PIS 10kw conversion or new PIP?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Coyotefred, May 2, 2012.
  1. Coyotefred
    Coyotefred Member
    132
    31
    Western Nebraska
    These are some very strong points. I guess some of it comes down to whether they outweigh the significant EV range improvement you'd get with the 10kwh kit.
    How likely is it we'll see some kit of kit/range-extender for the PiP in the near future?
  2. mitch672
    mitch672 Technology Geek
    1,077
    198
    Randolph, MA
    Very likely, as all of the conversion companies will see additional EV range as the "low hanging fruit" on the new PiP, it should be less complex, and work better, to add EV range to a system designed to operate as an EV.
    Also, it's likely what little business they do have, is going to dry up, so they will be looking for additional opportunities for their products.
    I know there are people also working on this for the Nissan Leaf as well, and it could make even more sense on the PiP.. Of courses the additional weight has to be factored in, as well the rear springs might need to be beefed up as well.
  3. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    The guys(s) from Enginer were on here a few months ago looking for adventurous PiP owners to test out a range extender pack. I havent heard anything about it since though.
    Here's the original post:
    http://priuschat.com/forums/toyota-prius-plug-in/104338-enginer-range-extender-pip.html
  4. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    I still wouldn't consider buying an 08 + aftermarket conversion route over a PiP for the same price.
    Have you driven a regular 2nd gen, 3rd gen and a PiP? I have. I can't speak to the conversion you refer to but the ICE (intentionally) fires up w/not very hard acceleration on unmodified 2nd and 3rd gens. Also, on 2nd gen, at >~41 mph, the ICE must spin. On 3rd gen it's 46 mph.
    On the PiP, you can drive in electric only up to 62 mph and it's calibrated to not fire up the ICE unless you accelerate MUCH harder. See http://priuschat.com/forums/toyota-...mph-electric-vehicle-acceleration-videos.html. The ICE has turned on when the EV car icon on the right side goes out. There's NO way you can accelerate that hard in EV only on an unmodded Gen 2 or 3. Certain plug-in kits like Enginer do nothing to change that threshold. I don't think Hymotion could either (and it's Gen 2 only).
  5. drinnovation
    drinnovation EREV for EVER!
    2,027
    586
    65
    CO
    Neither the Volt or Prius is an SUV, but both are PHEV which I think is important for long trips. Both can haul some pretty big things with seats folded down.
    Biggest things I've hauled in the Volt were boxes of foam core, which measured 36x40"x60" foam core plus bunch of equipment for the conference. Its easy to get the back totally flat. Still We use the subaru for dirty things like lumber and rocks but I know many of them would fit but I don't want risk my nice new Volt. I would be more willing to carry junk in a old prius :)
    Good thread on hauling stuff in volt at
    Hauling stuff in the Volt
    and
    At the Lumberyard
  6. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    the range extender for the PiP has got to fit in the storage hole between the PHV batteries and the bumper. if it's designed well. it could fit 4 KW there.
  7. mrbigh
    3,686
    699
    Long Island, NY
    I approached Enginer with an email directed to Jack the "owner" and after a few days received a replay by one of their helpers.
    Upon some chinglish translations I understood that the company will provide a slim monetary discount on the purchase providing that I will supply a months worth of data, installation progress photos and "free advertising on the forums".
    That offer it's NOT up to par being that I will risk my NEW vehicle for experimenting and more likely to F**k-it up with their components.
    Sorry, I can not be their guinea pig at that cost.......but things could change if the company would change their position and donate their equipment for their own technical benefit.
  8. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    Personally, I wouldn't shell out big bucks like that for an upgrade like that unless I had a lot of money to burn or I was a serious hobbyist.
    I took some risk in buying my PiP, because it's new, etc, but the car's fully supported by Toyota, the battery warranted to 150,000 miles, etc.
  9. Coyotefred
    Coyotefred Member
    132
    31
    Western Nebraska
    No, I haven't had a chance to drive/compare this Prii... This is a pretty significant difference.
