PHEV conversion kit question
Discussion in 'Prius c Accessories and Modifications' started by meehow09, May 8, 2012.
  1. meehow09
    meehow09 New Member
    42
    Chicago
    Would any of you consider getting a PHEV conversion done to your Prius C. It is just a plug-in battery system to supplement your existing battery and it provides up to 20-40 miles per full charge.
    I want the 4kW hr kit and it will cost $3495 + $500 installation - 80% cost due to Illinois Rebate Program for conversions. The final total will be $840 including tax. Do you think this is too much for the system?
    The kit is the Enginer PHEV 4KWH Kit for $3,495.00? There is also a kit for 2kwh, 6, and 8.
    Website link: http://www.enginer.us/products/conversion_kit.php
  2. SquallLHeart
    SquallLHeart The Techie Guy
    826
    247
    San Jose, CA
    thought of it.... still thinking.
  3. Mik1
    Mik1 Member
    333
    Houston, TX
    I wish we had something like that here in Texas. For $840 I would do it with a blink of an eye:cool:
  4. actiondonkey
    actiondonkey Member
    91
    30
    Link to the legal fine print and company offering services please. I'll be driving through IL next month and might open a P.O. box to claim residency.
    Some car dealerships allowed customers to 'sign over' their hybrid gvt rebate and use that amt as a down payment on the car. Wonder if this company would allow me to sign over this rebate and they do the dirty work come tax time whilst I already have a sweet PEHV kit
  5. Mik1
    Mik1 Member
    333
    Houston, TX
    I found these two:
    Illinois Green Fleets
    Vehicle Conversion Rebate | Department of Energy
    But I think PO box is not enough.:(
  6. actiondonkey
    actiondonkey Member
    91
    30
    " In order to qualify, vehicle conversion must take place in Illinois, and converted vehicles must be registered and operated in Illinois."
    The registered part would be a bit more difficult to circumvent. Oh well, so much for getting the Ill taxpayers to foot my PEHV bill:D
  7. formula
    formula Member
    320
    32
    CA
    lol OMG. I hope we have sometime like this in CA. I think you can also claim 10% from Fed?
    it would have been done if we had it in CA. lol
    I did send a email to Enginer about converting the PC, but no reply yet
  8. Mik1
    Mik1 Member
    333
    Houston, TX
    The registered part would be a bit more difficult to circumvent. [/QUOTE]
    That's right. Unless there is a long term business trip with relocation to the Ill on the radar:D
  9. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    Santa Fe, NM
    Is there physical room in the C for a 4 kWh Enginer kit? Consider that it fills the space between the HV battery and the rear deck in a Gen II.
    Still, a 2 kWh kit may be appropriate for the C. Since it has a 144V system, I believe it is only possible to run the 3 kW converter. It is possible that Jack Chen would be interested, since a small kit in a C has the potential for a 100 MPG car. Eric Powers make a post not too long ago about the performance of a 2kWh kit in his Gen 1 Honda Insight, also 144V: Adding Enginer PHEV system. - Page 12 - Insight Central: Honda Insight Forum
  10. MJFrog
    MJFrog Active Member
    780
    267
    NE Oklahoma
    2018 Nissan LEAF
    The Enginer kit only puts out max 15A of current to the HV battery. You may be able to go 20-40 miles all electric on a charge, but you won't be going any faster than 15-20 mph for that distance. At higher speeds you will be traveling in what they call "blended mode", which means the pack supplements the power from the ICE, thus increasing your MPG.
    Your call as to whether this is worth the $$$ to you.
  11. Mik1
    Mik1 Member
    333
    Houston, TX
    When I'm gliding on mine, I can use HV battery at the speeds up to 40-42 mph. Most of my 14-15 miles commute has the speed limits between 30 and 45 mph. Does it mean that I can use the additional pack most of the time except when I am accelerating and the ICE kicks in?
  12. seilerts
    3,326
    1,520
    Santa Fe, NM
    The Enginer pack will keep the battery at high SoC, which makes gliding easier. Since the system voltage is lower, higher current is potentially possible, as long as it does not trigger a fault code.
    It most definitely will not make your car into an EV, and you very much should always use the ICE for acceleration and hills. It would help deliver higher fuel economy if used for gliding/stealth at lower speeds, or blending on the highway.
    It could just work, but early adopters should be forewarned that there may be significant hurdles, and should be sophisticated users: either a mechanic, or a scientist/engineer.
  13. Mik1
    Mik1 Member
    333
    Houston, TX
    Will it be correct to think that the Enginer pack it some way or another will increase the capacity of my HV battery?
  14. SquallLHeart
    826
    247
    San Jose, CA
    it does not increase the capacity of the HV battery.. per say..
    it's more an aux battery that inputs a little current to the traction battery.. keeping the traction battery at a higher SoC..
    it wouldn't say it increases the capacity... more... it just acts like a small trickle charger that you keep in the car.. sure..
  15. formula
    formula Member
    320
    32
    CA
    I got a reply from Enginer.
    Q: Will the kit work with 2012 Prius C?
    A : yes, the kit can be installed onto a PriusC.
    Q: if I bought the PHEV 2KWH Kit, can I add more battery later to make it to 4KWH Kit or 10KWH Kit ?
    A: If you purchase a 2kWh kit, you can trade-in the old battery for 4kWh one for extra $1500 when you upgrade to 4kWh system.
  16. Mik1
    Mik1 Member
    333
    Houston, TX
    In that case for my 14-15 miles (one way) commute 2kW will be the best bet I would say. Will start thinking about it a little bit more...:D
  17. rwiggins951
    rwiggins951 Junior Member
    Cleveland OH
    I am interested in pursuing this. Need to see if Ohio offers any such rebates and get more details on the Engineer kit with a PC
  18. formula
    formula Member
    320
    32
    CA
    I will check with Enginer for more detail. I hope the kit can fit just above the spare tire where the think foam is.
  19. seilerts
    3,326
    1,520
    Santa Fe, NM
    Since you are in Cleveland, OH, contact Enginer (Troy, MI) and see if Jack will do the install personally.
    Can someone post a picture of where a prospective kit might be fitted in the back? I think, just count on losing access to or removing the spare tire. Before everyone starts howling, think about the last time that you had to change your tire in the middle of nowhere with no access to AAA etc.
  20. briank101
    briank101 Member
    170
    68
    Western Chicagoland
    Even though I live in Illinois and after reading this Vehicle Conversion Rebate | Department of Energy
    , I suspect this rebate does not apply to this type of PHEV conversion kit. If anyone has had success with this Illinois rebate, I would be interested in a specific reference to PHEV conversion kits being applicable.
