Question regarding first oil change
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by xliderider, Jun 27, 2012.
  1. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Regarding the Prius' first oil change... I have read all of the debates about whether to leave the oil in the car and just have the dealer change it out at the 10K/1 year service, as this is what Toyota has approved and recommends. Some people feel very strongly about changing the oil out sooner to get out any nasty bits of metal, etc. that can cause wear/damage to new engine parts/surfaces. Still others have said that Toyota puts some kind of additive to help protect the car during the break in period (moly additive?) and that changing out the original oil will remove this protection.
    So I'm thinking of a compromise, just changing the oil filter element to get rid of the filtered out metal shavings and bits, but leave the original oil in and top off with 0w-20.
    My question is, when I remove the oil filter cartridge housing, will the oil drain then stop after the oil in the cartridge housing drains out? Or will oil continue to drain out until a new cartridge is placed into the housing and then screwed back in? I'm guessing that the majority of oil is in the drain pan and that only what is in the filter and cartridge housing will come out if the drain plug is left in the drain pan.
    However, some confirmation would be great. ;) Thanks.
    Also, the car will be inclined back slightly on some Rhino ramps if that makes any difference.
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Someone reported on here that the oil filter is just above the oil level in the drain pan. So you should be able to change the oil filter without losing oil in the drain pan. You will need to top off the oil since you will lose the amount that was in the original oil filter.
    xliderider likes this.
  3. xliderider
    8,140
    3,277
    Honolulu, HI
    Thanks, that's what I was hoping to hear. (y)
  4. yeldogt
    yeldogt Active Member
    810
    313
    NE
    Once anything has reached the filter -- it is in the filter .... it is not going to sneak out -- and you are not going to get enough to clog the filter. It was once quite common to change the filter every other oil change -- and actually still is with some power equipment. The oil is more of an issue than the filter. You will be very surprised how clean the oil is at 3k and 5k. But ...if you have any concerns just have the oil changed and enjoy the ride.
  5. xliderider
    8,140
    3,277
    Honolulu, HI
    Sounds good, but the filter media is quite small. About the same size as the miniscule filter that Nissan uses for their 3.5L V6. :eek:
    I have more faith in the synthetic oils than the filter media at this time. ;)
  6. Mendel Leisk
    41,818
    It still is the norm with Honda, though most dealerships ignore it: push filter replacement with every oil change.
  7. Mike500
    Mike500 Senior Member
    2,593
    767
    The price of oil and the oil is cheap.
    I do my own oil change at 3,500 mikes, which my car will reach at the 6 months service interval.
    Then, I'll let the dealer do the one year change, which will probably occure in another 3-4 thousand miles.
    Then, I will wait another year to let the dealer do the 24 month service at about 15,000 miles.
    After thet, I'll de the yearly oil change, with oil and filter.
    I just don't trust leaving the original oil for 8,000 miles, much less; 10,000.
  8. yeldogt
    810
    313
    NE
    Rude person's -- Obviously, do what you feel comfortable ... but the extended interval is well established ..... all should check the condition using the dipstick and change accordingly ..... Years ago everybody changed the coolant every year -- now no one thinks about it.
  9. schorert
    schorert Member
    127
    51
    mass
    Oh I'm pretty sure that priuschat will establish a early coolant change interval soon enough...I mean it's just crazy to drive around with factory coolant for more than 25kmi, right?
  10. Mike500
    2,593
    767
    Take a bath every Saturday Night, if you want to.
    I prefer to shower, every day or even twice, if necessary.
    Thae same thing goes with changing underwear.
    Clean lasts longer.
  11. schorert
    schorert Member
    127
    51
    mass
    You only shower once a day? that's freaking gross man. Do a swab of your underarms and send it for analysis...you may find that the daily showers interval that 99% of americans use is waaaay to long.
  12. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    Each of the sides is correct in their own way for the reasons they use to justify it.
    When just a filter is removed you will lose the oil in the filter and any that is in the plumbing above the filter. It isn't very much, it won't siphon any of the sump oil out with it, and it's a good halfway between the two warring factions.
    Change Early Crowd Reasoning - "To remove any particles caused by break-in that may be smaller than the filter can catch but that are larger than particles that cause absolutely no harm. There is an abundance of these particles at break-in compared to normal use."
    Change Per the Manual Crowd Reasoning - "Because that's what Toyota says to do."
  13. yeldogt
    810
    313
    NE
    My first car with an extended change was a 2000 Jaguar ---10k change intervals with regular 5w-30 .....per manual -- held 9qt -- but it was a 4lt supercharged V8 -- Never a problem and it went to about 100k before I got rid of it. This is nothing new and is well proven. I own three cars now that have change intervals of 10k -12k and 15k.
