air temp on muti display
Discussion in 'Prius c Main Forum' started by xerox6135, Apr 24, 2012.
  1. xerox6135
    xerox6135 Member
    170
    94
    michigan
    Does the air temp display on the multi display on the dash when you use the steering wheel or do you need the nav system for this to work I have done everthing and it does not work I do not have the nav system what am I missing here any help would be great:(
  2. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
    You need to select the "Drive Information" screen.
    It is the one right before the eco screen ( i think)
    Then, at the bottom there is the cruising range and then very bottom, the outside temp.
  3. hnx676
    hnx676 Junior Member
    Singapore
    Do you want to display the outside temperature? just slightly touch the air circulation mode select button on the right touch tracer will display the current outside temperature and also the current temperature setting of your air conditioning.. They are on the multi info display...
  4. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
  5. sph101
    sph101 Prius 4
    156
    92
    32
    Brevard, NC
    2018 Prius
    you can also just tap the temp button on the steering wheel and the outside temp will be displayed.
  6. SquallLHeart
    SquallLHeart The Techie Guy
    826
    247
    San Jose, CA
    if you have a 3 or 4 anyway..
  7. xerox6135
    xerox6135 Member
    170
    94
    michigan
    Ok I only have a 2 so thats why it does not work thanks for all the info you guys are the best
  8. WX4GPS
    WX4GPS Junior Member
    64
    TMMK Georgetown KY
    Yeah I could not get it to work on my 2, but saw it shown and I don't recall saying you had to have a certain trim level.
  9. SquallLHeart
    826
    247
    San Jose, CA
    it's part of the touch tracer feature.. which is only on the 3 and 4.
  10. south central
    south central Member
    100
    south central Illinois
    Yup, just like dig4dirt said, on the Prius c - trim 2, the outside temp in only displayed in one screen, "Drive Information" at the bottom.
    Deb
