2012 Toyota Prius C – Easter Eggs
Discussion in 'Prius c Main Forum' started by Shibby, May 6, 2012.
  1. Shibby
    Shibby Member
    78
    43
    Hagerstown, MD
    This list is by no means comprehensive. Please post anything you discover and I'll add it to the original post and give you credit.
    Exterior
    1. Vortex generator/drag reduction locations – Headlights, Front turn signals, Base of Side Mirrors, Taillights
    Headlights
    Front turn signals
    Taillights
    2. Clear Bra strip at the curve of both rear doors
    3. Rear bumper diffuser
    4. Hood prop has two locations. First location is a standard angle; second location is ~90 degree angle.
    5. Black sticker between doors to maintain black color between door trim
    Interior
    1. Center console armrest is adjustable forward (pull hard)
    Normal
    Forward
    2. Rear outside seatbelts are storable when not in use
    Incorrectly stored
    Storage latch
    Correctly stored
    3. Center seatbelt is storable when not in use
    In use
    Release switch. Use the seatbelt latch to undo.
    Storage location
    Correctly stored
    4. USB/Aux Cable routing guide
    Electronics
    1. Outside temperature and current temperature is accessible by lightly touching the Re-Circulate/Fresh air button on the steering wheel. (Available on 3 & 4)
    Press here lightly
    Displays on MID screen
    Entune
    1. Presets are configurable in any order regardless of Source.
    1st four presets are FM, 5th is Sirius/XM, 6th is AM
    12 people like this.
  2. R11
    R11 New Member
    101
    17
    Portland, OR
    Can you reach the wheel with your right fingers at all if your elbow is on the front edge of the center console armrest?
    ron
  3. Shibby
    Shibby Member
    78
    43
    Hagerstown, MD
    I would say that you could hold the wheel position, but it'd be difficult to steer with any precision. Probably fine on the highway, which is what I feel you're asking...
  4. SquallLHeart
    SquallLHeart The Techie Guy
    826
    247
    San Jose, CA
    obviously the touch tracer and entune are only applicable to the packages that have them..
    also, the front headlights and the turn signals have those raised areas not for aerodynamics.. but for visibility.
    i wouldn't really call these "easter eggs"... you're just listing off informational stuff that most would otherwise figure out... i would moreso classify.. holding the trip button while the odo reading is displaying as an easter egg..
    even though that information is in the owner's manual..
  5. Daze
    Daze Prius C Owner
    92
    Utah
    Thanks for the post! I'm sure everyone learned at least one new thing from this. I had no idea there was a storage area for the rear right seatbelt! Thank you
  6. Shibby
    Shibby Member
    78
    43
    Hagerstown, MD
    I'd be interested in reading more about this. Visibility for what? Increased light output in some manner?
    I don't think there are any true easter eggs in our cars, but if this thread helps people notice/realize things that they wouldn't otherwise, I'm okay with it. :)
  7. Tideland Prius
    16,499
    This should be helpful for newbies! Thanks!
    I would say the turn signal one isn't for aerodynamics but so that the amber light is more visible from the side.
  8. Wharfe
    Wharfe Junior Member
    64
    Thanks, I was hoping the center armrest would move as its too far back. Guess I wasn't pushing hard enough!
  9. SquallLHeart
    826
    247
    San Jose, CA
    for visibility, it allows... better... visibility.. the light from the bulb already just goes everywhere.. but those spots capture some of that light and make it easier for cars to see at different angles.
    i suppose if we're going to make this thread informative... and for those too lazy to read thru their owner's manual..
    remember.. DO NOT BLOCK OR COVER THE VENT under the driver side rear seat.. it's the intake vent.. and the exhaust vent is on the passenger side in the trunk area.
  10. Ashley7
    Ashley7 Active Member
    545
    222
    Oregon
    2019 Prius
    Dude, why you gotta be such a grump? Chillax. Let people have their fun.
    karabits likes this.
  11. SquallLHeart
    826
    247
    San Jose, CA
    who were you calling a grump?
    well, i'm trying to make sure people do what they should and get the information that they need. anything wrong with that?
  12. kun1he2
    kun1he2 Junior Member
    Singapore
    There's a tiny false bottom secret compartment in the arm rest... :)
    Well, okay, not quite secret if you've already read thru the manual...
  13. SquallLHeart
    826
    247
    San Jose, CA
    psst...
    if you push the window lock button in the lock position, it locks all the windows.. except the driver window.
  14. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    Maine
    I distinctly remember some Toyota spokesdroid saying that they added a bump to the headlight assembly to affect the aerodynamics around the side view mirrors.
  15. TC400
    TC400 Active Member
    751
    169
    Pittsburgh, PA
    I dont remember that! But they made a huge point of it being on the taillights.
    Then I was really looking on my car and i seen it by the mirrors and on the headlights.
    And the regular prius has a bump like that on its turn signals too!
  16. nubomb
    nubomb Junior Member
    somewhere
    That made me chuckle.
