How Green is the PIP? Where Do You Live?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by bilofsky, Apr 15, 2012.
  1. bilofsky
    bilofsky Privolting Member
    525
    177
    S.F. Bay Area, CA
    2014 Chevy Volt
    Some good points.
    "Production and consumption of gasoline are assumed to produce 11,200 grams CO2e/gallon, based on GREET 1_2011 default values." (UCS report, p. 9)"
    But no regionalization for this figure.
    The Argonne National Laboratory GREET model calculates:
    • "Consumption of total energy (energy in non-renewable and renewable sources), fossil fuels (petroleum, natural gas, and coal together), petroleum, coal and natural gas.
    • "Emissions of CO2-equivalent greenhouse gases - primarily carbon dioxide (CO2), methane (CH4), and nitrous oxide (N2O).
    • "Emissions of six criteria pollutants: volatile organic compounds (VOCs), carbon monoxide (CO), nitrogen oxide (NOx), particulate matter with size smaller than 10 micron (PM10), particulate matter with size smaller than 2.5 micron (PM2.5), and sulfur oxides (SOx)."
    Apparently the term CO2e includes the CO2-equivalent greenhouse gases (which might include hydrocarbons other than methane, but methane is the major one) and not the others. The report's subtitle is "Electric Vehicles’ Global Warming Emissions and Fuel-Cost Savings across the United States," so it only considers the greenhouse gases.
    From a cursory look at GREET, it appears to lump all passenger cars together. And the UCS report is comparing EVs to the average passenger car.
    "To most accurately compare electric and gasoline vehicles, the emissions from producing the fuel as well as from consuming it must be taken into account. For gasoline vehicles, this means including emissions not only from propelling the car—i.e., by combusting the fuel in the engine—but also the emissions associated with extracting petroleum, refining it, and delivering it to the vehicle." (p. 8)
    One would think this includes flaring.
  2. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Just because wind turbines are shut off at night does not automatically mean that consumer green energy purchase turns them back on. It depends whether the *entire* clean fraction of the grid at night is already bought by others and specifically allocated to them.
    It is a fact of life in the US that utilities want to run their plants as efficiently as possible, using the cheapest fuel available. They are sometimes hampered by regulatory requirements, but dimes to dollars, that means burning coal; or even better, burning coal at night. Spending you enviro dollars at the utility is very unlikely to get you more green kwh on the grid.
    Since we (domestic US consumers) do not usually have the option to buy into green co-ops, PV and solar heating are the best alternatives to actually produce green kwh, or reduce consumption of dirty kwh.
    Unused hydro is very different than shutting off wind turbines. If the hydro is not used at night, it is available for later use.
  3. bilofsky
    525
    177
    S.F. Bay Area, CA
    2014 Chevy Volt
    Sigh.
    Fortunately, here in Marin County, we now have our own local power authority which offers two choices: a minimum of 50% renewable energy, or for a penny more, 100% renewable.
    So my recharging may be diverting coal generation elsewhere, but at least it won't be firing up any more of it.
  4. SageBrush
    11,627
    2,533
    Southwest Colorado
    I'd like to think you are right, but I am skeptical.
    Your utility says
    To clarify why I am skeptical, look at this contrived example:
    Marin country
    10,000 kwh total energy use a day -- all imported
    Export regions
    100,000 kwh total energy a day produced, of which 10,000 kwh is clean and 90,000 kwh is dirty. 10,000 kwh dirty energy exported to Marin CO
    10,000 kwh clean energy produced a day, consumed locally.
    Marin County proposes 'green purchase,' avidly taken up by EV'ers who add 5000 kwh a day of green EV demand.
    ok...
    Export regions now
    Consume 5000 kwh clean energy a day
    Export 5000 kwh clean energy to Marin
    Produce 95,000 kwh dirty energy, of which 10,000 kwh exported to Marin and 85,000 kwh dirty energy consumed localy, an unchanged total of 90,000 kwh total energy consumed locally, but now with a higher content of dirty energy.
    Net result: the additional 5000 kwh a day of clean energy demand in Marin CO results in additional 5000 kwh a day dirty generation in the exporter region.
