Solar Roof Option Question
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by priusincc, Jun 24, 2012.
  1. priusincc
    priusincc Member
    332
    NV
    All those with Gen III solar roof option. Anybody have any problems with sunroof or solar panel cracking/breaking/discoloring/leaking? I haven't looked at one close, I guess it's glass. Just wonder if there are any issues out there.
    Hoping to get 2012 with this option.
  2. Big Steve
    Big Steve ramblin wreck
    402
    39
    Richmond VA
    In three months no problems. I love the solar powered fan keeping the car below frying temperature.
  3. fuzzy1
    10,603
    My only issue is that on the road, my 2012 with solar sunroof feels significantly warmer inside than did the 2010 without sunroof, even with the vent (not AC) running at moderate fan settings. All that black solar thermal collection area on top seems to make a difference. Both cars are (were) the same color, Silver, selected in part to keep down that solar thermal gain.
    Parked in the sun is a very different matter, that forced airflow significantly reduces the inside temperature.
    For inner ear reasons, my sunroof is usually closed at highway speed. Those who keep it open probably won't notice this extra heat.
    I 'warmed up' to having another sunroof, which the spouse strongly desires, in part due to finding and easily fixing the sunroof water leak in the old nonhybrid. It is not meant to be permanently watertight, but instead has a drainpan with drain hoses running down inside the A pillar trim. The hoses shrank with age and pulled off the drainpan outlets, so water spilled directly onto the headliner. Some hose clamps (actually just multiple cable ties pulled extremely tight) now secure the hoses. Internet automotive forums can sometimes be extremely helpful. :)
  4. jabecker
    jabecker driver of Prii since 2005
    448
    78
    Portland, Oregon
    I've had mine for 3 months in rainy Portland, and so far no problems.
    As long as the cover is pulled closed over the sunroof, I don't notice that it's any warmer than my 2005 was. Of course, I don't have that car to compare with any more. If I open the cover and leave the sunroof closed, it does warm up quickly in the sun. But I love having the vents on when I'm parked in the sun.
  5. pjksr02
    pjksr02 Active Member
    534
    227
    Connecticut
    All's well since October 2009. It is likely warmer inside the cabin during the summer, while the sun shines, requiring more use of ac. But, it's also much brighter inside, especially in the winter months, and the window makes the cabin seem larger. I also think the Prius exterior looks better with the solar roof, but I'm biased.
  6. john1701a
    john1701a Prius Guru
    12,833
    5,310
    58
    No trouble whatsoever with mine. I had it for almost 3 years from May 2009 to March 2012.
    Being able to open the roof is fantastic. I still miss that. But then again, my upgrade to a PHV is pretty sweet.
    The fact that the car was always just warm in the summer instead of blazing hot certainly confirmed the solar did the job of cooling. Of course, if you forget to pull out the shade, that works against the effects of the fan.
    JJay likes this.
  7. priusincc
    priusincc Member
    332
    NV
    Thanks all for the input; it was helpful!:)
    I read some other older threads about the sunroof option making the car noticeably top-heavy; and others postulating about slightly reducing the mpg due to reduced Cd. :unsure: All in all, most people like it.
  8. Jenpen
    Jenpen Junior Member
    43
    san Antonio
    I have loved mine. I have noticed a big difference in parking in the hot Texas sun. Most of my cars have had sun roofs my last car a 96 Nissan has had no leaks so I don't think that's much of a problem
    Good luck
    Jen
  9. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Instead of a solar roof, I am a fan of excellent tint, windshield sun-shade, parking facing the sun, and cracking the windows open a bit.
    Oh, and parking in the shade ;)
  10. Tideland Prius
    16,616
    Just a note, remember to close the moonroof sunshade when parked. Even though the moonroof is tinted, it actually has the least heat-absorbing properties of any of the windows.
  11. rpeek2
    rpeek2 Dry Ice Juggler
    149
    MidwayUSA
    smallerDSCN0649.jpg Had a doozy of a hail storm about a year ago. Thousands of $$ in tin and windshield damage. Solar roof and sunroof excaped without a scratch or leakage problem. So, ya they're both made of tough stuff
    Tideland Prius likes this.
  12. rebenson
    rebenson Member
    364
    43
    Suburb of Chicago
    I have had my 2010 Solar roof since May 2010. Have not had any leaking issues (other than operator error... keeping vent open during rain).
    I really noticed the "advantage" when I took my wife's 2009 Corolla and parked it at train station last week.
    The steering wheel was so hot It was uncomfortable holding it...
  13. Tideland Prius
    16,616
    Good to know! I'm always worried what would happen if large hail fell from the sky. I wasn't sure how strong the glass on the roof is.
