Couple Questions Before Buying??
Discussion in 'Prius c Main Forum' started by clokwise, May 8, 2012.
  1. clokwise
    clokwise Member
    114
    Nashville
    Greetings all. Like others I've been doing some research, reading, watching videos, etc. I've never owned a new car, but I have been trying to find a way to afford a Prius that wasn't 4 years old with 80K miles on it! And then I saw the C. I like it. I drove one and I like it.
    I do have a couple questions. I am a gigging music, sort of by accident but thats a different story. I know there is room for my gear, but with the 99HP engine how well does it do on the highway hauling gear? Does it lose a lot of power? Which brings me to another point, how does the C do on the interstate. I'd say I'm about 60-40 city-highway. I do some traveling for playing music and part of my commute each day I hop on the freeway. I drove a C but it was only in a city setup. So it was stop and go and had no real opportunity to hammer down on it. Of course I'm driving an SUV now which doesn't have much power, so i don't require a sports car, but I just want to know if I need to get going from the on ramp I'm not gonna get rear ended or given the ole 1 finger salute.
    I've had my heart set on a Honda Fit for a while. Its roomy, good gas mileage compared to what I get now (not as good as the C but a big improvement over what I get now), its less expensive, and I don't think I've read a bad review about it. Has anyone had any experience between the 2?
    I'm sure I will think of more questions but thats all for now. Thanks ahead of time, and love the site!
  2. Wildfire
    Wildfire New Member
    Seattle
    Even without the gear you probably wouldn't want to be looking to pass that semi going 70 on a two-lane highway, but that said, my freeway driving experience in the C is actually pretty positive. Gas mileage is still very good and the ride quality (noise, mainly) is apparently much better than what you'd find with the Fit. My next Prius challenge is to see how well the C handles the haul up the local mountain passes @ 70mph.
    Lots of good comparisons between the Fit and the C if you check through the forums; I think only one person liked their Fit better than the C with a ton more making the switch from the Honda to the Toyota.
  3. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
    I never drove or owned a Fit, so i cannot comment between the two.
    How much does your gear weigh?
    You talking about 100lbs or 2,000lbs? big difference.
    The C has a 4 cylinder engine, which will power the C as fast as you need to go.
    Unless you are trying to pass on the autobahn, I am not sure how much more one would require.
    It is not going to spin out or burn rubber (actually I really dont think it could even if you tried)
    But it is as fast as any other style 4 banger
  4. clokwise
    clokwise Member
    114
    Nashville
    I'd say gear is about 100-125 lbs. plus me 250 lbs plus another passenger 190ish lbs. Just wanting to make sure it's not going to slow me down or just completely destroy the gas mileage.
  5. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
    No, no.
    You would need 4 large passengers and a large atm machine in the trunk until you start feeling boggish.
  6. Brerkev
    Brerkev New Member
    35
    Milwaukee, WI
    Could you go back to the dealer to test drive it on the highway? Bring your friend along. With the salesperson in the back seat, this should give you an idea of how the car would drive with your gear in the back
  7. PriusCinBlack
    PriusCinBlack Member
    145
    61
    I don't see any cause for concern in the facts of your situation you've raised- the Prius c can give you all the power you need on the highway as long as you're willing to sacrifice mpg for it.
    Now that my c is broken in (2K+ miles), it can easily get 60-65 mpg around town, which sounds like it will be a good portion, if not most, of your driving. It can also get 60+ mpg on the highway keeping it between 50-55 mph if not heading into the wind. I've gotten as much as 72 mpg average indicated over a 90-mile highway trip with the wind at my back in the c. Air drag is a big deal in this light car.
    Basically, it all depends on what your priorities are. If you like the idea of freakishly good gas mileage in a fairly cute car with decent amenities, the Prius c is for you. I'm sure the Fit has it's strengths, too, though, I'm just not as familiar with them.
  8. clokwise
    clokwise Member
    114
    Nashville
    Thanks all this is helpful. Mot people mention traveling on the interstate of freeway going at 55-60 how does the car do going 75-80? I'm not one to drive super fast but the interstates here in Tennessee are mostly 70 with most people traveling at least 75ish. I need to be able to keep up just so I don't be run over. Does it handle higher speeds well?
