Aftermarket Wheel Thread
Discussion in 'Prius c Accessories and Modifications' started by SSG S, Apr 27, 2012.
  1. whtrabbitjoe77
    whtrabbitjoe77 Junior Member
    S Lehigh Co PA
    could you post up some pics?
  2. daboy
    daboy Junior Member
    51
  3. ianblake
    ianblake Junior Member
    53
    PR
    i want to see the Scion IQ wheels on the Prius C
  4. Shovelwill
    Shovelwill New Member
    Front range of Colorado
    17's on my ride, still have good mileage (low 50's) and runs good. Can't tell you how may folks come up and ask what car it is. :D
    Wheel Brand Drag
    Wheel Model DR33
    Wheel Weight 14 lbs
    Size17x7
    Offset 40MM
    Tire Size Continental 205/45/17
    Tire Pressure Monitors YES, NO ISSUES
    Difference felt in ride quality: Handles better, more fun to drive
    Fitment Issues NONE
  5. Melissa5588
    Melissa5588 New Member
    Tampa Fl
    They look good but you may want to correct your specs.. you wrote the specs for the 15 inch
  6. Shovelwill
  7. kkim
    kkim Active Member
    386
    132
    kauai, hawaii
  8. gas sipper
    gas sipper Junior Member
    31
    texas
    i was told at the dealership today that id have to have a zero offset if i changed my rims because of the way the prius has tires to avoid rubbing is this true?
  9. Surrylic
    Surrylic Junior Member
    122
    Winchester VA
    These look great, nothing crazy and goes perfectly with the style of the car. My favorite type look great but don't stand out like HEY LOOK RIMS I GOT THEM. Good choice I might copy :p
  10. mattebury
    mattebury Junior Member
    70
    Southern California
    What I've been looking for, and this is harder than I thought, is I just want to swap the 15" steel wheels and plastic covers with 15" chrome rims. They are really hard to find.
  11. Angel Natal
    Angel Natal Junior Member
    53
    Arecibo, Puerto Rico
    I
    New release by Konig "Turn One" and they come in 15'' x 6.5''
  12. Surrylic
    122
    Winchester VA
    Agreed.. zero that are the same width and very very few as small as 6"
    Found anything you like yet?
  13. mattebury
    70
    Southern California
    I found these at Tire Rack that use the same size tire 165/65-R15.
    Never heard of the Platinum brand
    Surrylic likes this.
  14. mattebury
    70
    Southern California
    Just heard from a guy at Tire Rack. He says that these rims are too wide for the stock tires. Looks like I'm back to square 1 in trying to find new rims that'll allow me to keep the stock tires. I want chrome (real chrome and not chrome or silver paint) and I'm too cheap to buy both new rims and tires when I have a perfectly good set that's only got 200-ish miles on them. Maybe if I show up at Discount Tire on a slow afternoon and tell him I want a 15x6.5 (at least that's what I think the stock rims are) rim with a 4-100 bolt pattern and have him show me what he can find. He says that the stock tire won't fit on anything wider than 6".
  15. GraeSack
    GraeSack New Member
    30
    Lacey, WA
    Mattbury, if you don't mind the holes in the rims, the Scion XB has 15X6 steel wheels that I think will fit. There are several "near chrome" powder coats that look about as good as chrome, for much less money. If you want a more "old school" chrome rim, that may be tough to find.
  16. GraeSack
    GraeSack New Member
    30
    Lacey, WA
    On another note, carefully consider wheel weight and how it's distributed in the wheel. Heavier wheels and/or wheels that have more mass away from the center will degrade performance--although the degredation may be slight. I've always thought any modifications should enhance performance. For the Pc, we're trying to balance looks, handling and MPG. I'm confident solutions are out there--we just need to keep looking.
  17. Dorian7
    Dorian7 Junior Member
    70
    I am really confused about the whole stock tire size debate because on tire rack it says that the recommended size for a 15x6.5" Wheel is 175/65-15...
  18. mattebury
    70
    Southern California
    Same here.
    My stock tires are Goodyear, so I went to their website and they say for that specific tire, the rim width should be 5" - 6"
    I'll go with what they say, not Tire Rack.
  19. Lenwood
    Lenwood Junior Member
    53
    san Mateo ca
    Tire rack was supposed to retract that. Stock tire max with is 6" I went to a 15x6.5 and running 185/65/15.
  20. Dorian7
    70
    Have you noticed any drop in gas mileage from the increase in tire size?
