What does your insurance card say your PHV is?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by stacey, Apr 20, 2012.
  1. stacey
    stacey ☆☆☆☆☆
    115
    Lancaster, PA
    I just got my insurance card and it lists the correct VIN (finally - had a bit of a snafu there at first), but the car is listed as a "2012 Toyota Prius", not "2012 Toyota Prius Plug-in". I mentioned it to my agent but he didn't seem concerned. My insurance company is Allstate.
    I'm curious if this is normal or if it should be more specific. If I were to total the car, the VIN should be enough to prove the car really is a plug-in if that were to be questioned based on the listed make/model on the card, right?
  2. three33
    three33 New Member
    Orange County, CA
    Mine says the trim is plug-in. Make/model is Toyota Prius
  3. bisco
    51,851
    same here. not sure if it matters.
  4. ajtozzi
    ajtozzi Junior Member
    94
    It doesn't matter. Just make sure the VIN is correct, that's the important part!
  5. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    Mine doesnt mention PHV or Plug-In
  6. crewdog
    crewdog Acting Ensign Prius Prime
    492
    388
    Woodstock, GA
    Title says Prius Plug-in
    Tag receipt says Prius Plug-in
    State Farm card and policy itself says Prius
  7. CharlesH
    2,796
    1,163
    Roseville, CA
    It's the VIN that identifies it as a plug-in. That is what they looked at for the HOV decals. Similarly for the new emissions certification for the Volt.
    I think the main issue that may come up is for the Advanced trim to get a theft recovery ("LoJack") discount , since Safety Connect is standard for that trim.
    BTW, forget the Safety Connect discount if you have AAA. They say that if a factor isn't encoded in the VIN, it doesn't exist for them when computing rates.
  8. stacey
    stacey ☆☆☆☆☆
    115
    Lancaster, PA
    Thank guys. I figured it was only the VIN that mattered but it's nice to have it confirmed and see that other people are seeing the same thing.
  9. terrylowe
    terrylowe Junior Member
    79
    24
    Mississippi
    Mine lists my 2012 pip as a 2011 Prius
  10. greenleaf
    greenleaf Member
    153
    35
    Silicon Valley, CA
    When I first added insurance for the PiP, it was listed as Prius-C. The agent told me the VIN was not in the "system" yet so it could be incorrect.
    A month later, I asked the agent to check again and correct it if necessary. This time, it gets corrected to PHV.
    There is a DIFFERENCE. The PHV qualifies for additional discounts and dropped my premium.
    I am with Farmers.
  11. AMP
    AMP April 2012
    Chicago
    I wondered the same thing.
    My Prius V shows up just as "2012 Prius".
    I called Allstate, and they said they know all the features from the VIN number.
  12. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    Auto Club of So Cal lists mine as a Prius Plug-in, but no special discounts for the fact that is just that.
  13. janie
    janie 2016 Prius 3 Touring
    175
    42
    Three Touring
    Mine says its a Camry Hybrid - still hasn't been fixed. I was told it was an accident that they marked it as a Camry hybrid.
    I have an email with it corrected but they never sent me a hard copy with the correction.
  14. freakinfreak
    freakinfreak Junior Member
    Studio City, CA
    Seems like AAA was charging more for being a plug in. My rate went up replacing my 2012 Audi A7 with the 2012 PiP.
  15. rogerv
    1,639
    317
    Wow, that doesn't sound right. Kind of hard for me to tell because the Plug-in replaced an '06 Prius, and the annual premium increased by about $300. I wonder what it would be if I had bought a '12 Prius Hatchback. They may be erring on the side of caution until they get some claims experience with the Plug-in. There was some confusion on their end over the VIN, which didn't fit in their system. Took them about two months to finally get the change into that system.
