Exhaust Heat Recovery optional?
Discussion in 'Gen 3 Prius Main Forum' started by HTMLSpinnr, Apr 30, 2009.
  1. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    I've spotted in more than one manual, coolant specs with and without "optional" exhaust heat recovery. Is this an optional feature not included in some models?
  2. Danny
    Danny Admin/Founder
    7,093
    2,122
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    According to the documentation I have from the press event, it's a standard feature of the 2ZR-FXE, not an option.
  3. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    That would be a criminal thing to remove from Prius I, but I bet it would save some money...
  4. HTMLSpinnr
    5,341
    920
    251
    Right - the fact that they go as far as to specify coolant capacities with and without the system suggests that SOMEWHERE it is an "option".
  5. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Maybe they will not include it in the Prius I ($21,000).
  6. drees
    drees Senior Member
    1,782
    247
    Could be a possibility, but there's no way I'd consider a 2010 Prius without one. On short trips, your fuel economy is going to suck! But who knows, maybe it just brings down the short trip fuel economy to Gen-II levels in which case, a lot of people might consider it to save a thousand bucks.
  7. ronhowell
    ronhowell Active Member
    681
    32
    Cypress, CA.
    Can you show us the documentation you are referring to, Rick?
    Seems strange to offer such a stripped version anywhere.
  8. HTMLSpinnr
    5,341
    920
    251
    Taken from the Owner's Manual currently available @ Techinfo.toyota.com (US residents only):
    Column 1 Column 2 Column 3
    0 Capacity
    1 Gasoline engine
    2 With an exhaust heat recovery system 7.6 qt. (7.2 L 6.3 Imp.qt.)
    3 Without exhaust heat recovery system 6.9 qt. (6.5 L 5.7 Imp.qt.)
    4 Power control unit 2.1 qt. (2.0 L 1.8 Imp.qt.)
    Coolant type
    Use either of the following:
    •“Toyota Super Long Life Coolantâ€
    •Similar high-quality ethylene glycol-based non-
    silicate, non-amine, non-nitrite, and non-borate
    coolant with long-life hybrid organic acid technol-
    ogy
    Do not use plain water alone.
  9. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Sorry to dig this one back up from the grave. I am curious too after seeing the same language in the manual. Does anyone know? Is this by model, or by region (North vs South), etc?
  10. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Maybe the Prius 1 which would be for fleets does not have it otherwise, afaik, all 2-5 in the US have it.
  11. Mike500
    Mike500 Senior Member
    2,593
    767
    I know for sure that my 2012 Prius'v" level 2 has exhaust heat recovery, because they completed a recall on the system, last month.
    It's quite easy to tell if you have it. Just look under the car, and you will see a complicated stainless steel device behind the regular catalythic converter. It has a control valve and a smaller 3/4 inch diameter rubber "heater" type hose connected to it with a two eared hose clamp.
    I've seen pictures of underbodies of Prius models in Japan. They don't have this feature.
  12. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Cool thanks! Not that it is super useful right now where I am at. 105*F. But should help come winter time when I needed the cabin heated.
  13. Mike500
    2,593
    767
    I can't see why any currently made Prius in the US would not have the exhaust heat recovery system. It is more likely than not, part of the pollution control system and certification for the estimated mileage for the car.
    Recovery of the exhaust heat helps the ICE warm up faster and keeps it warm, even when the ICE is not running to keep the emission prorducts low. It's obvious that a cold engine produces more polluting products than an fully warmed up one.
  14. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I may be confused, but I thought it heated the engine to get better emissions, not the cabin.
    Jonny Zero likes this.
  15. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    You maybe right. But the HVAC takes heat from the cooling system to heat the cabin. Having this system is adding another source of heat to the cooling system, rather than blowing it out of the tail pipe.
  16. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    In Japan, all Gen3 Prius (lift back) come with Exhaust Heat Recovery system.
    It is optional for the Prius α (Prius v) and Aqua (Prius c) in Japan.
    Ken@Japan
    cwerdna likes this.
  17. Mike500
    2,593
    767
  18. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    I'll have to look, but my friend with a Prius C thinks his doesn't have it.
    Pearl S has it of course.
    A bit of confusion of reasons to have it , so just remember, the faster the engine warms up, the better your mileage will be. -Side benefit- is more heat in the cabin, faster more efficient defrost etc. This may be more important than mileage here, but I haven't experienced winter with Pearl S yet. DON'T RUSH IT!! ;)
  19. 13Plug
    13Plug Active Member
    581
    105
    2013 Prius Plug-in
    Does anyone here have or know where I can get a diagram of how the system works? I'm thinking like a Toyota Parts website. I know some coolant passes through part of the exhaust, I'm just trying to visualize it. Is there a valve or does the coolant always run through there?
    Looking forward to testing out the system when I get my Gen3 Prius. My Gen2 Prius takes a while to warm up in the winter when it's -35 LOL
  20. BruceInOKC
    BruceInOKC Member
    190
    Oklahoma City, OK
    I believe the EHRS is similar in principle to the coolant thermostat, which stays closed when the coolant is cold, then it opens when the coolant is warm enough so it flows to the radiator. The valve is initially open on the EHRS so the coolant can flow by the exhaust for heating purposes, then the valve closes once it's warm enough. See the diagram below:
    Exhaust Heat Recovery System
