Morimoto HID Conversion Kit Can Bus or Relay Harness
Discussion in 'Gen 3 Prius Accessories and Modifications' started by silversurfer501, Apr 2, 2012.
  1. silversurfer501
    silversurfer501 New Member
    Los Angeles
    I am planning on purchasing Morimoto Elite HID Conversion Kit from TRS for 2012 Prius. Is it better to go with Canbus or Relay Harness? Please share your experiences. For instance, flickering, check warning lights, etc...
  2. ImeanGreen
    ImeanGreen Prius v Five BP Brigade #236
    547
    73
    Somewhere out there
    Andrew at TRS suggested to get the Canbus. Just be aware that you can have the ground wire shadow issue.
  3. silversurfer501
    Los Angeles
    What is ground wire shadow issue?
    I spoke to Andrew from TRS, and I suggested that I get relay harness because there is less chance of flickering. I am confused.
    Do you have Canbus Ballast? Any issues?
  4. ImeanGreen
    547
    73
    Somewhere out there
    Did he suggested you get the kit with the relay or you suggested to get the one with the relay? What did Andrew told you what to get? I have the Canbus with no issues so far.
    Ground wire shadow looks like this in post #8. Need quick help on wiring for Morimoto 35w 9006 Elite HID kit install in 2011 Ford Edge!!
  5. goodtimes
    goodtimes my future is righteousness
    67
    32
    2011 Prius Alpha
    Been through this dilemma with Andrew & Matt @ TRS. The best outcome was to go with the heavy duty relay harness. It's an 80 amp per HID bulb. Easy install...
    No flickering... I have 2 Morimoto Elite kits with relay... 1, for head lights & the 2nd for my retrofit projector fog lights...
    No qualms whatsoever...
  6. silversurfer501
    Los Angeles
    Do you think you can show me some pictures of your installation? I know to use the fuse box for positive and the side fender for ground. But where did you place the relay and wires?
    Any step by step guide with pictures is greatly appreciated. Thank you
  7. goodtimes
    67
    32
    2011 Prius Alpha
    Do a search on You Tube for:
    Toyota Prius HID - How to Install HID Xenon 2010+
    This is a great tutorial step by step. They use a different hid kit but, it's basically the same setup as the Morimoto Elite. Everything is pretty stealth. Enjoy!..........
    TRS also has a install guide on their website with picture maps. Not actual pictures of install. Just diagrams of what wire goes and connects where......
  8. PriusWiLL
    PriusWiLL New Member
    Socal
    Im also interested in purchasing the morimoto kit for my 2012... can anyone link me to the exact product page? which ballast should i be picking? 35 or 50w?
  9. PriusWiLL
    Socal
    can anyone chime in?
  10. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Why would u need a canbus relay? Arnt those use in German cars that have the warning/check light &/or use the lowbeams as DRLs?
    As far as my experience goes, the std relay harness will work.
  11. El Nino
    El Nino Member
    210
    Michigan
  12. ImeanGreen
    547
    73
    Somewhere out there
    Bought the CAN BUS kit but ended up bypassing the CAN BUS wiring harness. Had problems with my CAN BUS wiring harness connector to the main headlight connector. So far it is doing fine with no flickering issues. Relay not used - headlights are fused anyway. Had to buy the bulbs from xenon supply to remedy the return ground wire shadow.
  13. El Nino
    El Nino Member
    210
    Michigan
    hmmm. I really didn't think it was that bad at all. Let me know what you think about light color and output when you compare. Thanks!
  14. ImeanGreen
    547
    73
    Somewhere out there
    The bulb I got with the morimoto kit was 5K and replaced with the 43K xenon supply bulb. Can't really tell the difference. Color from the 43K was even throughout as well as the 5K from TRS. Time will tell and will report any issues. Start up was very good with the morimoto 3 five ballast.
  15. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    A flicker issue can be 1 of the following:
    1) lowbeam used as DRLs (not on Prius)
    2) loose ground wire (on relay harness)
    3) loose power wire (on relay harness)
    4) bad bulb(s)
    5) bad ballast
    These are the most common causes for HIDs flickering.
  16. PriusWiLL
    Socal
    er ok so i can't buy from morimoto cause of the ground wire shadow problem? or do i need to buy from morimoto and replace the bulbs with ones from xenon supply? I'm a little confused
  17. ImeanGreen
    547
    73
    Somewhere out there
    PW, I would suggest that you buy the morimoto ballast and relay harness(I don't use a relay harness on mine - but get one just to make sure) and buy the bulbs from xenon supply. Make sure the bulbs has the same rating with your ballast. Meaning, don't buy a 55w HID bulb with a 35w ballast. I would go with the 3five ballast morimoto and a 35w 4300K HID bulb from xenon supply.
  18. chuck112281
    chuck112281 New Member
    17
    where did you install the positive in the fusebox. i just received my today, don't know where/how to connect my relay harness to the positive of the battery..... please help
    Thanks
  19. r3dl4b3l
    r3dl4b3l Junior Member
    72
    Houston, TX
    Check my posting about the relay. I linked another page with detailed pictures..
    Morimoto HID Harness Help | PriusChat
    Post#4 with link
  20. chuck112281
    17
