Installed subwoofer and door speakers
Discussion in 'Prius c Audio and Electronics' started by Tycho_Brahe, May 14, 2012.
  1. Tycho_Brahe
    Tycho_Brahe New Member
    Nashville
    I'd appreciate any comments or even constructive criticism. This is my first time at doing something like this and it's a miracle I got the car back together. I would not doubt, this is most useful as a guide for an example of what not to do :) But it was a good experience.
    I wasn't happy with the stock stereo. Often there was some peaks or valleys in the frequency response that fatigued me after a while. CD was acceptable, not great, but FM hit or miss. Satellite very hit or miss ( mostly miss ). What I ended up with was lots more bass, cleaner vocals, no headache inducing peaks and better stereo separation. It's not sonic bliss by any means, and I realize a head unit would be a step up. But it's enough that I really love listening to CDs again.
    The photos ( link below ) tell most of the story. I built my own enclosure. I wanted something small and the driver I chose enabled me to save most of my hatchback space. The enclosure is movable with a hook that unsnaps and some velcro. I just wanted enough bass for fuller music and moderate clean thump when I needed it. I'm using the fader control of the head unit for bass control, but I can also use the EQ of the head unit. Lastly, I added a fader knob to control output the the 2 amp inputs for the bass ( bridged output for rear channels ).
    I'm guessing that reusing the stock midrange mounts ( is midrange the right word ? I wanted to say woofer in my photo descriptions but didn't want to confuse with the subwoofer ) helped a bit on the bass response but the Boston SR60 drivers really don't have a lot of bass response.
    Here's the link to all the photos. I know there are a lot - just view the thumbnails and skip what you don't want to see. I tried to take photos of most of the steps but missed a few: Zenfolio | TychoBrahe | Prius Shared Stereo
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Looks like a great job. The question is, how does it sound?
  3. Wharfe
    Wharfe Junior Member
    64
    Good stuff! Looks nice.
  4. xerox6135
    xerox6135 Member
    170
    94
    michigan
    Very nice slide show . How does the cover around the radio come off . which wire did you use to feed the amp as in what color
  5. F8L
    19,011
    4,083
    Grass Valley, CA.
    Nice. Good job for your first install!
    My suggestions:
    1. Next time install the amp under a seat or in a storage bin. This will make removing the sub MUCH faster in the event you need to carry a large load AND it looks cleaner. Alternatively you can place the amp on the box but between the box and rear seat back so it's hidden and less likely to cause the box to flip over due to extra weight on one side.
    2. Place the terminal post (where the speaker wire go) on the side of the box so they are not visible.
    3. Try facing the sub straight back instead of to the side. This may increase total bass out put or at least increase low bass output perception be increasing the length over which the sound wave has to travel before reaching your ears. Low frequency waves are very long! To better understand my point try listening to the sub with your head right next to the speaker. Then go sit in the drivers seat and listen again. See how much louder it is? You cannot detect low frequencies when you are so close to the source. :) this is why sound competitors like to stick the microphone in the corner of the dash and far away from the speaker depending on the type of competition.
  6. Tycho_Brahe
    Nashville
    Thanks ! Yeah, if I have to carry a large load it will be a pain, you're right. I wanted to put it under a seat but there's not a lot of room, plus I cringed at removing a seat due to the airbag risk. Oh, and the heat too. I wasn't sure if it would dissipate the heat well enough. But after using the amp, it doesn't seem to get very hot so it would probably have been okay. The wires are long enough to at least move the thing around ( enclosure/amp combo ) if I have to, but only for maybe 3 or 4 feet in each direction.
    Your point on the terminal post is well taken. After completion I did wish I did something nicer with that part.
  7. Tycho_Brahe
    Nashville
    The cover around the radio snaps right off. Just put something flat and small ( key sized ? But not so sharp as to scratch the plastic ) on the bottom right where there is a gap. Keep gently working your fingers around the cover perimeter and it will come right off. The hazard light switch may need to be disconnected ( or you could let it dangle with the cover ). Then the radio comes out with 4 screws, just like squalllheart mentioned but will be attached by one million harnesses ;-) Take a look at my comments/description on this photo page for the wiring colors: Zenfolio | TychoBrahe | Prius Shared Stereo | Random Images of Head Unit Label and Harnesses
    Also, I'll include a horrible drawing I just did in paint.net. The only accurate wire colors in this diagram are the factory head unit speaker outputs. I didn't bother to make accurate amp input colors as I figured you wouldn't have the same amp anyway. I did not bother to break the front speakers down to the components and the potentiometer ( knob fader ) is just something I wanted to do for my setup but you can just ignore it and take the wires straight down to to amp instead. And obviously I left the many feet of speaker wire out of the diagram.
