HSI Red Bar
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by andyprius, May 23, 2012.
  1. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    From time to time while driving in EV mode, a red bar is displayed with HSI or Hybrid Synergy Indicator. What is it's purpose? I can't get rid of it, although since I am driving at the time I don't try too hard.:confused:
    Hybrid System Indicator
    52,284
    i have not seen it. i'll be interested to hear more.
  3. iRun26.2
    iRun26.2 Active Member
    824
    169
    United States
    Agreed! I wonder if it could possibly be anything related to indicating what acceleration level will turn on the ICE. I would find that very useful!
  4. andyprius
    2,212
    188
    I am doing extensive EV ing right now since there are chargepoints at my local favorite mall. Both levels 1 & 2. I have on a daily basis driven only EV and do not believe that the PIP has even accidentally gone into HV mode. This red bar mode has come on several times now. :confused:
  5. iRun26.2
    824
    169
    United States
    Are you certain that the engine isn't on in this 'red bar mode'?
    Could you post a picture of what you see?
  6. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Could it be the 124 mile interval turning on ICE that is required when driving in EV mode only?
  7. andyprius
    2,212
    188
    No, not certain, and do not have a camera, I gave up on them.
    As for 124 mile limitation, ? Possibly.
    Next time it comes up I will check it out better
    Apparently, I am the only one in the World getting this......:D
  8. iRun26.2
    824
    169
    United States
    I do not ever drive 125 miles without gas.
  9. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    It's not all at once. I use a little gas due to getting to the charging station after the EV has depleted.:D
  10. retired4999
    2,652
    627
    Eau Claire, Wi.
    My friends 2011 also gets the red bar, I'm just guessing but maybe it has to do with really stepping on the gas and is telling you your not being eco friendly? wild guess!
  11. iRun26.2
    824
    169
    United States
    Which could explain why I've never seen it...:rolleyes:
  12. retired4999
    2,652
    627
    Eau Claire, Wi.
    Thats what I thought! Thus the guess. :)
  13. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    Sounds like you've activated "power" mode, for lack of a better description. It means the gas engine is running at higher RPM's and you are demanding a lot of electricity from the battery. In fact, it says "PWR" under the bar. Pages 268 through 270 in the manual explain what everything is. If the red bar has come on, you are not driving in EV mode at that point.
  14. retired4999
    2,652
    627
    Eau Claire, Wi.
    Thats why I have never seen it! :D Thanks!
  15. andyprius
    2,212
    188
    Possibly, to clarify: On trip A, the top heading bar " Hybrid System Indicator" is back lighted in red. Coming home from lunch today it happened twice and then shut off by itself. In EV mode the entire time. I drive extremely conservatively, keeping the acceleration bar always at one half or below the ECO point.
  16. devprius
    devprius /dev/geek
    979
    291
    If you are seeing a split display that has EV and ECO both listed, you are in HV mode, not EV mode.
  17. andyprius
    2,212
    188
    I was, am, always have been, will be in EV MODE. I am not speaking of the indicator bar, but, the words above, are highlighted in red, specifically, " HYBRID SYSTEM INDICATOR " :confused:
  18. andyprius
    2,212
    188
    NO!
  19. bisco
    52,284
    wow, what a mystery! where's clouseau when you need him?
  20. CharlesH
    2,797
    1,164
    Roseville, CA
    My wife reported seeing this just once, and asked me what was going on, and like everyone else here, I was clueless. I myself have never seen this. She specifically said that it was the background for the "HYBRID SYSTEM INDICATOR" words, not the bar graph under the words.
    We are conditioned to treat things in red as a trouble indicator, thus the concern.
