Neat and Obscure facts about the PiP
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by 9G-man, Apr 18, 2012.
  1. John in LB
    John in LB Life is good
    399
    27
    Orange County
    Interesting, I just nice person-U-Med it to be a defogger. Will confirm the next time I defog my rear window...
  2. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    The hood has TWO places to insert, one for high and one for very high, almost vertical! Impossible for MOST people to hit thier heads.
  3. Allannde
    Allannde Just a Senior
    874
    138
    Washington State
    Yep:
      File size:
      96.9 KB
      1,277
  4. andyprius
    2,212
    188
    A major improvement over my 2005, the height is now 1-2" higher, I can now clear those stupid parking cement blocks! My 05 looked like beavers had been chewing on it. :D
  5. ultraturtle
    108
    81
    Peachtree City, GA
    After scratching my head for a week trying to figure out why the A/C button on the remote would not turn on the air conditioning as I approached the car, I took the unmanly action of actually reading the manual.
    Loving the car's feature of turning off whatever headlights you use when powering down, my initial habit had been to leave the Headlight Switch in the Daytime Running Lights on position. Turns out, they must be off in order for the remote A/C function to work. While it does not appear to be a hard requirement in the initial system operation description, a later section states "The Remote Air Conditioning System may stop operating temporarily if other features that use electricity (for example, the seat heater, lights, windshield wipers) are in operation or if the charge level of the 12-volt battery becomes low."
    Operating conditions
    The system will only operate if all of the following conditions are met:
    The shift position is in P.
    The “POWER†switch is OFF.
    All doors are closed.
    The hood is closed.
    The brake pedal is not being depressed.
    When leaving the vehicle
    Check that the headlights are switched to either off or “AUTOâ€.
    Check that the wiper switch is turned off.
    Check that all windows are closed.
    4 people like this.
  6. ThatTallGuy
    ThatTallGuy Junior Member
    67
    Southern NH
    I believe it's a defogger. It's in the driver's line of sight to a blind spot; the one of the left side is not.
  7. Chris Allingham
    Chris Allingham New Member
    San Jose
    Anyone notice there's a little spotlight on the ceiling that shines down onto the shifter knob? Only visible at night. Kind of a neat little effect.
    Regards,
    Chris
    MarkPressey likes this.
  8. CharlesH
    2,797
    1,163
    Roseville, CA
    Our Honda Pilot has the same thing. (You can do lots of things with a Prius, but hauling an RV trailer is not one of them.)
  9. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    The power windows actually slow down as the glass nears it's up and down limit, so they don't bottom or top out with much force. That's cool.
  10. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    I have always have my headlight stalk switch in the DRL mode, and I had no problem activating the AC via the remote key fob. I did multiple tests to make sure.
  11. radiocycle
    radiocycle Active Member
    550
    78
    Vallejo, CA
    I knew this... only because I was looking for a place to put a decal that I like but I didn't want to put it on the defogger wires. I was going to put one on each of the rear side windows until I saw that. You beat me to listing it in here though :eek:
  12. crewdog
    crewdog Acting Ensign Prius Prime
    493
    388
    Woodstock, GA
  13. plugable
    plugable Junior Member
    59
    Rancho Cordova, CA
    The following link indicates that there is an in-glass AM/FM antenna in addition to the roof-mounted antenna, so I'm voting that it's an antenna!
    2012 Toyota Prius Plug-in Hybrid Models
  14. bfd
    bfd Plug-In Perpetuator
    659
    172
    Close to SDSU in the Far Southwest Corner of Cali
    The Emergency Response Guide revealed several items I'd overlooked!
    Cool!
    1) Lumbar support…
    2) Telescoping steering wheel. (I'd noticed the vertical adjustment, but not the Z axis!)
    Since my Gen II had neither of those features, I didn't even notice until I read this! (And yes, I did RTFM! - It's on my iPad in PDF form.)
    These are the kinds of surprises I like.
  15. wmmmmm
    wmmmmm Junior Member
    53
    SF Bay Area
    I give up. Where is the Lumbar support? Is it adjustable?
  16. bfd
    659
    172
    It's the circular button.
    Yes, it is adjustable!
  17. wmmmmm
    53
    SF Bay Area
    How about that! I had go to try it out and it works. I was thinking about getting a support but now I won't have to!
    And I also read (skimed) the entire manual but missed them.
  18. mrbigh
    3,686
    699
    Long Island, NY
    Lumbar support is also available in the base package to?, I do not recall seeing a round knob in mine but I could also be wrong......
  19. janie
    janie 2016 Prius 3 Touring
    175
    42
    Three Touring
    No lumbar support on the base package :(
  20. bfd
    659
    172
    Or - It's an EXPENSIVE upgrade on the Advanced pkg.
