Early Indications of HV battery Weakness (@91k miles)
Discussion in 'Gen 2 Prius Technical Discussion' started by uart, May 10, 2012.
  1. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Firstly let me say that the car is still running perfectly and giving great MPG, but I just wanted to document some early signs of traction battery weakness and see if anyone else has notice these particular symptoms.
    1. Descending hills I get up to the full 8 green bars much sooner than it used to do. When I first got the car (at about 40k miles) I rarely saw it top out the battery charge. It needed to descend about 80 meters (change in elevation) of fairly steep hills to go from the nominal six bars up to all eight green. Now it seems I can max it out with as little as about 45m change in elevation (if it's steep and taken slowly).
    2. SOC anomalies after full 8 green charge. After topping out the battery to max charge, I've noticed lately that it seems to remain up at 8-green for longer (under EV driving) than previously. Normally you'd think this would be a good thing, as it would seem to indicate the battery is holding lots of energy, but it actually seems to be caused by errors in the Prius's SOC estimate. What I've noticed is I can drive (flats) in full electric mode, and it stays up at 8 (then 7) green bars for quite a long time (longer than previously), but when it eventually drops back to 6 (blue) bars, then it almost immediately falls to 2 or 3 bars. It's like it's miscalculating the SOC, and all of a sudden it realizes it's wrong and make a correction of -3 to -4 bars!
    Has anyone else noticed these issue?
  2. MJFrog
    MJFrog Active Member
    780
    267
    NE Oklahoma
    2018 Nissan LEAF
    This sounds more to me like an issue with the battery ECU than the battery itself...but that's just my opinion. Regardless, I'd get it checked by the dealer ASAP before it runs out of warranty.
    Don't know what warranties run in Australia, but US warranty is minimum 8 yr, 100k miles; 10/150k in CARB states.
  3. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Nah, the battery ECU works perfectly in all cases except for immediately after the battery has been maxed out (like to the point where it's spinning the ICE to dump excess charge). If (for example) it only charges to 7 green bars then the battery ECU monitors the SOC exactly as it should, no unexpected jumps or anything. I'm about 99% certain that this is a battery rather than an ECU issue.
    Yeah I'm not 100% sure but I thinks it's 8 year 150000km here. I'd be just in warranty, but I'm certain it wouldn't fail any (dealer service) tests at this point. The car runs great in every other way, gets 55+ MPG and still glides (full electric) perfectly. There's no way this would rate as a warranty issue at this point (in my opinion).
  4. chesleyn
    chesleyn Active Member
    596
    158
    Los Angeles
    UART:
    I just traded in my 06 Honda Civic Hybrid and it displayed the exact same characteristics that you are describing. One other thing it did was drop to 2 bars soc after starting the vehicle. Realized the battery was nearing its lifetime. Traded It in with 130000 miles.
    uart likes this.
  5. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    I'd get it checked as it does sound like when my HV battery ECU started to fail. It would sit at 7/8 and then 5/8 for long periods instead of the normal 6/8. It would then fluctuate rapidly and do weird things like you describe.
    I first thought it was the 12v failing but that checked ok and a trip to the dealers showed the ecu. Unfortunately it was about £700+20% tax+ fitting all under warranty but not cheap if the warranty has expired.
    I forgot to add - this was about 18 months ago and the car was absolutely ok since with regard to that.
  6. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,518
    Santa Fe, NM
    Yes. It is a sign of lost capacity.
    While cold comfort, know that you won't actually get a Red Triangle until most of the capacity is lost, around 85%. But, capacity loss is not linear, and will likely accelerate as the battery gets weaker.
    You may wish to start combing breakers yards now for a spare pack. They can sit on the shelf for a very long time.
    uart likes this.
  7. climateguy
    climateguy Junior Member
    65
    Santa Fe, NM
    These symptoms are exactly what I experienced with my battery (post), and at the same mileage. Unfortunately, if you take it to the dealer for diagnosis, you'll probably end up in the same situation I was in. Even though you know capacity has decreased, the dealer won't do anything without a DTC. Well, they will do something - they'll charge you ~100 USD to hook it up to their computer and tell you it's fine.
