Safely Disconnecting High Voltage System
Discussion in 'Generation 1 Prius Discussion' started by theSaj, May 30, 2012.
  1. theSaj
    theSaj Junior Member
    25
    Pennsylvania
    2002 Prius
    Does anyone have a link to a decent "How To" on how to safely disconnect the HV system?
    (We have to replace our transaxle.)
    How long should one wait after disconnecting before beginning to work. My understanding is that you have to give it a bit of time in order to drain internal capacitors.
    Thanks!
  2. electrontechnik
    117
    31
    Take a look a this emergency response guide for some pointers. Good luck with your transaxle replacement! My transaxle was replaced by the previous owner 10k miles before I bought it.
    https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CHsQFjAA&url=https%3A%2F%2Ftechinfo.toyota.com%2FtechInfoPortal%2Fstaticcontent%2Fen%2Ftechinfo%2Fhtml%2Fprelogin%2Fdocs%2F1stprius.pdf&ei=aNrGT7uLE4XZgAfajY2ACw&usg=AFQjCNGeo2xpQY3JHnCGR1xkUsKl10U1Wg&cad=rja
    Are you putting in a new or used transaxle?
  3. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    735
    Boulder Hybids, Boulder, CO
    Pull the orange plug from the HV battery, disconnect 12V, wait 5 minutes. Now impossible to get hurt from electricity working under the hood.
    If using a used Gen1 tranny, make sure it's "known good" from a knowledgeable supplier. Plenty of Gen1's are in the junkyard because of tranny issues. Also, who diagnosed the car? Shops (even dealers) often mis-diagnose Gen1s and you may need more/less than the transaxle. Most common tranny failure is MG2 burnt windings. Once the inverter is exposed remove the MG2 leads and test with a Megger (Meg Ohm Meter) or at least a simple multimeter. If you have close to zero resistance between any of the three orange leads and ground MG2 is toast.
    usnavystgc likes this.