  9. ETC(SS)
    7,094
    I don't have any stick time in the "C", so I can't say.
    I've read some Fit owners who have done a stare and compare between the two.
    Read around in this sub-forum a little and you'll get some idea, but remember. We're a "little" biased here in PC. I'm sure that there's a FIT Forum out there that will give you their version of the "truth."
    No....the "C" isn't going to be a tire smoking monster, but it should be OK for interstate duty---even hauling 2 pax or some gear. As stated above, your gear weighs about as much as 1 pax, so.....take a friend on your next test drive!!!
    The Fit gets glorious reviews in the automotive press! IIRC, it's been a C&D top ten model, so it's no slouch.
    MY recommendation would be to drive both and then follow your gut. You'll pretty much know after a few test flights which car would fit YOU best.
    Good Luck!
  10. Erikon
    Erikon Active Member
    819
    105
    Rochester, NY
    I imagine the mileage will drop into the lower to mid 40's loaded with two peeps and gear at 75 to 80mph, 65mph is better.
  11. BGGirl
    BGGirl Member
    480
    84
    Kentucky
    You are in Nashville? I went to Beaman Toyota and they were really helpful. If you decide to go talk to someone over there, ask for Jeremiah. He answered my million questions and was prompt in calling me back if I needed something.
  12. clokwise
    clokwise Member
    114
    Nashville
    Does the car perform well at 75-80. I don't see many people mention that speed range. Most are using this car in the city and rightfully so. I jus happen to do a lot of interstate driving with and without music gear. Is it underpowered for the interstates??
  13. andrewa
    andrewa New Member
    San Antonio, Texas
    I been driving my Prius around in Texas were some not all of are speedlimits are 70mph. I can tell you that in my experience, the Prius C might be slow (longer acceleration time), than traditional cars, but the Prius C can easily catch up and beat them in the 5-10 second difference it takes you to speed up (when driving eco, not power).
  14. clokwise
    clokwise Member
    114
    Nashville
    Yeah! Thats where I went when I test drove. I don't remember the gentlemans name but he wasnt particularly helpful. He couldn't answer many questions, all his info was just generic. But man was he interested when we got down to talking about the numbers in his office!
    Regardless. Thanks everyone for the info. Its all really helpful. Im still looking and reading a bunch of stuff. Im not ready to buy today but soon. Im almost thinking for the same price I could get a C3 I could get a decent used full size Prius. Whats your thoughts on that?
  15. BGGirl
    BGGirl Member
    480
    84
    Kentucky
    Well I know you didn't talk to Jeremiah then lol! He doesn't have an office. He really bent over backwards to keep me in the loop and if he didn't know the answer to something, he would tell me he didn't know and would find out the answer. If you go back in there, just ask for him. You can tell him that the moonroof Summer Rain Prius C sent you.. he will know exactly who you are talking about.. he did everything he could to try and find it for me.. As far as the full size Prius vs the Prius C- I liked some of the new stuff that came with the C, it got better gas milage, looked a little "sportier" and had the warranty. I also hated where the shifter thing is on the regular Prii.. but that is just me! Good luck searching!!
  16. PriusCinBlack
    145
    61
    I looked into buying a used regular Prius myself. The good ones have 10-30K miles on them and end up in the $21K range. That price is lower than a c3, but higher than a c2. The main difference between the c3 and c2 (other than $3K) is the nav stuff, which I did not need. I went with the least expensive option, the c2, with no mileage on it.
    As far as driving 70-80 mph on the freeway, if you plan to continue driving that fast you won't be driving to this car's strengths. It will be ABLE to do it, and you'll still get better mileage than most other cars- low to mid 40's mpg, as others have noted, maybe a little better if you draft- but it may not be worth the extra money. This is just a light car. If that's a priority for you, maybe consider something bigger with a stronger engine.
    On the other hand, if you're open to changing your driving habits and techniques- and driving a Prius is much different than driving regular cars- it has some amazing benefits.
    60+ overall mpg, dude.
  17. clokwise
    clokwise Member
    114
    Nashville
    I wouldn't say most of my driving is 75-80 but I do make frequent trips out of town via interstate. At least twice a month.
