Shark fin installed on my blizzard pearl "v"
Discussion in 'Prius v Accessories and Modifications' started by Mike500, May 3, 2012.
  1. Mike500
    Mike500 Senior Member
    2,593
    764
    It was easy. It was 90 degrees outside, yesterday,
    And, it gets clear reception. It sure looks better than the "rubber duckie."
  2. Rh0
    Rh0 Junior Lurker
    33
    N. CA
    Beautiful! How is the color match? I am thinking of doing the same thing. I assume this is the item in the PriusChat shop? There are no instructions for installation. What does installation consist of? Thanks!
  3. Mike500
    2,593
    764
    Yes, it's the same antenna sold by Priuschat shop. It's actually made in Canada by Visual Garage. I got mine in 10 days delivered from the date that I ordered it. The color match is good. It looks a little lighter, because my car is dirty wilh pollen dust. The painting is superb.
    Here's a link to the installation instructions;
    VG Shark Fin Antenna - Installation
    Cleaning the mounting surface and aligning it took more time than the actual installation.
    THANK you for your interest.
  4. hyperion666
    hyperion666 New Member
    Montreal, Canada
  5. Mike500
    2,593
    764
    :welcome:
  6. macmaster05
    macmaster05 Senor Member
    4,050
    729
    I don't know why more people don't buy this product. It's one of the best 80 bucks I ever spent.
  7. bagwell
    bagwell Active Member
    592
    49
    the woodlands, tx
    looks great!
    IMO tho, the shape is a little funky.
    Still much much much better than the standard antenna.
  8. btcompute
    btcompute Junior Member
    46
    Central NH
    Mike, did you replace the original antenna to change the look of the antenna, or did you have poor reception with the stock one?
    Just wondering how the reception compares to the original antenna.
  9. Mike500
    2,593
    764
    The reception is about the same. I can't tell the difference. The "rubber duckie" had an internal coil about 8 inches long. The shark fin antennal is acuually a "square wave" zig zag pattern ablout 5 inches long printed on the right side of the inside of the sharl fin.
    Both of them are 1/4 wave ground plane antennas with a total length of about 27 inches. They are made complact either by winding it into a helical coil in the "rubber duckie" and a "square wave" in the shark fin.
    I'm sure that a vertical mast rising 27 inches above the toof would have better reception, but the shark fin is effectively the same, performancewise, as the "rubber duckie."
    Hiope this 'splains it clearly. And, NO, I didn't have poor reception.
  10. ProximalSuns
    ProximalSuns Senior Member
    1,877
    PNW
    Thanks on that. Good to know on the reception.
    I got a black one for my Blizzard Pearl. Fits the black/white look of the car with the black room and back hatch. Waiting to put it on.
  11. maverickf
    maverickf New Member
    113
    Southern California
    I definitely want to see how they match. :D
  12. Guill
    Guill Member
    165
    Italy
    Looks great Mike! I installed a Shark Fin on my V about 2 months ago and it's performed great. No issues with reception--works perfect!
  13. skwcrj
    skwcrj Member
    278
    68
    Gig Harbor, WA
    Before installing my Sharkfin antenna, I checked the difference in reception between the OEM antenna and the Sharkfin antenna using a distant (weak) FM station and noticed no difference at all. The paint matching is perfect.
  14. joeruo
    joeruo Junior Member
    25
    boston ma
    Does the shark work well with sat radio and also the nav system?
  15. LEGO9V
    LEGO9V New Member
    Connecticut
    The shark fin antenna has nothing to do with the sat radio or the navigation system!
