TTAC on the Prius C and how it has less braking regen than the liftback
Discussion in 'Prius c Fuel Economy' started by dhanson865, Jun 9, 2012.
  1. dhanson865
    dhanson865 Expert and Devil's advocate
    851
    188
    TN, USA
  2. F8L
    19,011
    4,083
    Grass Valley, CA.
    Nice article. Michael Karesh wrote it. :)
  3. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    I read it as "It is more rewarding, but harder to hypermile the c than the liftback"
    It once again stresses how much 'drive it like it had no brakes' should be your first lesson.
  4. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    The first part of the review is a carefully worded putdown of the Consumer Reports test.
  5. cmstlist
    cmstlist Member
    183
    40
    Toronto, ON
    Well if the regenerative braking is most effective below 40 mph... Sounds perfect for my city commute that rarely lets me sustain 60 km/h for more than about 30 seconds before I have to stop for a light or congestion.
    Galaxy Nexus ? 2
  6. PriusCinBlack
    PriusCinBlack Member
    145
    61
    Yup, a very fair assessment. And insightful, too, re the braking.
  7. babybird
    babybird Member
    117
    44
    Colorado
    Reading the comments on the article, it's a bit surprising how little most owners know about how the Prius operates. Then again, I suppose that reflects that many Prius C owners are people who wouldn't have bought a Prius if the C model hadn't been available.
    The only thing the author didn't mention in talking about the regen braking difference between the C and the hatchback is that at higher speeds, or more demanding braking, that shifting to B-mode would help slow the vehicle a bit more without using the friction brakes. It won't charge the battery any better, and in some circumstances (anytime your braking demands don't exceed the battery's regen capability) may charge it less, but if you have to stop from high speed where the C's regen just isn't optimal, then B-mode can at least help save the brake pads a bit of wear. And it doesn't cost anything in terms of fuel since none is burned in most cases while your foot is off the accelerator.
    As far as I'm concerned, vehicle testing should occur in two phases-- one with an apples-to-apples comparison for normal driving so that the consumer can see how a vehicle's performance directly compares to all other vehicles; and another in which the vehicle is tested in the manner for which it was optimized (off-road testing for 4x4, towing and hauling for pickups, hypermiling for hybrids etc.). This way consumers could get a better idea of how much additional potential a vehicle has within its own particular niche of use compared to other similar types of vehicles.
    After all, nobody complains about a Ferrari or Bugatti Veyron being tested to see how fast it does 0-60, 0-100, its top speed etc. even though you'll never be able to use any of that legally on public streets in traffic (one tester who tested the Veyron reported that driving the car at top speed would burn through an entire tank of gas in something like 8 minutes)-- so why would testing a hybrid on a hypermiling driving cycle be such a contentious thing? It really shouldn't be treated any differently than any other specialized vehicle in that regard, and I'm not certain why this isn't completely obvious to car testers and consumer/automotive publications.
    ufourya likes this.
  8. cmstlist
    cmstlist Member
    183
    40
    Toronto, ON
    The only places on my commute where "B" might be effective, there are signs advising me "no engine braking permitted in urban areas" - so much for that!
    Galaxy Nexus ? 2
  9. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    babybird likes this.
  10. cmstlist
    cmstlist Member
    183
    40
    Toronto, ON
  11. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    The jake brakes start about 50 seconds in. Quite distinctive sound.
  12. Oldwolf
    Oldwolf Prius Enthusiast
    825
    110
    NC
    2016 Prius v wagon
    Interesting article.
