Most of the Neighborhood Spent the Day without Power
Discussion in 'Gen 3 Prius Main Forum' started by Southern Dad, Apr 29, 2012.
  1. Southern Dad
    Southern Dad Active Member
    350
    212
    58
    Monroe, GA
    One of the disadvantages to living in a rural area is when someone strikes a utility pole on a Sunday, the electric will be out for hours. A good time to own a Prius. :rockon:
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    So what did you run off the car? What kind of inverter?
  3. Southern Dad
    350
    212
    58
    Monroe, GA
    I have a gas guzzling 2003 Lincoln Navigator sitting out in the yard. Since it is often used on trips, I purchased a 400 watt power inverter. I quickly removed it from the back of the Navigator and put it in the Prius. It works very well. And 400 watts is more than an enough to operate one of our televisions, a fan and a Blueray player.
    My Internet already has its own battery back up which will last about 10 hours. It doesn't draw much for a cable modem and wireless router.
  4. ralleia
    ralleia Active Member
    386
    137
    Omaha, Nebraska, United States
    Interesting...
    So maybe we should keep that '94 Chrysler V6 when we go to buy the Prius? The engine is still sound.
  5. El Dobro
    El Dobro A Member
    7,093
    3,271
    Yep, that's why there's a power inverter sitting out in the garage, waiting for the day the power goes out again. :D
  6. ProximalSuns
    ProximalSuns Senior Member
    1,877
    PNW
    Good time to own a 2,000 Watt Honda generator. Using a car's 12V power ports not very efficient. With Prius small 12V battery, probably not a good idea to running 1-2kw of power through it and the power port.
  7. rcf@eventide.com
    173
    85
    Sedona
    You can use a high-power inverter with the Prius traction battery to power your house, and it will be recharged by the Prius ICE as necessary. See PriUPS.com
    Richard
  8. ProximalSuns
    1,877
    PNW
    Like I said....better a nice quiet 2KW Honda generator vs. blowing up your car or yourself messing with high voltage batteries.
    Now my Escape Hybrid had a 1KW 120V plug in the console. Never used it but cool to have. I'm sure Toyota looked at it, saw extra cost, extra weight for little used feature and bagged it.
  9. qbee42
    3,081
    The Prius is a lot safer and more efficient generator than the Honda. I can't say that I agree with your assessment, although the Honda has the advantage of being an off-the-shelf solution.
  10. ProximalSuns
    1,877
    PNW
    Jury rigging high voltage Prius batteries vs. a nice quiet 2KW Honda from Home Depot?
  11. Southern Dad
    350
    212
    58
    Monroe, GA
    I just wanted enough power to keep the TV on. We had a 3-year-old over who really wanted to watch Diego. I needed the fan to keep us cool.
    The Prius did very well. It started a few times on its own and kept the power going.
    The Lincoln still has its uses. I often find myself transporting a gaggle of 9-year-old girls to activities. It does haul seven plus gear.
    iPad ? HD
  12. NargilFenris
    NargilFenris Junior Member
    75
    Wherever Uncle Sam sends me
    Genuis. Will have to remember that the next time Westar claims a "squirrel" knocks out the power.
