ebay fog lights set
Discussion in 'Gen 3 Prius Accessories and Modifications' started by kknguyen1168, Jun 16, 2012.
  1. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    hi
    did anybody try this set of fog lights yet? the reason I ask because why it so cheap compare the one we sell in here, are they the same?
    Toyota Prius 2010-2012 OE Fog Lights - Clear | eBay
    Item number: 160797914724
    V/r
    Khoi nguyen
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Well it says it is DOT/SAE compliant so it is probably just as good. Might double check to see if they come with the bezel/surround.
  3. madman
    madman Junior Member
    46
    Los Angeles
    Do note that these do not come with the wiring kit. The same lights and the kit can be found together on eBay.
  4. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    ^^ states in the descriptions wiring harness and switch included. Might not come with a relay or whatever, but that should be all you need. It's also an aftermarket manufacturer so the quality may not be as good regarding the materials.
  5. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    I do not know, from the item description, the bulbs might not even be included in the kit.
    I bought from eBay seller Cosmodynamic and received the kit fast:
    2010+ TOYOTA PRIUS CLEAR BUMPER DRIVING FOG LIGHTS LAMPS+SWITCH | eBay
    It came with everything, you can see a picture in the item description that has the wiring harness, relay, dash switch, wire tap and mounting screws.
  6. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Im gonna say the switch & harness doesn't come with the lights. All listings that I've seen on ebay show a pic of the lights, harness & switch.
  7. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Only one way to find out... ask the seller.
  8. alfa737
    alfa737 Member
    126
    27
    I tried to be cheap and installed these foglights.. here is my experience with them.
    • the plastic is flimsy and does not fit in nice and clean (like OEM)
    • the wiring harness is also of a thinner gauge
    • the switch is of poor build so the green(standby) led bleeds into the area where it shouldn't making the switch partially illuminated even when it is not pushed in.
    • UGGHH!!! the silver paint on the front has started to peel off showing white plastic underneath.
    bad idea for saving some money short term... think long term.
    should have gone with better quality fog lights.
  9. ImeanGreen
    ImeanGreen Prius v Five BP Brigade #236
    547
    73
    Somewhere out there
    OP needs to double check on that. Says DOT/SAE compliant but lens does not tell you otherwise. OP, beware of plastic lens. You always get what you paid for.
    sfv41901 likes this.
  10. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    This is so true
