iPhone Bluetooth streaming issue
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by elmofongo, Apr 18, 2012.
  1. elmofongo
    elmofongo Member
    256
    SF, CA
    I am able to stream music from my iPhone Music app via Bluetooth without any issue.
    But whenever I try to stream audio from an app on my iphone other than the Apple Music app (such as an Internet radio app), the Music app starts streaming simultaneously and I end up with both audio sources playing at the same time on my Prius audio system. It seems like the Apple Music app is always the default streaming source even when other apps are streaming.
    Does anyone have a workaround?
  2. bfd
    bfd Plug-In Perpetuator
    659
    172
    Close to SDSU in the Far Southwest Corner of Cali
    I'd use USB. it's not sexy, but BT really eats your phone's battery. If you're charging, use the line out. I've always had a buzz when I try to do that, but maybe it'd work.
    Once I have a PiP to test...(mañana, mañana) I'll see if there's a better way and post back.
  3. usdmattiphone
    usdmattiphone Member
    147
    58
    That's really odd, i use Spotify all day long and never have that problem. If i hook it up via USB it defaults to the built in music app, but the second i start spotify the built in music app stops and spotify takes over.
  4. longterm
    longterm Member
    152
    Nashville, TN
    I agree with BFD, use a USB tether instead. I have an iPhone 4S and was able to use Entune apps this morning when I tethered--with Bluetooth I was never able to get any of them to connect, even though the Entune app was running on the iPhone.
    I agree that it would be better if I were able to stream from phone to car with Bluetooth, especially since I keep an iPod in my car all the time with my complete music collection on it (70GB); however, this works really well for me, and I'll take a good connection over a spotty (or nonexistent) connection w/ Bluetooth anytime.
    Bob
  5. pfile
    pfile Member
    319
    35
    bay area, ca
    i use rdio all the time and have not seen this either, but i wonder if you hit play/pause from the prius display that it activates Music.app instead of rdio/spotify?
    for whatever reason, the prius does not see my iCloud-stored music when attached by USB. since Music.app's intereface disappears when you connect via usb, the only way to play the icloud songs is to use the bluetooth interface... so that's a reason to use BT.
    i don't think internet tethering over bluetooth is supported.
  6. dionlbc
    dionlbc Junior Member
    LBC
    This is an issue with iOS 5.0.1 and 5.1, apparently bluetooth Internet streaming worked prior to these releases. I know that Androids work fine with this feature. For me it's a pain with my iPhone because I have all my music on my iPod so that occupies the USB port, but if I want to switch to Pandora or another streaming app I have to swap devices.
  7. CharlesH
    2,798
    1,166
    Roseville, CA
    I'm really surprised that iPhone users are having such problems. Usually, developers put all their energy into first getting the iPhone version of their application fully working, and then Android, and then (maybe, sometimes) some other platform. What is surprising is that that all of this streaming over Bluetooth is working fine on my Blackberry. And Toyota has declined to support Entune on my new Blackberry, due to "unsatisfactory user experience". (I had to side-load the Entune app for an old model.)
  8. bfd
    659
    172
    Same thing - only different - happened when I bought my GenII in 2009. First thing that didn't work as expected? iPhone and bluetooth streaming to the Toyota's system. Toyota's system caught up in the higher end '09 models like Venza, but now they're seemingly behind the curve again.
    The technology is such a moving target. Wireless connection technologies like BT are only as good as the fastest, most recent evolutionary version. And getting EVERYTHING that came before that version to play nicely together - simultaneously - is still an elusive goal.
  9. elmofongo
    elmofongo Member
    256
    SF, CA
    Well today I switched to a USB cable and got the same issue.
    When I tried a streaming app on my iPhone, the Apple Music app started playing too.
    Effectively same result, 2 apps streaming simultaneously wether via Bluetooth or USB cable.
  10. pfile
    pfile Member
    319
    35
    bay area, ca
    what app is it? it sounds like it's got bugs, since spotify and rdio seem to work okay.
  11. elmofongo
    elmofongo Member
    256
    SF, CA
    Well I tried 2 streaming apps. One is a French radio app and the other is Pandora. I'll try some others to see if it's an app problem.
  12. elmofongo
    elmofongo Member
    256
    SF, CA
    Resurrecting this thread since I'm still having this issue.
