Distance to empty???
Discussion in 'Prius c Main Forum' started by StarBrite310, Apr 19, 2012.
  1. StarBrite310
    StarBrite310 ~ * ~ * ~ * ~ * ~ * ~
    335
    Please, does anyone know where to find this reading? I've searched and searched and I cannot find out how to display the distance to empty.
    I appreciate any help. Thanks!
  2. SoGalinSoCal
    SoGalinSoCal New Member
    29
    I believe it's the "Driving Range" listed on the info screen.
  3. vinnie97
    vinnie97 Whatever Works
    1,430
    277
    Somewhere out there
    Cruising Range in actuality.
  4. StarBrite310
    335
    I'm confused??? :eek:hwell:
  5. vinnie97
    1,430
    277
    Somewhere out there
    It's in the Eco screen, says something along the lines of "Cruising Range," which, as far as I've been able to ascertain, is the equivalent of distance 'til empty. :)
  6. StarBrite310
    335
    Ohhhh! Hmm, that's kind of odd. I will have to take a look at it tomorrow. Thank you :)
  7. kkim
    kkim Active Member
    386
    133
    kauai, hawaii
    Cruising range shows up in your trip information (among other places) when you turn off the car.
  8. bdub
    bdub New Member
    60
    Maryland
    Also, if you have the Nav system, cruising range shows up when you press the Car button.
    Does this number update as the car gets better avg mpg?
  9. Ashley7
    Ashley7 Active Member
    545
    222
    Oregon
    2019 Prius
    I'm curious about that too. Last night, I had two bars left on the gauge, but cruising range said 1 mile. Yes, one. Obviously that's not right. I filled up anyway because I had to stop at the post office which is connected to the gas station, and now it says 367 or something like that, which is just slightly less than how far I drove before filling up. I'm probably not going to trust it all too much, unless it calibrates itself to a more accurate number.
  10. SquallLHeart
    SquallLHeart The Techie Guy
    826
    247
    San Jose, CA
    because it's a hybrid.. there's no accurate way to really calculate and predict your driving conditions and methods to have a reading that's for "distance until empty"
    so the only thing that would be the most accurate.. is "cruising range"... basically gives you an idea if you were ONLY cruising.. that's about how far you can get...
    throw in the hybrid system and real-life driving scenarios... and your true range will be obviously higher... though it's still not a good thing to get the fuel tank that low.
  11. StarBrite310
    335
    My regular Prius' always had an actual "distance to empty" and it seemed pretty accurate.
  12. rjdriver
    rjdriver Active Member
    411
    172
    Rhode Island
    Only had two fill ups so far, but "cruising range" went to ZERO on both tanks well before I was empty. Did't note the gallons on the first tank, but with the second, I had 2/3 gallon left when I "noticed" that it was at ZERO. The only reason I looked, was because that's when the last bar on the gas gauge started to blink.
    On both tanks, it seemed like the gas gauge took a very long time to start moving, and after it half a tank, the bars seem to disappear at a faster pace.
    Is it stated anywhere how many gallons should be left in the tank when the bar starts to blink? While the cruising miles left will always vary based on driving conditions, the gallons to empty should be consistent.
  13. kkim
    kkim Active Member
    386
    133
    kauai, hawaii
  14. dig4dirt
    dig4dirt MoonGlow
    1,153
    741
    Lancaster Co PA
    I just filled up first time today. Cruising range was actually at zero days ago.
    I do agree with the gauge going slow until halfway. I had two bars
    yesterday, and then this morning only one blinking.
    I filled it at the end of the day about 20-25 miles later.
  15. JoeVenture
    JoeVenture New Member
    On my second fill up it said I had a cruising range of 378 miles, and I actually went 496 miles before I filled up. The last bar started blinking around 485 miles, and I didn't want to take too much of a chance, but I pushed it for another 11 miles just to see. I've also noticed that the cruising range adjusts a little over the course of a tank of gas. I think it starts to gauge your average MPG on that tank and makes the adjustments to the cruising range number. I honestly feel the cruising range will become more accurate over the life of the car. I'm still within my first 1,000 miles.
