Radio on/off switch
Discussion in 'Gen 2 Prius Technical Discussion' started by bogeybob513, Jun 7, 2012.
  1. bogeybob513
    bogeybob513 rtc513
    147
    Myrtle Beach, SC
    Can't turn off the radio. I know I can just keep it low, but would appreciate if someone knows how to replace the switch.
  2. kwasmart
    kwasmart cool member
    chiacago
    unplug the negative on the 12v and it will turn off. then restart by putting it back on. I have 2004 prius w/ 212k miles and it sometimes does that. keep driving.Martin
  3. bogeybob513
    bogeybob513 rtc513
    147
    Myrtle Beach, SC
    Thanks. The darn thing just reset itself after a few days!
  4. Oldwolf
    Oldwolf Prius Enthusiast
    820
    110
    NC
    2016 Prius v wagon
    So the problem is not a faulty mechanical switch?
  5. bogeybob513
    bogeybob513 rtc513
    147
    Myrtle Beach, SC
    I haven't ruled it out. Waiting for it to happen again.
  6. FirstFlight
    FirstFlight Member
    429
    77
    New Jersey
    I assume you tried to press the power button when attempting to power off the radio. If you have radio controls on your steering wheel, try pressing and holding the "mode" button. I think it should turn off after 5 seconds.
    If the above doesn't work and you don't have the money to either fix it or buy a new one, I'd pull the radio out and cut the -12V wire and put a switch in. You could also try pulling the fuse. Don't quote me on this but I think the radio is on the dome light fuse, which is a 15A fuse.
