Service Engine Light
Discussion in 'Prius v Technical Discussion' started by danbob, May 7, 2012.
  1. danbob
    danbob Junior Member
    36
    Westchester NY
    Just like the title says...Start up, light flashes four or five times, then goes away....Anyone have this happen to them yet? Our car is 3 months old with approximately 4500 miles on it. Is this just a maintenence reminder because it is coming up on 5k miles, or is something not right here? Just got 46mpg hand calculated with the car loaded to the gills with stuff and a bike rack on the hitch so I would be surprised if anything was actually wrong.
  2. Econ
    Econ Member
    329
    26
    East of the Berkshires - MA
    Make sure you gas cap is on tight.
  3. gmcneil05
    gmcneil05 Member
    118
    36
    Avon Park, Florida
    My 05 just started doing that and I'm 80 miles away from 5000. I guess your right about it being a early reminder.
  4. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,517
    Santa Fe, NM
    Yes, this is what a Toyota does. After the 5000 mile mark, the light will stay on. Now would be a good time to check your oil, if you have never done that.
  5. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Yes it is the early reminder. It will flash at startup when 4500 miles has been reached since the last reset. At 5000 mile the light will stay on until reset. Then the 5000 mile starts again.
  6. danbob
    36
    Westchester NY
    Thanks so much for the info guys. SO does this mean that every freekin' 5k this light is going to go on? a bit annoying if you keep track of your maintainence
  7. JACoH
    JACoH Enjoying the mileage
    193
    40
    Oregon
    Check your oil, rotate your tires, and reset the reminder. Instructions in the manual, very easy, page 354.
  8. Quentin
    Quentin Member
    335
    West Virginia
    It will only be annoying if you don't do your appropriate service at every 5k miles. ;) It is a friendly reminder to people like my brother who will drive a car until something breaks before he decides he needs to do some work on it.
  9. syscon
    syscon Member
    329
    43
    Edm. Alberta
    Maybe USA manual provide instructions how to reset the engine light but Canadian Manual does NOT contain any instruction as to how to change the oil or reset the engine light.
    Page 354 "Reset Maintenance Data (USA only)"
    Doesn't this procedure works on Canadian Models? If it does why would they put "USA only"