    I congratulate and thank you for putting up PV. THAT makes a positive difference. I hope you do not read me as critical of you, quite the opposite. I do wish however to educate environmentalists so they are not fooled by green-washing.
  5. ProximalSuns
    ProximalSuns Senior Member
    1,877
    PNW
    Nope. The study said that even assuming the dirtiest coal generated electricity, the electric cars were less polluting. Many of us have option to pay for wind power electricity at a higher rate so even in a "dirty" region one could have a zero emissions vehicle. Cool!
    • Nationwide, EVs charged from the electricity grid produce lower global warming emissions than the average compact gasoline-powered vehicle (with a fuel economy of 27 miles per gallon)—even when the electricity is produced primarily from coal in regions with the “dirtiest” electricity grids.
    • In regions with the “cleanest” electricity grids, EVs produce lower global warming emissions than even the most fuel-efficient hybrids.
    • EVs charged entirely from renewable sources like wind and solar power produce virtually no global warming emissions.
    And the name of the company that destroyed the Gulf of Mexico was what?
  6. SageBrush
    11,627
    2,533
    Southwest Colorado
    Grrr
    I like the UCS; heck, I send them money. This article however is spin.
    Increased electricity demands do not make the sun shine brighter, or the wind blow harder (EV fans respectfully excluded as minor contributors.) Nuclear is baseload. So the increased demand is ENTIRELY covered by NG, oil, and coal*. The proportions vary from region to region, but are NEVER less CO2 intense than NG. Period. End of Story, until the grid is 100% green, and excess green capacity is available.
    Now look at the UCS study again. A 'mostly coal' region EV is equivalent to a 27 mpg car, so a 54 mpg Prius is better than a 100% NG car, since the carbon intensity of NG is 55% that of coal.
    That is for GHG; EVs fare considerably worse in Sox and Nox.
    *I can think of two possible exceptions: One would be a grid where the fractional demand for green energy exceeds the green fraction in the production area. I do not know of any place that situation exists today.
    The second situation would be regulations that require a fraction of total energy production be green; then that fraction would apply to the increased demand as also. As I mentioned earlier though, the regulations typically apply to consumption rather than production, so the utility simply buys unallocated green energy from other producers.
  7. bilofsky
    525
    177
    S.F. Bay Area, CA
    2014 Chevy Volt
    Thanks for your comments and for taking the time to look at Marin Clean Energy.
    Those hypothetical 10 MWh/day of countywide consumption used to include (as of 2010) 8.4 MWh nonrenewable, all from PG&E. By this summer, roughly 80% of consumption will be through MCE, with minimum 50% renewable. So now we're down to less than 5.7 MWh nonrenewable out of 10.
    Still, your analysis sounds right in the short run and we may just be shifting the dirty power elsewhere.
    But as more people choose to buy green electricity (where available), more local [ame="http://en.wikipedia.org/wiki/Community_Choice_Aggregation"]Community Choice Aggregators[/ame] agencies like ours are formed, and more regulators require a higher percentage of renewables, at some point more renewable power will have to be generated. (If you live in Massachusetts, Ohio, California, New Jersey or Rhode Island, ask your local government to consider community choice aggregation.)
    Under California's Renewable Portfolio Standard, utilities were required to be 20% renewable by 2010 and 33% by 2020. (They didn't hit the 2010 target, but two of the three of them came close. Sigh.) So eventually, for every new kWh of coal generation that EVs suck up at 2 am, the utility will have to find half a kWh of renewable. Eventually shifting will hit the limit and it'll have to be built.
    Unless, of course, the oil and coal folks manage to stave off the regulators and frack up enough communities to keep renewables uncompetitive. Well, at least Marin Clean Energy is also helping build local renewable electricity sources. Too bad we have to share the planet with those other guys.
  8. SageBrush
    11,627
    2,533
    Southwest Colorado
    Contrary to my nature, I will not quibble here, and just agree with your post ;)
    The cynic in me however suspects that way before the shifting reaches its limits, NG will be reclassified as a 'green' fuel for portfolio compliance requirements.
  9. ProximalSuns
    1,877
    PNW
    We call it science.
    Meaningless non-sequitor generalities don't change the scientific facts.
    Wind power is zero CO2. A different end to the story.
