Changing out the footwell lights
Discussion in 'Gen 3 Prius Accessories and Modifications' started by AZGeek, May 31, 2012.
  1. AZGeek
    AZGeek Semi-informed Member
    627
    144
    63
    Arizona
    Well, this is not going to be as easy as simply swapping out bulbs. The existing LEDs are in a custom housing and have resistors in the electrical path. Here are some images of the unit I pulled out from the passenger side. Any EEs out there with some suggestions?
  2. Big Steve
    Big Steve ramblin wreck
    402
    39
    Richmond VA
    Looks like more than a resistor in circuit too.
  3. HI MPG
    HI MPG Active Member
    789
    133
    93
    Orange County, CA
    It's amazing you even cracked that thing. I couldn't figure it out.
    Is the color temp still amber? Are you looking to change to white? If so, I may have an easier solution for you.
  4. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    There's a thread in the Gen3 main forum where a guy found a Lexus part, same part, but with a white LED. I think it was from a ES350.
    Footwell lighting??? | Page 2 | PriusChat
    I see you posted in that thread.. so are you trying to do something different than just white LEDs?
  5. sLick415
    sLick415 Member
    214
    55
    San Francisco, CA
    Ive been trying to find one with a blue led but no luck..
  6. AZGeek
    627
    144
    63
    Arizona
    I want blue to match the illuminated door sills and courtesy LEDs I have in place now.
    2012 Mods | PriusChat
    I just put in an order for a variety of LED bulbs / fixtures to see if I can find something that works. My concern without seeing the output yet is how bright these will be --- I am looking for something perhaps only a bit brighter than the original foot well intensity.
    At least I now know where to tap power to get the rear seats illuminated.
    new iPad ?
  7. walter Lee
    1,126
    376
    Maryland
    On the sixth and last photo, the electronic component in the center next to the LED is a diode. A diode is used to keep the electricity going in one direction - this means the LED is a uni-directional LED and is suppose to get its electricity in one direction ( if that is not obvious by now).
    The electronic component to the left of the diode is a resistor which lower the current level of the electricity before it passes through the LED. The bands on the resistor white-brown-brown-gold describe its rating <band1><band2> x 10 ^ <band3> ohms with an error accuracy of <band4>[1] The color scheme for the first three bands is describe by an old engineers mneumonic device.
    bad = black = 0
    boys = brown = 1
    rape = red = 2
    our = orange =3
    young = yellow =4
    girls = green = 5
    but = blue =6
    violet = violet/purple = 7
    gives = grey =8
    willingly = white = 9
    the last band, band4 is described the tolerance/error of the resistance
    with the most common designations as follows:
    <no band> =20% error tolerance
    silver = 10% error tolerance
    gold =5% error tolerance
    for example the resistor band in your photo is white brown brown gold
    91 x 10^1 ohms @5% error = 910 ohms @5% tolerance.
    It's likely that the wiring/current goes on a simple serial path the positive prong/lead - resistor - diode - LED - ground/negative prong/lead. Manufacturing wise I would guess that the ground lead of the diode and a lead from the negative prong are threaded into the metal casing up through the LED housing and through the LED light view port, then the leads are soldered/connected to the LED, then finally the LED is pushed down into light view port. To take the LED - you would poke a screwdriver/thin blade like tool and crowbar/lever/pop the LED out from its viewport opening.
    hope this helps
    Walter
    [1] Electronic color code - Wikipedia, the free encyclopedia
    WE0H likes this.
  8. Skuits
    Skuits Junior Member
    69
    Did anyone crack this nut...? I too would like to get some blue LED's and use the factory mount setup.
    Thanks,
    Mark
  9. Burna J
    1,069
    3,338
    53
    Long Beach, CA.
