LED or Xenon Headlight
Discussion in 'Prius c Accessories and Modifications' started by uPredict, Mar 21, 2012.
  1. daboy
    daboy Junior Member
    51
    I really want to order this today to get 20% off but I don't know if my dealer can get me a prius c.
  2. fattymoocow
    fattymoocow New Member
    96
    Richmond, VA
    Thanks crebble for the link and coupon code!
    I watched some of those installation videos on the xenonsupply.com site and think this is something I could do by myself. But then I started reading that HIDs are illegal if they are put on aftermarket? Seems weird considering almost everyone on this forum has them on their Prius. So wondering, what is the likelihood that I would be pulled over for having them in? I was looking at the 6000k. I read that if they aren't pointed high then you're not likely to be pulled over and since the Prius is such a low car to begin with will this be okay then?
    I really want to get them but I don't want to be pulled over.. So any advice will be great! Thanks! Answers before the end of the day will be even better since the coupon code expires tonight ;)
  3. F8L
    19,011
    4,083
    Grass Valley, CA.
    If you want to reduce the likelihood of being pulled over for HIDs then stick with a 4300K bulb or a 5000K bulb. You'll benefit from a brighter light as well as get rid of any blue which is a dead giveaway for an aftermarket HID kit since all the ricer kids, including the truck crowd, use 6000K or higher rated bulbs. OEM HIDs are 4100K-4300K.
    Aiming the headlights correctly is important for safety as well as legality. The only problem with HIDs in the Prius is the upward bowing (think smile) of the cutoff beam. This casts light about 2ft. Higher than the normal cutoff and into the eyes of oncoming drivers. For this reason it is critical you ensure your headlights are aimed correctly.
  4. kkim
    kkim Active Member
    386
    132
    kauai, hawaii
    Yep, I always use a 4100-4300K HID kit when adding HIDs to cars that don't come stock from the factory with them. I have never had a problem with being stopped because of HIDs.
  5. maverickf
    maverickf New Member
    113
    Southern California
    So as long as I have the headlights aiming correctly, I should be fine right? I didn't know that about 6000K bulbs when I ordered right before the coupon expired.
  6. F8L
    19,011
    4,083
    Grass Valley, CA.
    Aye, just be safe and make sure they are not aimed too high. :)
    If you don't like the blue tint of the bulbs you can change them out whenever you feel like spending another $40 buck or so. The bulbs are not specific to the kit.
  7. maverickf
    113
    Southern California
    Thanks. I'm definitely not going to aim high, I don't want to get pull over from cops then from wife at home. :p
  8. F8L
    19,011
    4,083
    Grass Valley, CA.
    I hear ya! LOL
  9. Mik1
    Mik1 Member
    333
    Houston, TX
    This is how I mounted mines with some delay, was out of town... Looks amazing.
      File size:
      161.3 KB
      1,076
      File size:
      144.7 KB
      1,063
      File size:
      186.2 KB
      1,074
      File size:
      118.2 KB
      1,112
      File size:
      85.2 KB
      1,025
  10. Redcap32
    Redcap32 Junior Member
    45
    Kansas City
    I love my HIDs drove down to the Ozarks last week and had amazing visability I got the 4300k. My HIDs in the lows are brighter then my highs.
  11. crebble
    crebble Member
    176
    47
    Shohola PA
    Xenonsupply just sent me another 20% off coupon code. "memday20". Good until May 28 th.
    Hope it helps someone if they are on the fence about ordering HIDs.
  12. orangenerd
    orangenerd Junior Member
    58
    Lawton
    Thanks much man
  13. crebble
    crebble Member
    176
    47
    Shohola PA
    New coupon code from XenonSupply. "hid4pops". 22% off until June 17th at 11:59 pm.
    Surrylic likes this.
  14. Surrylic
    Surrylic Junior Member
    122
    Winchester VA
    Nice, thanks!
  15. Lindy
    Lindy Junior Member
    San Francisco, California
    I am also in san mateo. Are you at Putnam Toyota or Toyota 101? I need to get these and I need an install. Any suggestions? Please?
  16. Lenwood
    Lenwood Junior Member
    53
    san Mateo ca
    Lindy shoot me a message and I'll call u . The install is really easy and can assist you.
  17. crebble
    crebble Member
    176
    47
    Shohola PA
    New code for the 4th, "fireworks" good for 18% off. And for those who bought the kit, check your 3m pads. Mine let go.
  18. daboy
    daboy Junior Member
    51
    any new coup0n code? TIA
    edit: got 15% coupon" xsforum15"
  19. Ryephile
    Ryephile The Technophile
    418
    151
    24
    Metro Detroit
    Very clean install (y)
    I just placed an order for the Prius H11 package from XenonSupply.com. We'll see how this goes; I've yet to read any negatives from them.
    To be honest I'd love to see an H11 LED bulb with proper illumination, but haven't seen the aftermarket catch up yet. LED arrays that can be used for forward lighting are certainly out there and starting to proliferate OEM applications, however the aftermarket support may get the shaft until the arrays can be made modular enough for halogen replacement footprints.
  20. DKTVAV
    DKTVAV Active Member
    510
    101
    What package did you order? Link if possible.