    Also wrong again as BPA is shutting down the wind power to run the hydro. Has to do with artificial rate structure that allows BPA to charge more for hydro. Hydro has severe environmental costs though not CO2 related. It has destroyed the billion dollar salmon, shad runs along with heat pollution of the water, along with the artificial lakes has terrible effect on water quality.
    It also hurts the wind power industry and US economy effort to build sustainable energy industry and jobs and power plants.
    Feds rule BPA wind-power shut-off was unfair: Federal regulators ruled Wednesday that the Bonneville Power Administration discriminated against wind-power producers when they ordered shutdowns of their operations this spring during a time of glutted electricity markets.
    To this topic, wind powered PIP is a winner in cutting CO2.
  10. bilofsky
    525
    177
    S.F. Bay Area, CA
    2014 Chevy Volt
    Awww, shucks. Have I charmed you? ;)
    Or the utilities will pay a $2500 fine and keep on buying coal power.
    I just wish the California community choice aggregation law hadn't excluded nuclear power. It may not be renewable, but given a choice between the problems of global warming on the one hand, and nuclear safety and waste disposal on the other, I know which one I'd rather deal with.
    (Have I uncharmed you?)
  11. SageBrush
    11,627
    2,533
    Southwest Colorado
    Nah, still charmed.
    Wind and solar exist, so I see no reason to consider nuclear. More specifically, I see no reason for the public to limit corporate exposure liability for environmental damage, the way it is currently for oil and nuclear.
  12. SageBrush
    11,627
    2,533
    Southwest Colorado
    No doubt.
    The authors try to wiggle out of their poor reasoning in Appendix 'A', where they write
    See the logical fallacy ? The decrease [or increase] in GHG is virtually imperceptible, too. comment in [] and bolding is mine.
    The second logic fallacy is saying that additional green production in the future that exactly offsets the higher demand (say, from EVs) makes the EVs green by extension. This ignores the fact that had the EV demand not materialized, the grid would be that much greener. Unless you can convincingly argue that EVs are the cause of increased green energy production, this is just a game of musical chairs (or energy shifting, as bilofsky aptly names it.)
  13. bilofsky
    525
    177
    S.F. Bay Area, CA
    2014 Chevy Volt
    Ideally, I agree. As a practical matter, if the profit-driven, environment-unconscious utilities find nuclear more attractive than wind or solar, I say better that than coal or hydrocarbons.
    Because the corporations would just add it to the price for energy, and the public isn't willing to pay more because politicians have gotten people addicted to the budgetary equivalent of a perpetual motion machine.
    Oh, you meant you see no logical reason.
  14. SageBrush
    11,627
    2,533
    Southwest Colorado
    The utilities could not pass on the price -- it is too high. They would default to lower priced sources, which today are NG, solar, and wind.
    If they become liable for fracking damage without liability limit, only wind and solar remain.
  15. ProximalSuns
    1,877
    PNW
    Yes. You've bumped into a solid scientific study with great documentation that disproves your unfounded personal opinions. You then quote their clear explanation that proves you wrong and then say "See?".
    Yes we do see.
  16. SageBrush
    11,627
    2,533
    Southwest Colorado
    You have reminded me of a joke I heard long ago:
    It is OK to talk to yourself;
    It is OK to answer yourself;
    Time to see the shrink when you say "excuse me, what did you say?"
  17. drees
    drees Senior Member
    1,782
    247
    Ah, the old "Marginal power" argument again.
    By your logic, emissions from any load depends on when you first plug in (or unplug from) to the grid.
    So if I look at my 1000W flood light that I've been running 12 hours a day (I'm scared of the dark) for the last 15 years, when I plugged it in it caused my utility to divert a bit more water to the hydro turbines to compensate with no extra CO2 emissions.
    Fast forward to today where marginal power is imported from out of state generated by dirty coal plants and I defeat my fear of the dark allowing me to turn off my 1000W night-time load.
    How much credit do I get for reducing my marginal load - is it 1000W worth of hydro? Or is it 1000W worth of dirty coal? Or do I claim a mix?
    What if I replace my 1000W flood lights a month later with an EV that I trickle charge at 1000W or 12 hours a night? Who's on first?
