Mfd display not working is anyone selling one? Ill include more info
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Vinnyvalentine, May 3, 2012.
  1. Vinnyvalentine
    Vinnyvalentine New Member
    Maryland
    Its a 2007 9 speaker jbl no nav display model number is 86110-47210 can anyone help me only part of the touchscreen works and its getting worse I have to use the steering wheel to control everything which I dont mind problem is my speakers are all faded to one side and I cant get it back is there a way to reset to facory settings I have removed the unit and would like to buy another on just not trying to spend the 400 I have gound the for anyone help please
  2. jdenenberg
    jdenenberg EE Professor
    3,953
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
  3. dann707
    dann707 Junior Member
    ca
    I have one for sell for $200..
  4. Vinnyvalentine
    Maryland
    sounds goos are you sure that it works and how much will shipping be? im in annapolis md
  5. Vinnyvalentine
    Maryland
    atre you also sure it is same model number with 9 speaker and no nav?
  6. Vinnyvalentine
    Maryland
    07 prius display not working more info ioncluded
    only half the screeen works when i touch it everything else works fine seems i only need the screen itself my ? is can i just replace the screen with any model number and keep all the guts of mine or do i need to buy the whole unit with proper part number i was thinking i could just replace the screen itself please help me out or if someone has a 86110-47210 for a decent price let me know.... my model is the second most expensive and i found a unit for 50 with differnt part number and just want to use sreen will this work??
  7. jdenenberg
    3,953
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Vinny,
    Ask Steve at AutoBeYours.com about interoperability of the different model MFDs. He is generally very helpful.
    JeffD
  8. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Had the exact problem on a 06. Give your dealer the VIN so you can get the correct part #, as there are many of them. I got one off eBay from LKQ for $450 and it was from a newer model year.
