2012 Prius HDD Service Menu
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by PRPrius, Jun 11, 2012.
  1. PRPrius
    PRPrius Active Member
    327
    198
    n/a
  2. PRPrius
    327
    198
  3. PRPrius
    327
    198
  4. CharlesH
    2,797
    1,165
    Roseville, CA
    Did I miss what the issue is you are having that sent you looking for diagnostic info and ultimately a new head unit?
  5. Totmacher
    Totmacher Honey Badger don't give a carp
    301
    110
    Mission Viejo, CA
    looks like the answer was "we don't know so we will throw a new unit at it and see if that works"
  6. PRPrius
    327
    198
  7. CharlesH
    2,797
    1,165
    Roseville, CA
    I wonder what they mean by a "RAM lockup" :confused: I work with computers, and I am not familiar with that term. I know about disk hangs when there are physical problems with the hard drive (which could possibly be relevant for the HDD unit), but I have never heard of memory hangs.
  8. jabecker
    jabecker driver of Prii since 2005
    448
    78
    Portland, Oregon
    If it's trying to address RAM that's defective or otherwise bad, it could certainly cause a crash or a hang.
  9. CharlesH
    2,797
    1,165
    Roseville, CA
    Makes sense. In my experience, bad memory tends to lead to outright crashes. But my work is with servers and the like, not embedded systems like these head units, so maybe they respond differently than the "big" systems to memory errors.
    Sometimes when I start the car, it takes a couple of minutes for the map to pop up. I can get to all of the non-NAV screens just fine and without delays, just not the map. I wonder if something is flakey with MY HDD :confused:
  10. benagi
    benagi Active Member
    525
    280
    Utah
    My Prius v 5 with atp went in because the nav system quit working after 3 months. I can see the map but the gps part of the nav is completely down. Zero signals from the satellites. Service also told me they have to order a new head unit. Been 3 weeks, still waiting.
  11. Teo2255
    Teo2255 New Member
    Md
    Is any posibility anybody know how to open hidden menu properly and the camera settings
    On prius V trim 5
    #11 Teo2255, Sep 20, 2019
  12. bisco
    52,484