    My point is - if you count any "new" load on the grid as marginal power and thus generated by some dirty power plants - I'm going to argue that every other load on the grid is also 100% responsible for that dirty power - until it isn't, anyway.
    Which doesn't make any sense at all.
    Yes - adding a new load to the grid can raise emissions by whatever the emissions of the marginal power plant are. But those emissions are shared among ALL customers plugged into the same grid. Using average emissions is the only thing that makes sense.
  18. bilofsky
    525
    177
    S.F. Bay Area, CA
    2014 Chevy Volt
    Well, there's the short view: Plugging in one more EV (or 1000 watt floodlight) won't change the mix. So use the average power.
    Then there's the medium view. Plug in a bunch of EVs, and put substantially more dirty power on line. So use marginal power and conclude that EVs increase greenhouse gases (or rather, decrease it but not as much, and in many places hybrids do better).
    The long view: Plug in a humongous number of EVs and force some of the cleaner plants to come on line. So eventually EVs will decrease GHGs.
    Depending on your view, you can make different assumptions about marginal vs. average power. As shown above.
    (Then there's the cynical view: Private utilities will pollute as necessary to maximize profit and do whatever they can to hamstring the regulators, so not much is going to improve until the economics or the system changes. All power (companies) to the people!)
  19. hill
    8,793
  20. miscrms
    miscrms Plug Envious Member
    2,079
    526
    Phoenix, AZ
    It does seem to me that this is an oversimplification that makes the results pretty hard to put too much stock in.
    The Prius is a perfect example of how 1+1 does not equal 2 in a non-linear system. The Prius uses the motor/generator to put an additional load on the engine under some conditions and reduce the load on the engine in other conditions. The efficiency of this conversion and storage is inherently less than 100%. So by simple linear math we can prove that the hybrid system will make the Prius less efficient than a regular gas vehicle, as the power added back by the motor is less than the power the engine had to provide to drive the generator.
    Except that we all know this is not true. The engine is loaded by the generator when its running lightly loaded and its efficiency is poor. The motor supplements the power of the engine when its load is high (or very low) and efficiency would also be poor. By keeping the engine operating in a fairly high efficiency band any time its in use, significant amounts of fuel are not wasted in inefficient operating regions and overall fuel consumption is significantly improved. Accurately describing the non-linear behavior of the system is crucial to drawing the correct conclusion about the impact of adding the hybrid system.
    Its not a perfect analogy, but the same is largely true of describing the impact of charging EVs on the grid. Part of the reason the night time GHG emissions look bad is because of the type of plants that have to be kept online at night, but part of the reason is also because those plants are running lightly loaded and consequently are running at low efficiency. As a result its not really valid to just say all these coal plants running at night are putting out X tons of GHGs, and increasing the load 50% by charging EVs will just cause 50% more coal to be burned and 50% more GHGs to be produced. Increasing the overnight load would likely allow those plants kept online (and those required to be kept "idling") to be run at a higher percentage of their design load and consequently operating at significantly improved efficiency.
    Specific data is pretty hard to come by, and will vary greatly both seasonally and regionally. One example showing several plants operating between ~20% and 40% efficiency from 10% to 30% load are shown on page 7 here:
    http://esd.mit.edu/symposium/pdfs/papers/connors.pdf
    In a case like that an increase in demand that allowed the operator to increase the load on a given plant could put out 3X more power while only burning 50% more coal. Consequently the increase in load would only be responsible for 1/6 of the increase in GHG emissions that a simple linear calculation would predict.
    So I guess I would argue that in addition to the factors others have mentioned, wind turbines being parked, surplus energy being wasted blowing off steam or heating water at plants that can't be shut down, etc, there is also significant potential for reducing overall emissions by increasing the load upon and efficiency of the significant number of plants that are underutilized at night and/or off season.
    That would help explain why most utilities are so supportive of electric vehicles. In general its cheaper for them to pay customers to use less electricity than it is for them add capacity, but electric vehicles provide a significant opportunity for them to operate their plants more efficiently which for them translates to more profitably. For the rest of us it translates to less resources consumed and less emissions per unit energy for the entire grid.
    2 people like this.
