Dash Clock Loosing 1 minute Per Day???
Discussion in 'Gen 3 Prius Audio and Electronics' started by Hank101, Apr 30, 2012.
  1. Hank101
    Hank101 Member
    108
    SC
    Any ideas as to why this would happen on a new 2012 Prius II?
    Thanks
  2. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    Interesting mine seems to gain a minute every couple of months.
    Posted from my iPhone via the Tapatalk app.
  3. Tech_Guy
    Tech_Guy Class Clown
    868
    123
    Silicon Valley, CA --- Land of Fruits & Nuts
    You're driving so fast that time is running backwards???
    Keith
  4. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    lol, it's all that speeding near 88 mph eh? ;)
  5. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    I have to adjust mine a couple of minutes every few months. I have never bothered to remember whether it was forward or backward.
    The next time you are at the dealer show it to them. If some way you can take a dated picture one day and then a second dated picture the next day then you can verify it for them.
  6. Tech_Guy
    868
    123
    Maybe a bit faster than 88 mph, like something closer to the speed of light (~186,282 miles/sec)
    (That is fast enough where the red stop lights appear green as you approach them.)
    Keith :)
  7. prius2010II
    prius2010II Member
    269
    us
    Which is more likely? A Prius driving at the speed of light or a flux capacitor equipped Prius able to break the time barrier at 88mph?
  8. fuzzy1
    10,583
    That is a 700 ppm error on the clock crystal. It is defective, as even a very cheap crystal should be within 50 ppm (parts per million).
  9. blane
    blane Carmudgeon
    98
    56
    NJ Suburb of NYC
    2019 Prius
    At least there is a "00" button to zero out the excess minute when you press it on the top-of-the-hour radio station time signal.
  10. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
    Mine gains almost a minute a month. I brought this up when it was under warranty and they "checked it" and said it was not off by enough to replace under warranty. This is something I would expect from a clock in a car in the 70's but not in 2010, or 2012. Lowest bidder for parts?
  11. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    So at what altitude are you driving? It's a known fact the further you get away from Earths Gravity Well, the passage of time changes, relative to Sea Level on the planet!
  12. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    I adjust my clocks twice a year, whether they need it or not.
  13. Big Steve
    Big Steve ramblin wreck
    402
    39
    Richmond VA
    A chip that can not keep time for a 24 hr period is scary as the timing signal for everything else the electroincs in htis car do.
    Are you sure it is the car and not the time source you are comparing it to?
  14. Eoin
    Eoin Active Member
    593
    116
    Long Island
    On the bright side, a stopped clock will be accurate twice a day.
  15. KK6PD
    4,003
    946
    118
    The clock chip that the clock uses is self contained, does not accept any time synchronizing or external reference. The clock chip timing is usually set by a quartz crystal and a capacitor, sometimes adjustable. In this case I would think the crystal is out of tolerance, or the cap is not the right value.
    The only way to fix this, is 1, take the clock apart, see what clock chip they use, look up the data sheet for that chip, figure out what they are using for reference. Repair, replace components as necessary. Or 2..
    Now we all know that NO dealer anywhere is going to go to that extreme to fix the clock. They are just going to pull a new clock unit off the shelf, and replace the defective one. Assuming you find a sympathetic ear, and a Service Manager who thinks losing a minute a day is worth the efforts to swap out the clock! Of course you have to prove the clock is bad, and out of tolerance.
    At this point I will say good luck, you might just have to bite the bullet and live with it, or buy a clock replacement yourself and do your own swap out!
    Let us know how it goes! :D
  16. tach18k
    tach18k Member
    406
    SoCal Beach Area
    Havent seen and issue with my clock, seems spot on....
  17. Big Steve
    402
    39
    Richmond VA
    Understood that the clock is separate, just hope the rest of the electronics are better designed and implemented.
  18. KK6PD
    4,003
    946
    118
    I would think so, I would imagine the clock is outsourced to a third party supplier!
  19. Big Steve
    402
    39
    Richmond VA
    Let us pray! ;-)
  20. qbee42
    3,079
    And is shockingly inexpensive. Even as an electronics designer, I am continually amazed at the low cost of these mass produced items.