  8. Tycho_Brahe
    Nashville
    It sounds pretty darn good. I'm comparing it to what I had, so I guess it's not a surprise it's better but I'm happy. Nice clean bass but still a little peaky. I'm playing with the gain and EQ a bit and think I have it where I want it. Was definitely worth it and a fun thing to try.
  9. F8L
    19,011
    4,083
    Grass Valley, CA.
    I think you did a great job, regardless. :)
  10. xerox6135
    xerox6135 Member
    170
    94
    michigan
    thanks I may get a amp this weekend thinking of putting amp and subwoofer down in the spare i think it will fit did the same on my focus sounded great just a pain if you get a flat
  11. cadillackid
    cadillackid New Member
    Columbus Ohio
    is there any benefit to just replacing all of the stock speakers or does the stock NAV style headunit just not have the Juice to drive better speakers.. I took my test drive yesterday and thought the sound system was very muddy.. even compared to my Jeep wrangler... when my PC comes in im thinking i'll at the very least want to swap the stock speakers out...
    -Christopher
  12. Tycho_Brahe
    Nashville
    I think you would might be satisfied doing that. The speakers I got were only at 90db sensitivity. Using a Polk at 92db or Infinity at 93db will get it about twice as loud. The first thing I did was install the new front door speakers and listened for a week. The factory unit had more trouble powering my speakers but they were very noticeably better. Clearer, more dynamic, better presence / stereo separation. But needs more power, like you said. I did not find that my amp output was unacceptable with my medium efficiency spearkers but you would probably be better off with something around 93 db. Also, my speakers had less output on the mid and low bass than the stock speakers.
    To me, and this is very subjective and hard to get a handle on, adding just new front speakers improved the sound around 15 to 20 %. Adding the amp another 10 to 15% and adding the subwoofer another 15 to 20%. I think each piece in the chain can be the weak link. I've heard every opinion on what's the most important piece in the chain and they are across the board.
  13. Wharfe
    64
    Cadillac, personally I wouldn't waste my time doing speakers only. I didn't have the Nav, only the basic head unit, but I believe they both sound the same.
    I couldn't believe how terrible the whole system was, I really blamed most of it on the speakers, but I installed my new Clarion head unit before changing out the factory speakers, and the difference was incredible. The factory head unit is the main problem with the system. That's why I decided to get the base model and upgrade it myself, rather than paying for Nav and ripping it out.
    They're not high quality speakers from the factory, but I was surprised how much better they were with a new head unit. They actually produced real bass without distortion!
  14. Robinwood
    Robinwood New Member
    India
    When you get all these stupid problems in your woofer, why dont you thorough it away and have some hot speakers around...like. [​IMG]
  15. managerman
    managerman Prius v Nerd
    228
    110
    Columbus, OH
    Tycho,
    Amazing install!! Very nicely done....I now have another mod project to add to the list!! :)
    On a different subject...I noticed in the pictures that you had a shot of the back of the C3 Headunit....I am wondering if you noticed if there was a spot for the backup camera input....it looked like it might have been the grey connector with nothing attached....I tend to beleive that there is the ability for this head unit to show the back up camera if attached since the liftback can have the same head unit with back up camera....any insight here would be great!
    Thanks,
    -M
  16. Tycho_Brahe
    Nashville
    I'm just not sure. I remember from the manual for the stereo it mentioned that you could also see a display of what the air pressure was for each tire. When I asked my salesman about that he said that feature ( and the backup camera ) only came on really expensive cars. So, since the manual mentions it I assume the radio must have the ability ( hence the connector ) ?
    One thing I notice is that people debate whether to change the speakers first ( or at all ), the head unit first, an amp first. Honestly, I have no clue and the more I read the more confused I get because there are a lot of people vouching they did it their way and it worked out for them. All I know is I was not ready to replace the head unit and did what I could to make the quality acceptable - at least for now. I remember right after I replaced just the front speakers and nothing else my wife was very impressed with the sound and we both wondered if I should even do the rest. But since I had already bought the amp and started working on the subwoofer I wanted to proceed. I do wonder ( and am tempted ) how much a new head unit would add to what I already have. If only there was a magic switch I could use to tell - just for a few minutes. Also, lots of people say just adding an only amp will help the sound. I am guessing that a new head unit has a much better amp than stock ( though still not as good as a dedicated offboard amp ) and is part of the reason for the better sound. But a nice EQ built into the head unit sure would be a nice thing to have.
