Denver area junkyard with 04/05 Prius?
Discussion in 'Gen 2 Prius Main Forum' started by narf, Dec 27, 2005.
  1. narf
    narf Active Member
    611
    45
    Colorado
    Four Touring
    In the quest to get rid of all the rattles under the dash, I've accidentally broken the mounting tabs that hold the two halves of the housing for the speedo. This looks to be a real mess to repair so i was hoping to find another part around. I'm heading to the dealer to find out how much a replacement is but I'd rather get one from the boneyard. Anyone in the Denver area know of one with a current generation Prius?
    (On the bright side, I can now have the entire dash removed in under an hour!)
  2. hawkjm73
    hawkjm73 New Member
    258
    Phoenix, Arizona
    While I don't know any junkyards, have you heard of a substance calles Plastex?
    http://plastex.home.att.net/
    I have not used it myself, but a coworker does work on his motorcycle with it. (It is a Honda PC800 - has a plastic shell with lots of fragile tabs.) It is excellent for replacing broken tabs using an included clay bar as a mold. The stuff attaches very strongly to the original piece. Might be easier than replacing the part, or it could be a huge mess. B)
  3. Godiva
    Godiva AmeriKan Citizen
    10,339
    You can also try eBay.
    Occasionally you'll see what looks like an entire Prius being sold piecemeal, except for body parts....I.E. someone took apart a totaled car and is selling the parts that are salvagable.
  4. keydiver
    keydiver New Member
    509
    Hobe Sound, Florida
    I just tried car-part.com, and they don't come up with a Prius in all of Colorado. :blink:
    Searching all states, I did find 2G HV batteries for as low as $450 though! B)
  5. narf
    narf Active Member
    611
    45
    Colorado
    Four Touring
    Thanks for checking. I just ordered the part from the dealer, it might be worth $88.00 to save the hastle of searching cross country for the part.
  6. Tideland Prius
    16,610
    narf, you took apart the dash? I need some help. How do I remove the plastic that surrounds the screen, clock and hazard light button? My dealer didn't reinstall it back properly and now I have a gap in the bottom between the radio and the clock.
  7. Potential Buyer
    Potential Buyer New Member
    287
    Dude, why the hell would there be a new Prius in a junkyard? :) Sure there might be one or two that were totalled in accidents, but good luck finding that.
  8. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Once you've got the vent panels on either side off you should be
    able to access the silver-colored diagonally-mounted bolts on either
    side of the MFD, and remove them. Then the whole MFD module pulls
    out -- it doesn't come easily, but it's on those same non-self-
    destructing plastic clips that many other parts are and will come
    away without eating itself. Then you can realign everything the
    right way before tightening the bolts back down.
    Note that to get the vent panel off that includes the shifter,
    you probably have to pull the lower drivers-side panel and the
    power-button one since they hook *over* it. Cumbersome, but doable.
    _H*
  9. Frank Hudon
    Frank Hudon Senior Member
    4,147
    home all week if you want to come over and we can see what is wrong but it sounds like they didn't put the radio in right. pm me and we can see what time slot is available.
