    Fairbanks, AK
    Or with one of the many, relatively cheap ($20) ODB-II connectors (USB or Bluetooth) and your laptop (PC or Mac) or Android phone. There are several posts on this site on how. You're not limited to just the ScanGauge or dealer. Though the ScanGauge would be kind of cool...
  13. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    If you're ever in Orange County, let me know.. it only takes like a minute
    Or do like RichardAK said.. if you have an Android phone.. if you dont have an Android phone, they shouldnt be hard to find used (even free from friends).. even the oldest Android phone (the G1) will work
  14. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I'll read into the Droid method. Thx
  15. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    Will your dealer do it for you?
    Before I helped a friend get an '11 Prius, I'd read threads here about basically getting the salesman to have the customizations changed (e.g. reverse beep and others) as a condition of the sale. No changes? No sale.
    On the '10 and '11 Priuses, many/most of the options that you can apparently now change via touchscreen on the '12s had to be changed via OBD2 (typical way is thru Techstream).
    I didn't know if the reverse beep was one that still required Techstream (or something that sends the right messages).
    When I showed the pages in the manual w/the customizations to the salesman (when my friend was buying) and asked about getting the reverse beep changed, funny enough, the salesman had no idea and never heard of it before. He walked us over to the service desk. The service writer said: we'll change these options for you one time for free, just bring it in and tell us want you want changed.
  16. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Don't know if the dealer will help. Guess ill have to give it a shot.
  17. Gabby
    Gabby New Member
    I have a 2o13 and i'm going crazy over the reverse beep! i wish there was a way to do it myself.
  18. vito.a
    vito.a Junior Member
    52
    17
    Tucson, AZ
    ataylor2 likes this.
  19. BuckyB
    BuckyB Junior Member
    48
    Chatsworth, Ca
    2013 Prius v wagon
    I did it this morning with a $9 Chinese OBDII Bluetooth adaptor, my Android phone and the free ELM 327 Terminal app, following the instructions found on this board. Worked like a charm. Actually, I didn't think I was doing it right, due to my friendly neighbor distracting me wanting to chat. But the next time I put the car into reverse, YEAH! ONE BEEP! Thanks guys!
