Chevy Volt = Hens' Teeth
Discussion in 'Chevrolet Volt' started by dbcassidy, May 12, 2012.
  1. scottf200
    scottf200 Member
    220
    61
    Chicagoland
    The solid grill is one way to recognize it.
  2. Erikon
    Erikon Active Member
    819
    105
    Rochester, NY
    True, and that's how I can sometimes spot them if they're approaching, but it may not be enough for the average person to say that's a Volt instead of a Cruze.
  3. El Dobro
    El Dobro A Member
    7,088
    3,270
    The average driver just about knows what's in their own driveway. ;)
  4. John H
    John H Senior Member
    2,208
    558
    I always see at least one Prii at the gas station I pass on the way home. :)
  5. bisco
    52,186
    i have seen two volts so far. good looking car, i thought they were easy to spot vs the cruze or malibu.
  6. simscottsim
    simscottsim New Member
    Kelseyville, California
    My previous ride was a 2009 Prius, converted (10KWh) PHEV.
    I just got my 2013 Volt, and very happy!..In fact the car, loaded version, only a few thousand more than Toyotas 2013 PHEV Prius. I can do my regular commute (36mi) using zero gas.
    I think the Volt the best choice right now in EV's and PHEVS. The reason I include both groups is: range anxiety, a real problem for any car with range < 100mi.
  7. drinnovation
    drinnovation EREV for EVER!
    2,027
    586
    65
    CO
    Welcome to the Volt family. .. so now you'll see one every day.
    What did you do with the PHEV converted Prius?
  8. simscottsim
    Minimally, I do think they are a lot more common in CA.
    Looking like the PHEV Prius will be picked up next week, have deposit...good deal for him, a loaded Prius for 16K. Have close to 50K into it. The bms on the large pack does need some tweaking, lately have been getting only around 3KWh out of it. Cell health is good. The buyer has close links to an EV modifying business, so it will be in good hands.
