Prius Gas Tank Drawings in PDF Format
Discussion in 'Gen 3 Prius Fuel Economy' started by Solarman44, May 2, 2012.
  1. Solarman44
    Solarman44 Junior Member
    78
    Largo, FL
    There has been many asking about the dangers of over filling the Prius. Until now it was hard to find any information about the problems this might cause.
    I found a site with a PDF file that might help everyone who might like to find out more, here is the site:
    http://autoshop101.com/forms/Hybrid13.pdf
    It has plenty of drawings and pictures say a thousand words. Let us all know if this helps.
    Cheers,
    John
  2. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
  3. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    I may be wrong here but I believe that the 2009 gas
    tank is entirely different than the 2010 Prius.
  4. MattPersman
    MattPersman Member
    110
    33
    Indiana
    It has been said many times and this goes for all gas engines with EVAP emmisions components, you can have liquid fuel go where it does not belong if you try to overfill. can this damage components over time? sure. will it? maybe.
    you could get liquid fuel in the canister and the purge solenoid could pull it to the intake and cause a driveability issue temporarily, i have seen this on vehicles i work on (not toyotas) when a component fails on the tank and the customer fills up it will overfill slightly and put liquid fuel in the vapor line.
    the symptom is typically "dies when coming to a stop" (because too much fuel is getting added when unneeded by the purge solenoid) our vehicles are different and you may never even notice the symptom being as our engine will shut down on its own coming to a stop and this only lasts a short time and in city driving until all of the liquid fuel evaporates or is sucked through the vapor line.