    I guess I've always been reluctant to buy new since you lose so much value so quickly, but maybe it's time to treat myself to a new vehicle for once :)
    From more that I've read since I originally posted I have some real concerns about the PIS conversion kits at this point, so I think that's off the table.
    But what about a Gen 3 with the Enginer 8k kit? I'm still a little confused after reading Enginer's website/user manual materials. Enginer talks about a "Mixed (EV) range of 80 (40)" for their 8KWH kit. But this doesn't mean a 'forced' EV mode where I'd get those 40 miles right...I'd only get them if I were staying below 46mph. So you'd be golden if you had 40 "in town" miles, but not so useful if you were doing highway miles... But isn't Enginer implying that you're still going to be able to be using that "EV"...just not as "pure" EV but as part of the hybrid "mix" ?
  10. cwerdna
    12,544
    2,124
    SF Bay Area, CA
    I'm no fan of aftermarket kits and am confused as to why you are so set on getting one. Please see my post at http://priuschat.com/forums/prius-p...4971-hymotion-issues-enginer.html#post1342017 and the links there about Enginer.
    I don't think the Enginer kit can do anything about the EV speed limit nor do anything to adjust how easily the ICE turns on in response to the accelerator pedal.
    cproaudio used to have an Enginer kit but doesn't any more. I don't know the details.
    It seems Hymotion (doesn't work on Gen 3) was the most reliable but even TheForce had the problem at http://priuschat.com/forums/prius-p...-battery-dead-rip-almost-3-years-service.html. Now per Hymotion :: Enabling the new generation of hybrid owners to maximize their fuel efficiency, they've gotten out of that business.
    I don't know your background (for all I know, you're an accomplished EE) but frankly, from the questions you're asking, I don't think something as (apparently to me) hacky as Enginer is for you. You really should drive a regular Gen 3 then try a charged PiP.
    BTW, Priuses that weren't sold as PiPs aren't EVs and weren't designed as such. You're likely going to run into quirks like the ICE wanting to start up once it gets too cold (from not running). People have devised stuff like http://priuschat.com/forums/private-sales/60906-coolant-temp-hack-better-mpgs.html, http://priuschat.com/forums/gen-ii-...-automatic-coolant-temp-hack-better-mpgs.html and http://priuschat.com/forums/gen-iii...s/76906-yet-another-thermistor-hack-gen3.html.
  11. Erikon
    Erikon Active Member
    819
    105
    Rochester, NY
    What I posted in the C forum works here too!
    "The Engineer kits don't really turn the Prius into an EV, they keep the traction battery charged so the ICE doesn't have to work to charge it, and allows you to run on battery only longer but under the same limitations (speed, temp, etc). Too pricey currently for what they do, plus I get nervous with anything that comes with a fire extinguisher!"
  12. Coyotefred
    Coyotefred Member
    132
    31
    Western Nebraska
    I'm no EE, and I think you're right on your observations...
    The reason I'm exploring the add-on conversion option was that as a teacher helping to financially support an older parent, I need to be careful with my spending, and you obviously pay a premium buying new with the off-the-lot depreciation, higher sales tax, higher insurance, etc. etc.
    The original reviews I was reading was that the PiP is basically a nice Gen 3 with a meager 4kwh EV add-on--for which the buyer was paying a hefty premium. If that was the case, I thought it made sense to get that same "package" with a used Gen 2 or 3 with an aftermarket conversion and not pay those "penalties" of buying new.
    But as several helpful responses have pointed out, it appears the PiP isn't just a Gen 3...and certainly no Gen 2. And perhaps just as significantly, at least right now these conversion kits seem to be a real gamble. Some folks have obviously made them work without a great deal of 'tinkering'...others it has obviously become a major 'project.' While I'm happy to 'tinker' a bit to make one of these work (I've done some home automation and basic solar/wind mods/installs and enjoy that), I definitely don't want a 'project'...
    So I think if I'm wanting to get something now (as opposed to say waiting for a used PiP market to develop), biting the bullet for a new PiP is probably the wise choice. I've never purchased a new car so some of this is probably just some financial "cold feet" so to speak...but maybe this is a good opportunity to bite the bullet and enjoy that new car smell ;) I feel strongly that if we are to move the auto industry more in the direction of efficiency and better energy sources/alternatives, folks have to step up and support that financially to show that there's a market worth continuing to invest in...
