Engine revs up before shutting off?
Discussion in 'Prius c Technical Discussion' started by Allison C, Jun 11, 2012.
  1. Allison C
    Allison C New Member
    Lancaster, CA
    My gas engine seems to rev up right before shutting off and transitioning to EV mode. Is this to make sure there is adequate fuel ready for immediate demand when the gas engine starts again? Or does anyone know the reason for this or if it is normal? Thanks.
    minkus likes this.
  2. Oldwolf
    Oldwolf Prius Enthusiast
    825
    110
    NC
    2016 Prius v wagon
    My C is always in EV mode when I shut down so I don't even hear the ICE. Are you shutting down with a cold engine or a HV battery in a low state of charge? That might explain what you are hearing.
  3. Allison C
    Lancaster, CA
    It's not at shutoff, it's normally when I stop at a traffic light and after a second the ICE shuts off, but before it does it always seems to rev up before it enters EV drive. I think the battery is normally at least 50% charged. I think it probably does the same thing if I am setting in the parking lot, when the battery gets low and the ICE kicks on, it revs higher than you would think (more than a typical gas engine at idle), but it shuts off in a couple minutes once it gets a little more charge. Maybe the ICE charges the hybrid battery more efficiently at a higher engine speed. Not sure...
  4. SquallLHeart
    SquallLHeart The Techie Guy
    826
    247
    San Jose, CA
    well.. yes.. but most times when i hear the ICE really rev up when i come to a stop is when the ICE is still cold.
  5. BrunoPuntzJones
    107
    28
    Normal for mine. Pull up to red light, engine revs, then shuts off.
    Dylan Murphy and RocMills like this.
  6. chicagoaficionado
    chicagoaficionado Junior Member
    57
    Chicagoland
    I just noticed the same thing after more than six months of use. I'm assuming its normal? Is there any follow up with this?
    The RPMs rev up right before the car transitions into EV mode when still moving. Any new insight out there?
  7. minkus
    minkus Active Member
    369
    125
    Cleveland, OH
    I've also noticed this, so it seems to be normal. I'll pay more attention to see if it happens more when the engine is cold. Not sure about the reason why.
  8. MotorcycleGoat
    MotorcycleGoat Junior Member
    51
    I wonder if this is a cut off of the fuel supply. Just a theory, but if the fuel supply is cut to an engine, it will run leaner and leaner until it can't run any more. A lean engine runs hotter and faster...so, that could be what its doing. Cutting the fuel supply as a method of shutting down the ICE and therefore causing a lean condition right before it dies. I experienced this with many a small engine. Lawn mowers, weed whackers and RC cars. Thoughts?
  9. epoch_time
    epoch_time Active Member
    235
    110
    las vegas
    This reving of the engine before shut-off its the fuel injection computer calibrating itself against atmospheric pressure changes ( air
    pressure changes).
    The genIII does this also but not as offen as the prius-C.
    Possible conditions for fuel injection recalibration;;
    Prius driven long distance to a city with higher elevation?
    Prius driven in mountainous environments?
    Drastic weather condition changes?
    All the above could be reasons if precise air fuel mixture is desired.. resulting is less fuel build-up in oil.
    I think this is a wonderfull way to precisely measure air fuel mix (14 to 1) before fuel trim is added or subtracted..(highest engime rpm at idle = precise 14 to 1 air fuel mixture).
    I wish my genII did this more often.. It only does it after disconnecting 12 volt aux battery..
    minkus and chicagoaficionado like this.
  10. I'm glad someone clarified this, I knew it was normal but never understood why
  11. chicagoaficionado
    57
    Chicagoland
    Thanks so much! It makes sense then why it is sporadic.
  12. Jake123
    Jake123 Junior Member
    74
    35
    I think it's a change from sending ICE power to the wheels to sending ICE power to the battery during the second between stopping and shutting off the ICE.
    Petridish38 likes this.
  13. Petridish38
    Petridish38 Junior Member
    I agree. Further, it seems plausible that the revving results from the change from MG1 placing a load on the ICE (battery charging) to no load on the ICE just before the car enters EV mode. If you watch the hybrid system info screen right before entering EV mode, you can see that battery charging is stopped as a precursor to the ICE shutting down. Removing a load (in this case, the load MG1 acting as a generator places upon the ICE) from an engine under load will cause it to rev up. This seemed normal to me from day one.
    minkus likes this.