    Mine "lasted" another 40k miles after I first noticed the decreased capacity, but mind you that driveability suffered quite a bit during the last 15-20k. I never did get a DTC, but ended up replacing it because it got to the point where I couldn't ascend hills at over ~40 mph.
    If I'd known at 92k miles what I know now, I might have been tempted to...umm..."ensure" that a DTC was generated before the warranty expired. ;)
    uart likes this.
  8. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Thanks for the info everyone. Yes climateguy, I remember reading you post and was thinking my situation was similar to yours. Especially the part about the wife having to drive it over mountains that take it out to max SOC a couple of times per day.
    For those who still think it's just a problem with the battery ECU, let me say that it can run all day, all week, all month, whatever, and as long as the battery doesn't get maxed out then the SOC behaves totally normally. If I'm regenerating then the SOC goes up (slowly and predictably). If I'm running in EV then the SOC goes down (again steady and predictably). If I park it at night with 6 bars then the next morning it's still got 6 bars. If I park it at night with 7 bars then the next day it's still got 7, and so on. Nothing at all seems amiss with how the SOC behaves except for the first discharge cycle immediately after maxing out the SOC (generally to the point of spinning the ICE to dump charge). This seems to be the only instance where the SOC doesn't behave correctly, where it stays up high for ages and then seems to drop very suddenly from 6 down to 3 bars.
  9. uart
    uart Senior Member
    4,220
    1,211
    Australia
    BTW. Does anyone know of where to look for a s/h battery in Australia, or someone that will ship to Australia?
    I do think mine will hang in there for some time (driveablilty so far is not much affected), but in the mean time I wouldn't mind getting hold of a s/h one and rebuilding it.
  10. MJFrog
    780
    267
    NE Oklahoma
    2018 Nissan LEAF
    When it starts misbehaving (spinning ICE to dump charge...) after maxing out the SOC; if you pull over, shutdown and restart the car, does it start behaving properly again?
    If it does, again I would point at the battery ECU as the culprit.
  11. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    I'd second that as mine did exactly that. Started off gradually and just got worse and worse over a few weeks.
  12. uart
    uart Senior Member
    4,220
    1,211
    Australia
    No, if I power off the car and restart then it makes no difference. Maxing out the traction battery charge just seems to put the SOC out of kilter. It stays that way (even if powered down and restarted) until the SOC drops to about 6 bars and then it's like it suddenly figures this out and re-adjusts the SOC back to about 3 bars quite suddenly.
    If the SOC was not topped out (like if it only goes to 7 bars, or even if it just hits 8 bars but doesn't top out) then the SOC is tracked properly and no anomaly occurs.
  13. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    I'll quickly tell you of my experience. It was very similar to yours, the battery sitting at odd levels but otherwise the car ran well and economically. Then it would fill up too quickly and then there were one or two times where it shut off and the engine revved as if trying to run the a/c and such like.
    Then one morning I tried to start the car and got the "check hybrid system" message. It did this a couple of times and then the car started and ran ok even when switched off and left over night. Then it displayed the message again and this time I knew something was wrong.
    It was only a warning and not the amber triangle and definitely not the red triangle, so nothing too major. Took into dealers and ecu was faulty.
  14. uart
    uart Senior Member
    4,220
    1,211
    Australia
    This doesn't really sound all that similar to my situation. My battery is hardly ever sitting at odd levels. Actually about 99% of the time it behaves totally normally.
    Mine fills up normally but just has reduced capacity (compared to what it used to have). It doesn't just fill up while I'm driving along normally or anything like that. I have to go down a large hill, regenerating all the way, and then it fills up just as it should, first to 7 green bars (normally takes a while) and then to 8 green bars (happens a little more quickly than the 7). This is no different to what it's always done, but over time the size of the hill required to fill it has become less.
    Mine doesn't "shut off", but spinning the engine is normal behavior when the SOC is too high.
