Anyone replace the steering Wheel?
Discussion in 'Prius v Accessories and Modifications' started by tanasit, May 11, 2012.
  1. tanasit
    tanasit Member
    399
    60
    Philadelphia
    I saw several from the other Prius but V.
    I am just about to replace mine but have a question.
    In stead of removing the battery terminal, can I just remove the SRS airbag fuse?
    It is on page 416 of the manual and the fuse location is #28.
    Thanks,
    PS. If I have to remove the battery terminal, I will try not to forget and close the trunk!!
  2. anewhouse
    anewhouse Active Member
    191
    105
    CNY
    Re. a replacement steering wheel - check out this post. (This poster says he used a leather-wrapped wheel from a standard Prius and it was an easy swap.)
    Hadn't heard about this - what's the issue here? Trunk gets stuck without battery power? Educate me! ;)
    Andy
  3. tanasit
    tanasit Member
    399
    60
    Philadelphia
    That is the wrong link you sent.
    You can NOT open the trunk, if the battery terminal is removed! Another words, the trunk is electronic powered open from the outside. Otherwise you have to climb over the rear seat, open the rear panel behind the license plate and manually open it.
  4. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,518
    Santa Fe, NM
    Disconnect the 12V. It is safer.
  5. anewhouse
    191
    105
    CNY
    Link still works for me - look about 1/3 of the way down the second paragraph. Quoted, just in case it still doesn't work:
  6. res00ges
    res00ges Junior Member
    seattle, wa
    What kind of used steering wheel you replaced with? where did you get it?
    Thanks
  7. tanasit
    tanasit Member
    399
    60
    Philadelphia
    JDM Steering Wheel
    Nigel has about 10 more Piano Black color arriving in a week or two. 5 Standard and 5 Sport.
    All of them will be available to ship out next week.
    $210 shipped in 48 states. I want the white silver as seen below but he needs 5 people for group buy..:(:(
    Sport version with thumb rest at 3 and 9 o'clock.
  8. umichioe
    umichioe Junior Member
    77
    Plan to swap with the OEM Softex steering wheel of 2012 Prius.
  9. ZPriusv5
    ZPriusv5 Junior Member
    74
    Cincinnati, Ohio
    where did you find the OEM wheel?
  10. umichioe
    77
    Toyota Dealer. I actually can order the real leather one (2010, 2011 Prius). Still thinking.....
  11. antech5
    antech5 Member
    160
    I use a leather steering off of a 2010 prius that I found on ebay, I just swapped everything over , it all bolts up.
  12. koipond
    koipond Member
    198
    40
    thinking of doing this same thing for my Prius C (which also seems to share the same wheel as the V etc). I'd love the "SofTex" wrapped wheel if possible. Where exactly can one fine a "Toyota Dismantler" to get one used?