    I have an iPhone 4S and I can't get any of my iPhone apps that are capable of using Bluetooth streaming to work without the iPhone Music app to stream at the same time. Very annoying.
  13. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    You should be able to hit pause in the iPhone Music app to get it to shut up, and then be able to use your other bluetooth streaming capable apps.
    DianneWhitmire likes this.
  14. DianneWhitmire
    DianneWhitmire High PRIUStess
    4,062
    1,123
    64
    Laguna Niguel, CA
    Entune = quirky.
    I've never, ever had a Toyota's or Lexus's NAV system direct me vocally right over the phone call I was in, at the same time. :whistle:
  15. rockerdan
    rockerdan PiP Rocks!
    427
    83
    Wheatfield NY
    Im not big on BT streaming with my IP4.....BT IMO is good for phone calls only...the sound quality is not so great.
    I just grabbed a 16gb low profile USB flash drive, its low profile so when i put stuff into the armrest it wont hit it. I got it from Best buy for 15 bucks.
    the best part is it only took 15 mins to drag all my music onto it(approx 2500 songs) and I still have lots of room left.....the USB sounds better then the BT does.
    and plugging in the Ip everytime i get into car is just a pain in nice person....i have barely ever done that.
    Only downfall of the USB flash drive is no playlists.....you can browse by artist, albums,songs,genre but not playlists...
    Dan
  16. blakemster
    blakemster Member
    130
    huntington beach, ca
    OK, I hate to admit it - ENTUNE was half baked ... now, I hear Toyota has a new system coming out in the future???? Entune sucks!
    I had such hi hopes :(
  17. elmofongo
    elmofongo Member
    256
    SF, CA
    I hit pause and both streaming apps shut up, I hit play and they both resume!
  18. rockerdan
    427
    83
    Wheatfield NY
    My audio observations after a week with my new Pip...
    I like to use the MODE button on steering wheel....this toggles from my BT Ip4 to my USB flash drive to radio FM, AM Sat radio ect ect.....It works well as I always have my fave radio and XM radio stations on so every MODE toggle pulls another great song from wherever you go to next.
    while I love the USB flash drive it is lacking in the fact you cannot do playlists....I got that to somewhat work though yesterday by going into itunes, and opening one of my playlists......For example I open a playlist I created in itunes named "current faves". Then select all(highlites every song in list) and right click choose GET INFO, then INFO tab. Now at bottom of that window you see GENRE. I typed in "Current Faves". This changed the genre of every song in my current faves playlist at once.
    well when i tried searching by genre in the car it does come up....i think it takes time to learn and find each song, as at first it barely found any..but it seems to be grabbing more and more each time. Ofcourse the other problem is the car puts the songs in alphabetical order, so your playlist wont look the same order. But it sorta works.
    for my true playlists on my Ip I tend to just leave my iP set on my fave playlist, so when i toggle the mode button on steering wheel to BT that playlist will start....and ofcourse on BT you can only toggle ahead or back one song at time and cannot browse. I just hate having to plug phone in when my USB drive is there, and when driving around getting in and out of car its not convenient. for long drives plugging in the iP is not too bad though.
    Dan
  19. Net Junky
    Net Junky Junior Member
    Well I think there is one big thing you guys are leaving out is to inform which system you have. The display audio with entune (base model) is made by Harmon and the hdd is made by denso. Both system runs differently and different quirks about each.
    Display audio works best with USB. It how the system works.
    Hdd works fine with bt for iPhone.
    Now here is the kicker....and what the issue is with the system is apple doesn't care about using outside systems. They don't care to support anything other then apple product so that is why it doesn't work seamless. Also Bluetooth has over 50 minor protocols you don't see that enable little things like call history, address book, audio streaming etc. every phone has to go through the tests and certified which is displayed on their website.
    Which system do you have?
  20. ProximalSuns
    ProximalSuns Senior Member
    1,877
    PNW
    The Display Audio works OK with the iPhone. iPhone does it's Bluetooth for phone and music find. It will do the Entune's apps via USB OK. If you purchase Mobile Hotspot capability for your iPhone from ATT, then the iPhone will do Entunes via Bluetooth fine.
    Trick with iPhone/Bluetooth internet connection (which is not officially supported but does work) is to go into the Setup/Bluetooth and edit your device. One of the items is VPN/DUNS where you need to enter your Entunes ID and PWD into the Nav. Once you do that, iPhone will do Bluetooth internet connection well.