  13. sub3marathonman
    sub3marathonman Active Member
    557
    75
    Much of what cwerdna said I would agree with. I would not consider an enginer kit, now Hymotion is out, and the one that sounded promising (PIS) is sounding a bit questionable. The one possibility that hasn't been discussed is the bms+ system, which mrbigh uses, and some others too, with satisfactory results. The benefit to bms+ is it can be installed in stages. I have no first hand experience with the kit though.
    But, instead of trying to work around the limitations of any Prius, why not consider all electric and go with a Leaf. I think, after all the tax credits and Toyota dealer "market adjustments" you would be at the same price or even less. I am certain if you went with a Leaf SV model you'd end up paying less. You might have to lease first, then pay the lease off, but it can be done. You might even find a 2011 demo and come out far ahead.
    In the initial post it stated that some days were 50 - 70 miles of highway driving. The Leaf should be able to do that, especially if there is the opportunity to recharge a bit during the day. If it is 50 - 70 miles each way, that would be difficult, but possible if there is access to a 240v EVSE.
  14. hill
    8,836
    from the "Plugin-Supply" web site:
    Max Electric Speed72 MPH
    Plug-In Supply | Plug-In Conversions for Prius and Escape
    I've gotten very good feedback about those folks and am considering their product for our Lexus SUV hybrid.
  15. drinnovation
    2,027
    586
    65
    CO
    That's clear. Then it just that the OP said boulder hybrid conversions.. which mus not be using the PIS units as the BHC page says 52mph.
    Curious what the impact on reliability will be at 72mph. but that is faster than the Pip so maybe be interesting for the OP if they have highway stuff to do as well.
  16. cwerdna
    12,544
    2,124
    SF Bay Area, CA
    Be careful w/demo models if buying. You'd want to make sure it's not being sold as a used car, which wouldn't end up qualifying for any tax credits ($7500 Federal tax credit and any state incentives/rebates). I don't know all the details, but consult the folks at Nissan Leaf Forum - Online forum for the Nissan Leaf Electric Car.
    From http://www.mynissanleaf.com/viewtopic.php?p=101293, 50-70 miles of highway driving should be doable in a fully charged Leaf if the OP does the stated 50-55 mph. Be careful about hills though. http://priuschat.com/forums/freds-h...elevation-profile-route-between-2-points.html can help.
    Seriously though, if money is tight the OP is concerned about all the extra costs of buying a new car, esp. a PiP (since it's quite pricey), the OP ought to just look into a '12 Prius liftback (aka regular Prius) lightly equipped like the model Two or Three or a used '11 or '10. A used 08 or 09 is a possibility but the 3rd gen is overall a superior car.
  17. Coyotefred
    Coyotefred Member
    132
    31
    Western Nebraska
    Yes, the Leaf is what I first considered and it's still a close call. On the one hand, as you say, financially it's close to equal if I go the "lease and buy out" option on the Leaf. Also, I really like the idea of an all-EV vehicle and supporting a bold move like Nissan's, and of course being able to drive so much in EV mode.
    On the other hand, it's a 1st generation vehicle, with all the uncertainties (and of course excitements) that come with that. Being an all-EV system I would expect good reliability there, but the batteries, electronics, etc...who knows... Warranty support is there for both but in my rural area, I'm 4 hours away from a market with service for either one at this point. The Prius of course has already established itself through several "generations" as a reliable, energy-efficient choice even before adding the plug-in EV capability.
    Finally, it seems like I'd get end up getting more use out of (and obviously no range anxiety-related stress using) the PiP. I can use the PiP for probably 90-95% of my driving (I have my old Jeep for bad snow/mud conditions), whereas I'd probably only be able to use the Leaf for around 75% since one of my longer regular trips of around 65 miles one-way doesn't have electricity, and where I live and drive/vacation there aren't convenient charging stations to be found, so using the Leaf as a 'vacation' or 'weekend' car would likely be out of the question...
