2012 Prius - With Lowering Springs and 17" Moda MD10 Wheels
Discussion in 'Gen 3 Prius Accessories and Modifications' started by g33kguy, Apr 21, 2012.
  1. g33kguy
    g33kguy Junior Member
    Virginia
    Spent the morning swapping out the stock springs for a set of Tein lowering springs along with a TRD rear sway bar. A few weeks ago I mounted the 17" Moda MD10 wheels.
    Handling in the Prius is much improved and the stance is looking much better. +1 :rockon:
  2. smokiejoe
    smokiejoe Member
    178
    30
    PA
    Very Nice...
  3. The Critic
    The Critic Resident Critic
    3,193
    2,321
    CA
    Looks nice. Be sure to get an alignment immediately and again in 3 months. The alignment changes quite a bit as it settles.
    MB860 ? 2
  4. g33kguy
    Virginia
    Thanks for the heads up on the alignment.
  5. dmkrueger
    dmkrueger Junior Member
    Wilton, NY
    Has it effected your gas mileage at all?
    iPad ? HD
  6. gmcneil05
    gmcneil05 Member
    118
    36
    Avon Park, Florida
  7. g33kguy
    Virginia
    Overall since upgrading to the 17" wheels, I've seen a drop in mpg of -4 mpg, after two fillups. Was averaging 48.5 according to the dashboard. Now we average 44.5 mpg. Not bad, I'll take the hit, enjoying the new stance and much improved handling.
  8. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Looks great. Gonna be installing my springs tomorrow. Not looking foward to removing the lower windshield trim
  9. F8L
    19,011
    4,081
    Grass Valley, CA.
    Looks great. :)
    How is the ride?
  10. cap160
    cap160 Older Member
    78
    Michigan
    Very nice look:)
  11. charlie_rivera1
    charlie_rivera1 Junior Member
    Palmetto, FL
    I had mine done as well and did not need any aligment at all. It all depends on how much the new lower springs drop you car. I installed Tanabe max comfort and it dropped the car only 1.0" in front and 1.1" back. I have Momo New 17" with Michelin LRR tires and I have seen a drop in MPGs. I use to get 56 MPG and now I'm seeing about 53. I was told that I need to wait for the tires to break in to start seeing better mileage.
    I forgot to tell you, nice look. You can see mine in the photo section titled " The transformation"
  12. F8L
    19,011
    4,081
    Grass Valley, CA.
    What were your alignment numbers before and after?
  13. charlie_rivera1
    Palmetto, FL
    I did not do it before and after. I had the car inspected after the installation was completed. I was a little bit nervous and had it checked at the dealer, since I have the maintenence package included and they also said that the car was still per factory specs.
  14. g33kguy
    Virginia
    The ride is much improved. Minimal body roll and the "sloshy" feel is now gone.
  15. g33kguy
    Virginia
    Yours looks great too! :D
  16. SuperchargedMR2
    SuperchargedMR2 Diehard Rams Fan
    673
    179
    Vancouver, WA
    It's very simple & not hard at all, took me about 10 minutes.
  17. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Did u remove it or just loosen it to get under it?
  18. NineScorpions
    NineScorpions Economy, Meet Style!!
    375
    64
    Very nice indeed.
