Backlight on standard (non-navi) headunit
Discussion in 'Prius c Technical Discussion' started by andrewdenver, Jun 14, 2012.
  1. andrewdenver
    andrewdenver Junior Member
    Denver, Co
    I picked up my Prius C Two yesterday and I can't seem to figure out if the headunit has a backlight in it or how to turn it on if it does. It makes it really hard to see the display at night ( and even during the day ).
    It looks like there are leds behind the LCD in the head unit, from the photos here: LED swap! color change green to blue (in progress) | PriusChat
    Is there some trick to turning them on or should I call up the dealer?
  2. SquallLHeart
    SquallLHeart The Techie Guy
    826
    247
    San Jose, CA
    umm.. are you saying your headunit isn't illuminating at night.. at all?
    yes... the radio has leds for backlighting.. and they most definitely provide lighting so you can see the buttons at night..
    can you tell me in more detail what's going on? maybe interior photos when you have the headlights on.
  3. Iconn127
    Iconn127 Master Diagnostic Technician
    44
    Cameron Park, CA
    to the left of your steering wheel there is a dimmer switch. please try and turn that up first.
  4. SquallLHeart
    826
    247
    San Jose, CA
    ^^ i was thinking that might've been the case..
  5. Iconn127
    44
    Cameron Park, CA
    detailer probably was wiping it down and switched it down to dim. my thought
  6. andrewdenver
    Denver, Co
    That was my first thought as well. It seemed to change the HUD but not the head unit display. The buttons on the head unit got brighter/dimmed but not the display.
    I'll see about getting some pictures after work.
  7. SquallLHeart
    826
    247
    San Jose, CA
    well.. kinda silly... but the display doesn't turn on.. unless the radio is actually on..
    if the buttons on the headunit are lighting up... then by all means.. the illumination circuit to the radio is obviously there.. and working.
  8. andrewdenver
    Denver, Co
    I have it set up to turn on BTA from my phone as soon as the car is on and music does play. So def. not that.
  9. Iconn127
    44
    Cameron Park, CA
    take it back to the dealer, you most likely have a defective head unit. thanks to 3yr 36k mile warranty its no hassle for you minus taking a trip over.
  10. andrewdenver
    Denver, Co
    Just turned it on without much other light. Apparently the back light IS on, it's just really really dim. I guess I'll take it back to the deal and see what they have to say.
    Thanks!
