Anyone hardwire their V1?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by d2mini, Apr 17, 2012.
  1. d2mini
    d2mini Active Member
    519
    106
    Houston
    Or other radar detector?
    It's always the first thing I do to my cars and it's usually easy to find info on the forums, but my search turned up zilch here on priuschat. :confused:
    Usually i just run the wiring along the top of the windshield, down the a-pillar, into the side of the dash, and that's usually where the fuze box is so I tap into a fuse that has switched power running to it. Where are the fuzes on the Prius? Can i still follow the same basic install? Any tips?
    Thanks! :rockon:
  2. d2mini
    519
    106
    Houston
  3. GoldPianoGarden
    GoldPianoGarden Bling Meister
    841
    72
    98
    Brunswick, GA
  4. GoldPianoGarden
    841
    72
    98
    Brunswick, GA
    I have a couple of other things mounted here and there on my windshield that are done that way (i.e., a large-screen Magellan GPS). I don't know where the fuse box is, tho... I assume under the steering wheel area, but that's just a guess from stereo installation wires temporarily clipped up and hanging over to that area).
    I'd get the BlendMount to put it right onto your rearview mirror, tho. That's what I did, and the wires don't show at all...
    BlendMount Custom Radar Detector Mounts Escort Beltronics Valentine One
  5. d2mini
    519
    106
    Houston
    Oh awesome, so blend mount works on this car?
    My mirror on my A3 doesn't work with it, so i totally forgot it existed.
    So where did you tap into power for your radar?
    Thanks!
  6. leeb18c
    leeb18c Active Member
    272
    202
    SF Bay Area
    I tap the power from left foot well panel and ran the phone cord along the a-pillar and windshield/headliner towards the rear view mirror while installing new head unit. I forgot the exact acc pin/wire but you can search here for that. The v1 is sitting on the right half of the rear view mirror with velcro that i was going to replace with a better magnetic mount but haven't got around to making it. It's been that way for a few years and i can swap easily from car to car when needed. i'll see if i can get a picture later.
  7. GoldPianoGarden
    841
    72
    98
    Brunswick, GA
    Here's the only pic I could find that I had taken before I had put my car into the bodyshop, but I hadn't had it wired yet, as I had just finished sticking it into the car for the 1st time that night:
    http://priuschat.com/forums/members...-detector-blendmount-picture8934-p1020196.jpg
  8. GoldPianoGarden
    841
    72
    98
    Brunswick, GA
    I don't think my post went through.... I am 99% sure that my stereo guy did it off the mirror wires. Wires for other things are run around the pillar and down to the fuse box, though...
  9. d2mini
    519
    106
    Houston
    Cool, thanks. Maybe I'll just get that kit I linked to.
    Seems easier than running the wire to the fuse box.
    I'll get that mirror mount too. :)
  10. Judgeless
    Judgeless Senior Member
    1,821
    255
    Cleveland, OH
  11. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    GoldPianoGarden, is it possible to adjust the mount so the Valentine One is flush with the bottom of the rearview mirror? I tried another mount and the Valentine One stuck out about an inch below the mirror like your pictures shows. To me, this feels like it blocks my view and bothers me. The BlendMount looks like it could be adjusted so the Valentine One is flush, but I'd like to get confirmation to avoid having to return another mount.
  12. jdc02005
    jdc02005 Junior Member
    Arkansas
    While I'm not GoldPianoGarden, I can answer this as I have recently mounted my V1 with a BlendMount.
    Yes it can be adjusted to be flush with the mirror.
    The stock position of the mount after I got mine, had my V1 touching the mirror so I had to adjust it down and closer to the windshield a tad.
    Yay, my first post :D
    innerpri and ryogajyc like this.
  13. Gary Otto
    Gary Otto Member
    123
    Silver Springs, FL
    Don't speed....don't worry about a detector.....AND...get better mileage! Isn't that why you bought the car in the first place?
  14. d2mini
    519
    106
    Houston
    It's not about intentional speeding. I like knowing where the cops are at all times. How many times have people gotten busted because they just weren't paying attention to their speed? That beep wakes you up and keeps you honest. But then again, there are times when it's necessary to bend the rules. :D
    ryogajyc likes this.
  15. GoldPianoGarden
    841
    72
    98
    Brunswick, GA
    I just like following the speeding cops so I can make a citizen's arrest from time to time to keep them honest.... lol
    innerpri likes this.
  16. GoldPianoGarden
    841
    72
    98
    Brunswick, GA
    I bought it for that turbo boost button! lol
  17. GoldPianoGarden
    841
    72
    98
    Brunswick, GA
    If you look closely, you can see the two "grooves" where you can slide the mount up or down as closely as you'd like to the bottom of the mirror. I just left mine down a little to help prevent any reflection from the mirror causing any loss of the radar signal from getting to the rear antenna on the Valentine. And, I seem to recall the distance from the mirror that I installed mine had something to do with it hitting the top of my laptop screen if my mirror was angled a certain way....
