Rocker panel painting results
Discussion in 'Gen 2 Prius Accessories & Modifications' started by cuz, Apr 18, 2012.
  1. cuz
    cuz Junior Member
    Cape Cod
    First post here, just wanted to display results of recent rocker black-out. Used Rustoleum Textured Black over dark gray primer. Texture is very fine, and the black has just a bit of sheen, which looks nice. I removed both wheels and partially removed the front inner well liner, and a deflector from the rear. Washed the area with ammonia and water to remove the wax. Then 1/4 inch 3M vinyl masking tape (auto body), with the top edge at the rim of the door sill. This gave the spacing I was after. Then 1.5 inch masking tape row by row up past the door indent. After making sure all the tape was well pressed down, I wiped area with Wilbond to remove any grease and to soften the clearcoat for the primer to grab onto. (No sanding--fingers crossed). I can't link photos here until posting five times, so you'll have to go to my album for the pics. because
  2. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    Keep us posted on how well it stands up. Post a pic. once you can. H
  3. cuz
    cuz Junior Member
    Cape Cod
    You can get to my photos now by clicking on my name, then public profile, then albums. because
  4. Daves09prius
    Daves09prius Active Member
    680
    161
    Gettysburg, PA
    Welcome to the forum,
    I looked at your pictures, I think it looks really nice and clean. Makes me wonder why the Prius didn't come this way from the factory!
  5. cuz
    cuz Junior Member
    Cape Cod
    Thanks. I was hoping for a factory look. The little bit of black really makes the side view of the car a lot sleeker. I may add front mud flaps, but I'm still thinking on that. because
  6. maestro8
    maestro8 Nouveau Member
    471
    109
    nor cal
    I agree the look is great, but why stop there?
    Throw a bit more paint on there and you've got yourself a Boxer! :)
  7. cnschult
    cnschult Active Member
    772
    96
    Michigan
    if you were going for continuity wouldn't have been easier to paint the plastic on the bottom of the rear bumper barcelona red?
    The Berlineta Boxer is one of the sexiest sheetmetal ever fitted to an automobile (along with the Miura & GT40) so I hope you're not trying to insult Pinifarina with that joke.
  8. cuz
    cuz Junior Member
    Cape Cod
    My intention was to make the car look sleeker, or leaner, and this technique has been used by car companies on various models at least since the sixties. Painting the rear valance red would have made the rear end appear to have more mass than it already does.
