Choosing a sub for this car
Discussion in 'Gen 2 Prius Audio and Electronics' started by niteryder, Mar 6, 2012.
  1. niteryder
    niteryder Junior Member
    39
    Earth
    Well, I picked up my Prius about a month ago now and it was finally warm enough for me to install the sub amp. Honestly, this was the easiest amp install I think I have done to date.
    I currently run the stock JBL setup for now because I think it is decent for what it is. For the sub amp I run an alpine that does about 200Watts RMS @4ohms. I had an oldschool sub box (one of the many I made back in the day) with a 15" and 12" MTX in it, which completely drowned out everything. Even with the gains all the way down. It was fun, and it hit seriously hard. However, I am a long since retired bass head. For now, I have a pair of 6" woofers adding some low end, which will not last long because they are low wattage.
    I was thinking of taking the 12" out and just using that.
    Anyway, I was wondering what people were using for a nice well rounded sub that sounds good. Since this is my first "hatch back", any insight would be good.
  2. frodoz737
    frodoz737 Top Wrench
    4,734
    2,523
    33
    10" rear facing.
  3. F8L
    19,011
    4,083
    Grass Valley, CA.
    A single high powered 8" can work but with your wattage a single 10" works. I really liked my Orion XTR 12". It was very smooth compared to the last few JL subs I used in the same system.
  4. Kutanks
    Kutanks Member
    118
    MA
    right now im runnning 2 12' kickers in a ported box of an Alpine 500w monoblock
  5. Vinnyvalentine
    Vinnyvalentine New Member
    Maryland
    I have 3 twelves and 1500 watt amp and lights dont even dim when it hits badass
  6. bandogg
    bandogg Junior Member
    San Diego,CA
    I went with the JL audio CP 108LG W3v3, its max 250 rms and its thin enough to fit in the cargo area. Well all most thin enough, about 1/2 in over, and it sounds great.
    EVO 4g LTE ? 2
  7. phatcat
    phatcat New Member
    Washington
    I put in 2x 12" JL W3v2 powered by an 800watt Phoenix Gold amp along with a capacitor
  8. eyecannon
    eyecannon Junior Member
    LA
    pics please
  9. Daze
    Daze Prius C Owner
    92
    Utah
  10. maestro8
    maestro8 Nouveau Member
    471
    109
    nor cal
    I've got a 10" alpine sub in a tuned sealed box, just over 1 cu. ft. Paired with a 300 watt amp (I forget the make), it's more than plenty for a small enclosed cabin such as the Prius.
    It's amazing how much better a single speaker sounds when it's in a properly tuned enclosure! You don't lose response at certain frequencies like you do in a generic enclosure.
    Find the factory spec. sheet for your subwoofer; it should tell you the optimum enclosure volume. If you don't know how to do this, find a local independent shop (not a chain!) to do it for you. It's worth the $100 or so they'll charge for a custom enclosure!
  11. C25A1guy
    C25A1guy Junior Member
    35
    Northridge, CA
    Although it is not in my Prius, I've been using Image Dynamics IDQ subs for YEARS and is probably the best sub I've ever used (even got me placed at the regional IASCA finals a few years back with my Ridgeline). It runs fine on 200w RMS (heck, you can probably even run lower, it's such an efficient sub), doesn't require a whole lot of air (on the small side, I think you can get away with as little as .75 cu ft w/ polyfill).
  12. johnnyP13
    johnnyP13 New Member
    Did you add a second battery? or what because im about to put a 1300w rms system in my 08 prius please help
