'04 died & won't restart this morning
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by funkadelic, May 24, 2012.
  1. funkadelic
    funkadelic Junior Member
    San Francisco Bay Area
    i started my '04 prius (~110k miles) this morning, went back into the house to grab a few things, & then I started hearing a loud rattling sound from the engine for a few seconds before the engine died.
    The dash and MFD lite up with these symbols in the attached images.
    I tried to start up the car again & the motor turned on but then the loud rattle sounds started back again and the engine shut down again.
    Looks like I may have to get the car flatbedded to the dealer but does anyone know what this symptom might be indicative of so I know what to expect? The car has been running fine without issue & just filled it up yesterday.
    thanks
    -norm
  2. kamikaze70
    kamikaze70 New Member
    PA
    I suspect it is your small battery. Mine died after 6 years.
  3. kamikaze70
    PA
    That was on my 06 Prius by the way.
  4. funkadelic
    thanks, i found a youtube vid on how to get the car's MFD into diagnostics mode to check the aux (small) battery charge so hopefully it shows it is dying and nothing worse :)
  5. jdenenberg
    jdenenberg EE Professor
    3,953
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
    It sounds a bit worse than a weak 12v battery. Where are you located? There are some great independent Prius shops scattered around the country.
    JeffD
  6. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,519
    Santa Fe, NM
    No, not a main battery or 12V problem.
    First guess would be a stuck shut throttle plate.
  7. funkadelic
    i'm in northern california (Fremont). I just swung by the dealer near my work in my other car with the intention of buying a new battery, but after explaining the symptoms to the service advisor & a tech, they said it sounded more like a misfire and said that a dying aux battery wouldn't cause the engine to shut off after it's started. Ordered a scan tool to pull the DTC codes, so hopefully will get to the bottom of it tomorrow!
  8. jdenenberg
    3,953
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Luscious Garage or Art's Automotive are the good independent Prius repair facilities in Northern CA.
    JeffD
  9. koolingit
    koolingit Member
    158
    51
    Mocksville NC, USA
    Bad gas at the fill up?
  10. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Check your oil level/condition before you do anything else.
  11. funkadelic
    thanks everyone for the assistance. These were the DTCs present:
    P0171 SYSTEM TOO LEAN
    P0335 CRANKSHAFT POSITION CIRCUIT
    C2300 ACTUATOR SYSTEM MALFUNCTION
    C2318 LOW VOLTAGE ERROR
    Dealer ended up replacing the aux battery since it was on its way out (bad cell), but ultimately the reason the car didn't turn over was the crank position sensor (part #9091905045) was dead
    Everything is back to normal now :)
  12. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Thanks for letting us know how it turned out.
  13. Oldwolf
    Oldwolf Prius Enthusiast
    826
    110
    NC
    2016 Prius v wagon
    Very interesting. Glad is wasn't anything too serious.​
