Yokohama YK580
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by The Critic, Oct 31, 2011.
  1. The Critic
    The Critic Resident Critic
    3,193
    2,330
    CA
    I was on Discount Tire's site tonight and came across an advertisement for their DTC/DTD-exclusive Yokohama YK580.
    Discount Tire And America's Tire Yokohama YK580 Tire
    YK580 Performance Tires | Yokohama Tire Corp.
    The tread pattern is very different than the Avid ENVigor or the previous generation YK520.
    On Yokohama's website, you can compare various tires on traction, winter performance, NVH and longevity, based on Yokohama's internal testing.
    According to them, this is how the YK580 ranks against the Avid ENVigor and TRZ:
    YK580/Avid ENVigor/TRZ
    Dry Traction: 9/8/7
    Wet Traction: 9/8/7
    Winter Performance: 6/5/10
    NVH: 8/8/9
    Longevity: 8/7/10
    The weight of the YK580 in the 195/65-15 size is only 19.8 pounds. This compares favorably to the 18 lbs of the Bridgestone Ecopia EP422 and is much less than the 23 lbs of the Michelin Primacy MXV4.
    Considering the advertised low rolling resistance and the promise of superior traction, I think this tire is worth considering for our cars. According to Yokohama, the YK580 is an improvement in dry and wet traction over the Avid ENVigor-- which was a tire that performed very well in Tire Rack's testing against other High Performance all-season tires. Therefore, the YK580 should be darn good if it as good as the specs promise. :roll eyes:
    Price is $93/tire on Discount Tire Direct, which is quite competitive.
  2. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    Price is $100 mounted and best of all it is in stock at all SF Bay Area locations. LRR tires at hard to find in stock.
  3. dhanson865
    dhanson865 Expert and Devil's advocate
    851
    188
    TN, USA
  4. The Critic
    3,193
    2,330
    CA
    Relying on words from marketing literature is probably not the most reliable method of comparison. However, the one advantage that the YK580 has is the superior wet/dry traction
    MB860 ?
  5. jawmag
    jawmag Junior Member
    Monterey, California
    I wanted to let everyone know about my experience with these tires. I bought a set about 8000K ago. I originally was going to get the michelin energy saver tires, but they don't make a size for my touring model Prius 08. These yk580's were a little more expensive but I thought I would try them.
    In the first week I drove from spokane to seattle up to Vancouver, through the mountains over to calgary. These tires handle incredible not just in rain but also in slush and snow. The other thing I noticed is how quiet they are. I also had a chance to drive the windy hills of the napa valley. The turns are hard and fast and these tires held on even when the pavement was wet.
    I have driven over 1 million K. I have a number of vehicals and have bought new michelins, brigdestone, bf goodrich, nokian and pirelli tires. I would say these could be the best tire I have ever owned. There is just something special about them. Very Satisfied.
    Jawmag
  6. Former Member 68813
    3,524
    983
    US
    Interesting. How about MPG?
  7. F8L
    19,011
    4,083
    Grass Valley, CA.
    Mpg would hopefully be decent for a tire they call LRR. Time to make some calls. :)
  8. plam0ne
    plam0ne Ninja
    70
    florida
    was quoted 600 installed by local DT. (205.50.17) hmmm...
  9. F8L
    19,011
    4,083
    Grass Valley, CA.
    I talked to Yokhama and they stated that the YK580 is indeed considered LRR but for max mpg the dB Super E-Spec and the AVID Ascend are better choices. For more traction and performance the YK580 is a better choice.
  10. plam0ne
    plam0ne Ninja
    70
    florida
    got them installed, great tires! a whole lot quieter than the sumi's handle's just as good too. very happy with these :)
  11. F8L
    19,011
    4,083
    Grass Valley, CA.
    Nice!
    Please keep us posted on MPG and noise as they break in. :)
  12. plam0ne
    plam0ne Ninja
    70
    florida
    will definitely do. a few quick snapshots :)
    on stock v wheels, yk580 205/50/17 (43/41 pressures)
  13. F8L
    19,011
    4,083
    Grass Valley, CA.
    Thanks for the pics. It looks like the extra 1/2" didn't do much for the wheel well gap. At least the mpg should be better. Your car looks great. I'm jealous of the wheels. :)
    mellowjd likes this.
  14. D@LA
    D@LA New Member
    Los Angeles
    2014 Prius Plug-in
    Hi folks, I found this old thread while researching YK580s for my Prius, and it was helpful but I really wished the original posters had followed up on the mileage question so I'll try to fill that void for others who may be in the same situation. I've now put a couple thousand miles on these tires and as best as I can tell, the mileage difference is negligible. I might be getting 1 MPG less compared to the Avids that came with the car. Maybe. It's hard to say exactly of course because as we all know there are dozens of variables that can affect mileage (e.g. climate control use, tire pressure, etc) so maybe I'm off slightly. Maybe it's 2 mpg, or maybe there is no difference whatsoever. My point is that there is NOT a big fuel efficiency difference between the two, as far as I can tell, so if you're looking to replace your Avids you don't have to fear your mileage will fall off a cliff. There is, however, a very noticeable difference in traction as noted by others, with the YKs being superior.
    If you are a hypermiler who wants to push the fuel efficiency limits and you have zero tolerance for any compromises to mileage, I respect that and you might want to stick with the Avids or something similar. For everybody else, however, I do recommend these tires. For me, traction = safety. Given that the tradeoff on mileage is negligible, to me it's a no brainer.
  15. WolfpackBill
    WolfpackBill Senior Member
    349
    500
    Lexington, NC
    Here's my 2 cents.
    I had these tires when I had my Accord. The traction was awesome in both wet and dry roads. They are extremely quiet at the beginning but at the last 15,000 miles or so, the noise became unbearable (had them for 60k miles). Now I understand it's a Honda and they're not good at insulating road noise, I don't think our Prii are really good at that either. Tread wear was nice and even throughout the life of the tires. I don't know much about MPG since I really didn't care about it since I was driving an Accord so I wasn't chasing MPG like I do now with my Pirus.
