2010 Toyota Prius model II Head Unit Upgrade
Discussion in 'Gen 3 Prius Audio and Electronics' started by spiderman, Dec 24, 2009.
  1. drew935
    drew935 Member
    168
    Nor Cal
    Thanks Kumatae. I wired it up today as saw what you're referring to.
    It only blinked once and then went off. I reset it twice and tried to reconfigure it based on the instructions but it didn't work. I'll try again. Luckily, my client isn't too worried about the SWC working at the moment as he is loving the rest of the system upgrade.
    Shell 8215 says thus.
    Pin 6 - I grounded to the radio ground. I thought that this would be sufficient.
    Pin 7 - Green/ orange from the ASWC
    Pin 8 - Black/ Green from ASWC
  2. kumatae
    kumatae Member
    101
    So Cal
    2014 Prius v wagon
    Yeah that should have done the job. Hmmm... After I pressed the reset button, I didn't have to do any configuring, it just did everything on its own. The default configuration is most useful in my opinion. Getting the ASWC and mounting the deck properly with minial gaps was by far the hardest part about this install. I could probably tear apart the dash in less than 3min flat and have the radio out in 5min. Hope you get it to work!
  3. drew935
    drew935 Member
    168
    Nor Cal
    I hope that's it. I'll give it a go when I get the car back for lowering. The kit that was provided was straight forward and very easy to install with no gaps. Yes, it's a 2min tearout to get the HU out :D
  4. cerede2000
    cerede2000 New Member
    Hello,
    I'm looking for a guide to remove the door trim to access the front speakers.
    Thank you :)
  5. hbpb
    hbpb Junior Member
    Has anyone replaced the 2012 HU and retained all of the steering wheel controls? If so ...., well how do I do this?
    I did a search and couldn't find a definitive answer.
  6. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Which model do you have? Does it have the telephone controls in the wheel?
  7. hbpb
    hbpb Junior Member
    Its the Canadian "Base" model, which near as I can tell is somewhat equivalent to a III.
    It has the telephone controls in the steering wheel on the left side, a touch screen, no navigation.
  8. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    OK, well that's beyond my experience. Hopefully someone else has will have input. It might be good to start a thread with a very specify title.
  9. hbpb
    hbpb Junior Member
    I'm quite certain its the same HU as the US cars, touch screen, no navigation.
    I'll start a new thread.
  10. swaggingprius
    swaggingprius Member
    88
    29
    East Coast
    Thank you so much OP. I went and followed the instructions about upgrading the HU on a model II. I also have a Pioneer, but different model than the one in your instructions (so what?). Had to dremel the brackets to make the holes bigger, and a wee trial and error, got it to fit quit nicely.
    Cheers!
    I owed a pic of the end result.
    I have noticed that the upper left corner seems to sink in a bit more than the right side. I have noticed this on anyone going with this trim. Except for this, I like this so much better than the regular aftermarket solutions.
    spiderman likes this.
  11. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    That is great to hear, glad the instructions were of use.
  12. nikolay
    nikolay Junior Member
    hi need help my mini sd with GPS can't start download unit from china.
  13. tomlouie
    tomlouie Member
    118
    Boston, MA, USA
    2023 Prius
    Does anyone have a copy of the documents from the OP? When I try to look at the docs via the links, the files are corrupted.
    Thanks.
  14. Aleman
    Aleman Junior Member
    Philadelphia
  15. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I will check on the links today in the original msg. thanks
  16. lenny1jz
    lenny1jz Junior Member
    26
    sd
    Thanks for the PDF. My install went flawless with PAC SWI PS
  17. MikeInOrlando
    MikeInOrlando Junior Member
    32
    Orlando, FL
    I read your information on installing the dash speakers and had a couple questions.
    1) Can you explain in dummy terms for me why additional bass blocking is necessary?
    2) Doesn't the factory blocker block too wide a range of sounds from the speaker?
    3) Do you know if any other 3.5" speakers fit as easily as the Pioneer ones?
    4) Thanks for all the awesome detail in your post!!!!
  18. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    There are a bunch of documents. Where are you reading about bass blocking?
  19. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    1. In this case it is a simple capacitor that essentially cuts the lower range energy (bass) to that squawker.
    2. Probably and when the speaker is replaced, the blocker goes with it (attached). Most head-units come with high and low-pass filters programmed in.
    3. There are quite a few, but all will likely take some modification. Someone on here was able to put in a 4". Infinity, Quartz, Hertz to name a few good options.
    4. You are most welcome.
  20. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    All the documents worked (downloaded) for me.