  17. Surrylic
    Surrylic Junior Member
    122
    Winchester VA
    I'm wary (that the right word?) of installing a whole new head unit... I like what came with the car for the most part. My favorite feature being that I have my phone connected via bluetooth for talking on, and my old iPhone (that's just an iPod now) connected via bluetooth for Podcasts (I do this so the podcasts I listen to delete automatically after being played and new ones automatically download via Wifi). I also have an old standard iPod connected via USB for music... Did that all make sense? My android phone I carry with me, my iPhone never leaves the car, and my iPod only comes in when I need to update new music on it.
    But I would like much better sound quality, so I think I'll be upgrading the speakers alone. Looks like you did an ace job OP, it's out of my league so I'll be having someone else install for me but man I hate paying the labor cost haha. If you don't mind me asking, how much did all of this cost? If the front speakers made enough of a change that you debated on whether or not to even do the rest then I may just buy those to start with. Thanks for all the trouble you went through to photograph it all :)
  18. Tycho_Brahe
    Nashville
    You're welcome. About $500.00.
    After all is said and done I would say that eliminating road noise would be the next best thing I could do with my setup. I notice that the stereo sounds so a lot better when the car is idle ( even at high volume I can notice that effect.) I didn't think the C had that much noise until I started to scrutinize and tune my new system. How to go about that I really don't know. Not sure exactly where the most road noise is coming from ( hatch ? doors ? floor ? ). The expense would probably be out of my league. I do find myself frequently wondering how a new head unit would improve what I have now.
    As for the cost: I could only afford low to medium quality stuff but here's what I had to buy:
    • Alpine MRX-F30 amp for $170.00
    • Dynamat door kit for $26.00
    • JBL GTO804 subwoofer driver for $60.00
    • Speaker terminal spring clip for $4.00
    • 60 ft 18 gauge Speaker wire $13.00
    • 75 ft 24 gauge speaker wire for $6.00
    • 3/4 inch 2 ft X 4 ft MDF board for $11.00
    • Speaker / auto carpet for $9.00
    • Spray on adhesive for $8.00
    • Boston Acoustics 6.5 inch component SC60 speakers for $150.00
    • 8 gauge amp wiring kit for $35.00
    • 100K dual ganged audio taper volume control pot for $4.00
    • Silver knob for $3.00
    Total: approximately $500.00
    I think that amp family might be in the process of being replaced by a newer model and can be found for a good price. I'm unsure if the tiny bit of dynamat did a thing to help but I just wanted to be sure the area around the front door speakers didn't rattle.
    I did go to the hatch area this week and installed thin foam weatherstripping around the backside of that oval plastic piece on the hatch. From the inside back seat I could tell that it was rattling with the subwoofer sometimes. I need to open the passenger door up and eliminate a rattle there as well.
    Anyway, I'll stress again that I'm not sure what I have is great but I think it sounds very good. Could be better, for sure. After a few more days to get used to it and listen to more CDs I think what was gained was:
    • Minimizing most of the dips/peaks in the frequency response so it's not fatiguing to listen to.
    • Able to listen to louder music which helps to cover up some of the road noise
    • Got a lot more bass, not perfect but relatively clean and level, from the subwoofer ( but lost some from the front speakers ), so overall the music is fuller and more enjoyable
    • Able to adjust the bass quickly with a knob. This really comes in very handy since FM stations and my MP3s vary so much from song to song or station to station.
    • Midrange and highs are much more clear. Before I often couldn't hear much vocals in some songs ( I tried adjusting the EQ ).
    • Stereo sound stage opened up quite a bit and the dynamics improved
    Cons:
    • The expense and time.
    • Loss of hatch space.
    • Some FM stations are somehow just have an annoying mix of bass ( or maybe it's my crappy new system doing something ! ) and I have to turn the bass knob way down.
    • Probably some minute level of gas mileage lost due to higher power drain, plus when I'm ever parked in my car in accessory mode I wonder if I'm going to drain the battery ( I sometimes just leave the car turned on )
    • I'm probably never going to resale the car but did I affect the resale value ?
    • I'm constantly tweaking it and wondering if the quality is really as good as it could have been had I gone another route ( head unit ) or chosen different speakers. I think I'd like the car stereo to sound as good as a good set of headphones and this is probably very unrealistic mainly because of the response curve ( transfer function, whatever they call it ) of the car's interior.
  19. actiondonkey
    actiondonkey Member
    91
    30
    My .02 is swap the head unit. I swapped the head before swapping speakers and the improvement in sound quality on the stock speakers was shocking.
  20. Surrylic
    122
    Winchester VA
    Interesting.. eliminating road noise has crossed my mind, but I never realized it affected the quality of my sweet tunes! And thanks for all the info in the quoted post btw, super helpful!
