C in the rain...
Discussion in 'Prius c Main Forum' started by prius1driver, May 9, 2012.
  1. prius1driver
    prius1driver New Member
    78
    New York
    It's raining here today. For the same distance of my commute, I saw a dramatic drop in MPG. Does this make sense?
  2. j_benj
    j_benj Prius C Fan
    125
    Jersey
    Raining here too and I clocked in my morning commute at 56mpg. Actually slightly higher than my normal. I attributed it to slower moving traffic, never got up past 55ish on the freeway.
  3. prius1driver
    78
    New York
    I used to get 55-58mpg for my commute, but it fell below 50mpg today thanks to the rain :(
  4. j_benj
    j_benj Prius C Fan
    125
    Jersey
    Wow that is a significant drop. Is the outside temp much colder today than it has been?
  5. jbrad4
    jbrad4 Active Member
    474
    148
    Rowlett, TX
    Check your tire pressure. Several people on this forum driving the hatchback run with 44psi front, 42 psi rear. That's what I have in my PHV tires.
  6. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Yes, normal. Pushing water with the tires takes a lot of effort.
  7. Ashley7
    Ashley7 Active Member
    545
    222
    Oregon
    2019 Prius
    When I bought my c, it rained for about a month (Oregon). My mileage went up as soon as it stopped raining and the temperature went up. Both of those have an effect. The engine is also breaking in, but I've still only driven it 600 miles, so I'm not sure how much that had to do with it.
  8. dig4dirt
    dig4dirt MoonGlow
    1,153
    741
    Lancaster Co PA
    Ash, glad to hear you mpg went up!
    Rain will change mpg, and it all depends on driving characteristics.
    Take benj for example. (lower speed=higher mpg)
  9. PriusCinBlack
    PriusCinBlack Member
    145
    61
    Also, wind. If it's windy, that will affect your mpg more than anything.
  10. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    All the 'spray' you see is lifted from the road surface by energy from the cars. MPG has to go down to get that spray.
  11. j_benj
    j_benj Prius C Fan
    125
    Jersey
    Tis true indeed! headwinds are my enemy on the freeway.
  12. south central
    south central Member
    100
    south central Illinois
    We took a 230 mile (mostly interstate) round trip when we had less than 200 miles on the ODO. Bucking 25-30 mph headwinds we got 41 mpg with driving speeds of +/- 67 mph. I was actually pretty happy about it. Aerodynamics can help only so much and that was some wicked wind. The return trip, with tail wind, averaged 53 mpg.
    Oddly enough we haven't driven in much rain, or at night. (Now I'm curious how the interior cabin lighting looks).
    It'll be interesting, as everyone's Prius c breaks in and matures, to read posts about mpg evolving and how significantly the elements change those figures.
    Deb
  13. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    As others have mentioned, tires have to push out the water. Rain usually come with stronger wind. Headwind is bad, obviously. Sidewind is even worse as it screws up the aerodynamics.
    People usually slow down when it rains so you gain some more MPG from it. Overall, the MPG evens out for me.
  14. fgp
    fgp Active Member
    503
    169
    daytona
    2023 Prius
    check out my recent trip to daytona. fred and shotys trp to daytona and back
    good and bad
  15. cadillackid
    cadillackid New Member
    Columbus Ohio
    also in the rain you may be using your A/C to keep the windows defogged that will make a difference as to pull out humidity an A/C unit works Much harder than to cool hot temperatures.. condensing moisture takes a lot of energy...
    -Christopher
  16. Neilb9
    Neilb9 Million Mile Driver
    22
    Kauai
    Yep! And so does every other car. The c just lets you know what's really happening.
  17. thefyn
    thefyn Junior Member
    33
    Treasure Coast
    Yep, it rained torrential on hyway and the gas milage got a huge drop for me.
    Kinda expected...But driving that little thing through huge pools on the highway in torrential downpours Florida style was kinda scary. That is the trade off I suppose.
  18. rjdriver
    rjdriver Active Member
    411
    172
    Rhode Island
    Have been reading this thread with interest, as in the 10 or so days I have driven my 40 mile commute in the rain over the past 6 weeks, average mileage for the trip has not varied at all. Have been getting a steady 55 to 56 mpg for what is a fairly even split between highway driving at 65-75 MPH and rural/city at 38 - 52 MPH.
    Most of the days, the rain was light to medium. Today it was very heavy. Not a lot of puddling or ponding on the road as the drainage was good, but a steady downpour that required full wipers (not intermittent) for the whole trip, and I still got 56mpg. None of the rain on any of my rainy days was accompanied by much in the way of wind.
    Obviously, when a tire has to disperse water it's momentum will be lessened, so technically, gas mileage should drop. I can't explain my situation, except possibly that the wind was more a contributor for the others posting here. Also, maybe the fact that the general driving speed was a bit slower overall in the rain, or at least a higher percentage of it was at the lower end of the above speed ranges. That might have negated the lost MPG and balanced it all out.
  19. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Heavy rain will cause you mpg's to drop anywhere
    from 10-15 % or even more. Not just the Prius
    but all cars except they don't notice it like
    we do in our Priuses.
