HOW-TO: Rear Door Panel removal
Discussion in 'Prius c Technical Discussion' started by SquallLHeart, Apr 11, 2012.
  1. SquallLHeart
    SquallLHeart The Techie Guy
    826
    247
    San Jose, CA
    another helpful how-to:
    OldNo7 and iamthegoddamnbatman like this.
  2. dj45639
    dj45639 New Member
    LA
    Awesome! Do you have a good method for removing the armrest base panel?
  3. SquallLHeart
    826
    247
    San Jose, CA
    some plastic panel removers are good for getting enough leverage.. flathead screwdrivers can also work fine, but you need to be more careful not to mess up the plastic
  4. dj45639
    dj45639 New Member
    LA
    thanks, ended up using an old credit card I had lying around. Worked pretty well.
  5. Silver101
    Silver101 Junior Member
    NC
    What's wrong with the pictures? I cannot see them.
  6. SquallLHeart
    826
    247
    San Jose, CA
    ack!!.. the forum change jacked up my links.. um.. lemme try to fix that.
  7. Silver101
    NC
    Nice! Thanks!
  8. Oldwolf
    Oldwolf Prius Enthusiast
    826
    110
    NC
    2016 Prius v wagon
    Interesting. Why are you guys removing the panels?
  9. Silver101
    NC
    I am thinking to install additional speakers in my PC 1, which does not have rear speakers.
  10. Oldwolf
    826
    110
    NC
    2016 Prius v wagon
    Does the PC1 have rear door speakers though?
  11. Silver101
    NC
    That's what I meant. The PC1 does NOT have rear door speakers, but the grills are there.
  12. los panda
    los panda Member
    155
    has anyone removed a door entirely?
  13. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    thanks, this is great info! i need to get rear speakers soon!
  14. EC15Prius c One
    EC15Prius c One New Member
    San Francisco
    2015 Prius c
    Do you know how to remove the front passenger side door panel? Thanks~
  15. Bethtown
    Bethtown New Member
    Cali
    Don't meant to sound dumb but I am new to this. Both of the info sheets start at step 4 in my phone. Not sure if it is bc of the mobile site or if that is where they start. Could someone either post a link to the full data or send me a copy of it to my email. I would so appreciate it.
    As for why u need to take it off, there is a common problem with the door lock actuater motor going out. Causes the doors not to lock or unlock although the front one will unlock with my key and the others will work if I use the manual lock. To replace the entire thing is 150 per door min. But u can get the motor for5-10 online. Need to try and fix it. If your car is under warranty and door locks aren't working take in before warranty expires.
  16. SquallLHeart
    826
    247
    San Jose, CA
    they start at step 4. i believe steps 1-3 were something unnecessary like disconnect your battery or something and was purposefully omitted.
  17. Jay Chu
    Jay Chu New Member
    Australia
    2014 Prius c
    i-Tech
    Thanks
