Max MPH in EV mode?
Discussion in 'Prius v Main Forum' started by jcmccain, May 25, 2012.
  1. jcmccain
    jcmccain Junior Member
    Boston
    When I first started driving my Prius V in November, I was playing with the EV mode. I am pretty sure that I was able to get up to 25mph before it clicked out of EV mode. After my first oil change at the dealership, I tried the EV mode again and now I can only get up to 10mph in EV mode. On my 2nd trip to the dealership, I asked if they'd changed anything and they said they hadn't. They also said that that was not an option they could adjust. Has anyone else had this experience? What speed does your EV mode disengage at?
    Thanks in advance!
  2. Erikon
    Erikon Active Member
    819
    105
    Rochester, NY
    Untill your engine temp is over 155 degrees it'll limit you to 10mph.
  3. Priuswagon
    Priuswagon I love my Prius
    112
    Kingston Washington
    I bought my Prius V in November too. :)
  4. jcmccain
    Boston
    Thanks Erikon. That makes sense. I force EV mode so infrequently, that I wouldn't have noticed that.
  5. Andrewlcox
    Andrewlcox Junior Member
    68
    Decatur, Illinois
    I was doing 38 mph on a flat road last night. Almost couldn't believe it. I watched my EV and lost some speed on a small hill and by accident blipped the throttle and then the engine turned on.
    Andy
  6. Wanderer
    Wanderer Hybrid neophyte
    366
    39
    Cold country
    I don't think I've ever run in straight EV via button but in Eco and normal I can EV to 46. I switch over at 47 even if coasting. Not sure if it helps but...W
  7. ghosteh
    ghosteh Member
    146
    57
    Illinois
    Same here. Driving in normal mode, I can (sometimes) get up to 45mph before the ICE will kick on.
