Part Found in my Prius C III
Discussion in 'Prius c Main Forum' started by ROLOPR, May 23, 2012.
  1. ROLOPR
    ROLOPR Member
    441
    95
    Puerto Rico
    When I bought my Prius C III, I found in the Trunk the following parts in a plastic cover. I asked the dealer about this, and nobody can answer that. Any idea what is this??
  2. macmaster05
    macmaster05 Senor Member
    4,050
    730
    Looks like a left phalange.
  3. macmaster05
    4,050
    730
    It could be a tool left behind by one of the Toyota workers who assembled the car. In the assembly line, workers sit in the trunk facing out and tweak stuff. Take a good whiff of it and tell me if it smells like hard-earned Japanese sweat.
  4. HaveNoCents
    HaveNoCents Conservative Tree Hugger
    299
    48
    Crystal Beach, Texas
    It looks like a jig.
  5. orangenerd
    orangenerd Junior Member
    58
    Lawton
    I had the same parts and was wondering the same exact thing. Mine was wrapped and sealed in a dark blue plastic bag...looks like it was meant to be installed
  6. Yotabig&mini
    Yotabig&mini New Member
    Maryland
    The parts you found are the front wheel air dams. They come in a bag and are in the trunk at time of pdi. There is a left and right indicated by a L and R and 4 screws. They go in 2 holes on each side in front of the front wheels in the splash shields. Usually are put on during pre delivery inspection. Hope this helps
    4 people like this.
  7. ROLOPR
    ROLOPR Member
    441
    95
    Puerto Rico
    Do you installed? Have photos?
  8. TC400
    TC400 Active Member
    751
    169
    Pittsburgh, PA
    Better than finding a rusty razor blade!
    I have no idea what those are
  9. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    If they are the air dams for the front wheels, you need to have them installed. Else, your aerodynamics will be hurting on the highway and MPG won't be as high.
  10. ufourya
    ufourya We the People
    1,258
    336
    42
    I found the same parts. The left one has the part # 53852-52180
    I have temporarily misplaced the right one.
    I have found ONE place so far that identifies the part #.
    https://www.usatoyotaparts.com/index.php?i=2&type=parts&partnum=accept
    It identifies the part as ... pad, fr wheel opening.
    So it appears Yotabig&mini is correct. I'll try and find the holes and install tomorrow.
  11. ufourya
    1,258
    336
    42
    In the light of day, that is exactly what the parts are. Thank you very much for identifying them.
    The first photo shows the openings that the tabs slide into. (passenger side). Second photo shows installed driver side from front of car and the third shows installed part looking toward the front of vehicle.
  12. ianblake
    ianblake Junior Member
    53
    PR
    just install mine .. thanks
  13. orangenerd
    58
    Lawton
    just put mine in
  14. ROLOPR
    ROLOPR Member
    441
    95
    Puerto Rico
    I will installed this weekend, thanks.
